ecs 680i sound glitches
13 Jan 2007
hi,i have an ecs 680i mobo and since this is installed i get some sound glitches.i use a bog standard soundblaster live digital and have also tried the onboard and still the same.so far its only noticeable in bf2142...any ideas.
thanks
ecs 680i pn2sli2+ extreme motherboard
intel core2duo [email protected] ghz
zalman cnps9500 with arctic silver 5
1 gig corsair twinx 6400
galaxy 7600 gs oc(possibly 2x quadro 1500 in sli)
sound blaster live digital
hiper 530w psu
19"samsung flat panel
enermax server case.cs-718
Its a known problem with the SLI boards and the 680i chipset everyone i know on most forums that has one has complained the sound doesnt work, or the sound screws up,
My 680i chipset i had to pull the HD audio card out as it was shocking, i put my old Audigy 2 in there and even that sometimes when gaming in SLI will just bomb out on me, and i get a super high pitched squealing into the headset then no sound in or out after that.
Yeah but the previous bios sorted the sli #snap.crackle.pop# issue.
It happened regardless of whether you used onboard or pci soundcard or headphones as you said. Now seems to have been fixed or at least no one is complaining anymore.
The sound issue the op is having does not sound like this.
You could try reinstalling the game and the sound drivers and updating to the latest drivers.
Also, make sure you updated the bios correctly. You HAVE to use a floppy or the windows installer package. Specific details here for the latest P24 bios just out.
http://www.evga.com/community/messageboard/topic.asp?TOPIC_ID=24880
the bios was flashed using the nvidia installer pack under windows,didnt reset the cmos though,will try that next...thanks for your replies.
also i mine is the ecs version,your link is for the evga version,are they compatable?i know they are referance boards.
