Guys i just installed that kit and am running an i7 950 @ 4.ghz. My idle temps on all cores are between 37C- 41C which are down from air cooling with artic pro cooler which used to be around 45C+.
I removed the stock thermal compound and applied artic silver 5 and re-seated the water block again.
When i run prime 95 the temperatures rocket to 75+ on all cores. is this normal?
edit: do i have to change settings in bios as well? Because the cpu cooler is connected to chasis fan point and the big 120mm rad/fan is connected to cpu point as suggested in the instructions.
