easy tv capture card
22 Feb 2007
installed the above...loaded software...plugged in aerial...but when i try and use it with media player i get the message: tuner not found
tuner hardware malfuntioning/not installed.
pc also tries to install an unknown device.
pc spec: acer windows xp mce
amd athlon 64x2 dual core processor 3800+
2.01GHz, 768 mb ram.
can anyone point me in the right direction ?
Good place to start would be the 'unknown device'.
Install a driver for it. Point Windows at the CD that came with the device.
tried card in another pci slot...same result. I think the card may be duff.
The signal from the aerial is not great...can this cause a problem ?
i`ve just installed wintv express...and get same message...tuner not found hardware malfuntioning or not installed.
can it be my aerial set up...although i get a pic on a tv on that lead ?
my aerial set up is as follows: ntl aerial from wall to splitter ( 1 for broadband 1 for TV). Broadband OK. From splitter TV aerial goes to 3 way amplified distribution box (1 for lounge TV 1 for bedroom TV 1 for pc tuner card. Is this the correct set up or do i require something else or need to alter things ?
