As most are aware I am building my system. But, I've came across a problem.
In the Maximus IV Extreme manual it says "Do not forget to connect the 8-Pin EATX12v power plug. Otherwise the system won't boot".
I had not connected that. As such, the system was turning on, then off, then on and the red CPU light was active. When I attempted to connect the 8 pin I noticed 4 of the pins had been covered.
The problem I have is can I remove the cover connecting the 4 pins and connect an 8 pin without problems? I don't have a 4-pin. The corsair 1200W came with a bundle of wires but no 4 pin.
What purpose does the EATX12v serve?
Thanks
Thanks
