EasyAntiCheat - setting a permanent core affinity
21 Oct 2011
ST4
Apparently people have had success fixing the crashing issue in The Division 2 by setting EasyAntiCheat to only run on a single core. This can only be done via Task Manager once the program is running, I've set it to just use core 11 but it reverts back to using all cores on a system reboot/restart. So does anyone know if there's a way to set the affinity for EAC and have it stick after a restart/reboot on Windows 11? I don't want to install a piece of 3rd party software, so that's not an option and setting a shortcut to EAC with a command line switch enabled isn't an option either as EAC starts automatically with The Division 2.
Thanks.
