10 Sep 2009 at 16:11 #1 Occooler Occooler Associate Joined 3 Jun 2009 Posts 201 Location London I can't get eax 1,2,3 to work on call of duty. Has anyone else had the same problem and fixed it? I have a x-fi xtreme gamer sc and vista 64
10 Sep 2009 at 16:18 #2 Phil99 Phil99 Soldato Joined 29 Oct 2004 Posts 10,884 Is the card set to 'Game' mode?
10 Sep 2009 at 21:48 #3 Occooler Occooler Associate OP Joined 3 Jun 2009 Posts 201 Location London yep. I bought the card because of the poor support of a xonar DS. Eax is enabled now in Doom3, so its an improvement atleast. I'm being anal, I know, but I'm entitled to be given the £70 I spent.
10 Sep 2009 at 22:37 #4 Uriel Uriel Soldato Joined 15 Jan 2006 Posts 7,815 Location Derbyshire You need to run the Alchemy Program and select Call of Duty. It should work then, and once you've done it there's no more fiddling with settings like on Xonar. See here for list of games requiring alchemy: http://connect.creativelabs.com/alchemy/Lists/Games/AllItems.aspx Note: setup is a bit more fiddly for anything using Steam. Use the instructions for steam games in the link if using the stam version.
10 Sep 2009 at 22:52 #5 Occooler Occooler Associate OP Joined 3 Jun 2009 Posts 201 Location London thanks for that, I looked on the alchemy website for compatible games, after a google search, but it didn't load properly. I'll try again EDIT I'm an idiot. I downloaded ALchemy and expected it to make everything work. Last edited: 10 Sep 2009
10 Sep 2009 at 22:56 #6 Uriel Uriel Soldato Joined 15 Jan 2006 Posts 7,815 Location Derbyshire Trust me, COD 1 and 2 need Alchemy. COD 4 doesn't require it. If you're playing 1 or 2 just run the software. You should have installed it with the rest of the X-Fi stuff.
11 Sep 2009 at 00:27 #7 Occooler Occooler Associate OP Joined 3 Jun 2009 Posts 201 Location London Eax 3 is now working thanks. I thought alchemy was like a driver, not something that patched games, so I didn't run it!
