Edge vs Chrome
2 Dec 2004
Under The Desk, Wales
Having used both now with Win 10 for me, Chrome is much faster!! Anyone else with the same view?
I think they are very similar in speed, I really like edge but until I can add extensions(adblock) and sync bookmarks I think I will end up staying with chrome.
Edge seems far far better on low end hardware though but that maybe because of the number of extensions I use.
I like Edge, really nice and clean looking but as meandu229 said until they add ext support i will stay with firefox. I use Adblock a keepass ext and can't be without them.
I used Edge 90% most time, it is the fastest browser.
I only used Chrome when sites failed to load on Edge or watch Netflix. If I want to see pictures then I will use Edge because it load instantly while it took too long on Chrome.
using edge turned off flash in settings very fast now.
bugs in Edge
Finding a word, does not work correctly does not jump to second word
Anchors send you to the wrong section of the webpage
Upgraded today and I don't find it faster than Chrome at all. May try tinkering as I love the look of Edge.
