Edgerouter 4 local packet loss and gaming quality issues.
18 Feb 2004
Lincolnshire
So, I have ahouse with 4 adults and 2 kids, kids have pc`s and PS4`s, mostly use the pc`s to game and do school work on. I also have a pc for gaming and its my main activity due to ill health.
I have some knowledge of routers and network but not loads, I have tried various routers over the past year or so (Fritzbox 7530, Asus ac5300 and in the last month or so,the Edgerouter 4).
I Play a lot of Apex legends and games like dauntless, BF-V, NMS etc.
So the connection is Zen Internet 330/50 FTTP, which I thought was going to be so nice to have after coming from a house with only 3.5/.60 (terrible).
So my setup is as follows –
BT ONT Box upstairs – wired cat6 cable downstairs to my current Edgerouter 4 then eth1 is to my 2 day old switch, Netgear s8000. I did have an unmanaged switch a Netgear gs08 I think model number was, but I finally found it was the cause of some of my frustrations, I had a lag in say dauntless spawn area where I would walk forwards and then sometimes end up back where I was not moved at all, the new switch stopped this from happening for example.
The min issue is 2 fold, when I play Apex legends with either both or 1 son the game feels so different, like we are firing rubber bullets and our damage output is negligible. When we are on alone with friends who are living elsewhere and not on our internal network we do way better in both damage and kills. Its reproducible. Had this issue for a long time now.
In apex I have tried setting both my sons pc to launch with a different port number to mine and each others to help with the issue without success. I know it sounds odd as you can have a bad game any one can, but the difference is instantaneous.
The other issue im having is one I need confirmation with. I have been trying to decide if I need to buy a different router, the reason for this is as follows –
I have been checking pings and latency/packet loss. I downloaded a program called Pingplotter which my ISP uses from time to time.
Now on the first hop to say either twitter.com or google or 8.8.8.8 or 8.8.4.4 or my isps DNS server I get packet loss of up to 70% according to pingplotter. So the first hop is 192.168.1.1 as an example and the packet loss is huge.
When I run ping via command prompt this doesn’t show up, and tracert shows some hops being non responsive but not on my local network that I’ve seen so far.
So I tried to isolate the problem, I took both my sons and wifes laptop upstairs to the ONT box and connected 1 at a time to it via a different network cable, no wifi in this house.
So I setup a dialup connect and ran pingplotter again, there was no packet loss on either laptop and obviously no local network 192.168.1.1.
So I thought ok bring the Edge router upstairs and see what happens – ONT box - another different network cable - Edge router then cable to both laptops one at a time.
Pingplotter again and bam the packet loss is back, so now im thinking it’s the Edgerouter either fault or miss config. So I managed to find a Fritzbox 7530 router from when the ISP sent it out at the start of the contract.
Setup the fritzbox upstairs in place of the Edgerouter 4 and the packet loss was still present?
So all I have is ONT – fritzbox or edgrouter 4 – laptop (connected via ethernet cable)
I am at a loss, is pingplotter reliable? And if so are both ruters a problem?
If not reliable then that’s ok but what am I seeing such a difference when I restart the Edgerouter 4 sometimes up to 4 times a day, doesn’t lose connection I just see a huge difference in gaming quality?
On the Edgerouter I have tried SQM both on and off, I setup the router with the wizard and didn’t bridge any of the ports etc. I have tried offloading on and off I have tried both firmware branches, reset to defaults each time and setup from scratch. Also tried UPNP and version 2 and with it off completely.
Where do I go next lol any help very much appreciated.
also pings are around 9-20 ms in most games and pinging google dns as example is 9ms.
posted this 2 other places to try and see what might be going on or if its something and nothing.
I have just seen this posted somewhere -
Hops 1 and 2 show approximately 75% packet loss, yes. But the destination shows 0%, and the destination is all that matters. so not sure if the packet loss is an issue at all.
but that dont explain the gaming issue.
With that first hop being your router I'd start there. Have you swapped out the cable that's connecting the router to the switch? Does it make any difference if you connect a device directly to the LAN port on the router?
Does the router show any errors on the LAN interface? Are speed and duplex fixed or set to auto/auto? What about the switch port? Is that auto/auto or fixed? What speed and duplex are the router and switch reporting for the relevant ports?
thanks for for the help, i changed the cables both from the ONT box to the switch and the switch to the laptop to test and the packet loss remained. i tried another different cable direct to the ONT box and no router and the packet loss was gone.
The duplex is set to auto across all ports. The drop down list shows - 100 full/100 half - 10 full/10 half.
The switch to router is reporting 1000M full speed auto.
Which firmware version are you on? They do a lot of updates for it.
I used to have one of these, it was a nice solid router.
both the latest version 1.10.11 and also tried 2.08 hotfix1
I read the new branch isnt quite where it needs to be in terms of the original stable branch, i used the 1.10.11 as my main firmware and only tried the other as a way to cover all bases.
Did you try a different cabe between the ONT and router WAN port? What speed/duplex is the WAN port on the router reporting? Are there any CRC's or errors showing on the interfaces on the router and switch?
Nothing there that looks unusual.
Re-reading your original post I see you've got an ONT, a FritzBox and the ER4. How exactly are they connected? You should have a cable from the ethernet port on the ONT to the WAN port (eth0 by the looks of it) on the ER4. What is the Fritzbox doing?
Also, did you try a new cable from the ONT to the ER4?
What's eth2 on the ER4 doing? It shows as down but looks like it's in a different VLAN to eth1.
Edit - I really should have read your original post better.
Do a simple packet loss test, do 'ping -n 100 8.8.8.8' and see what the result is. If you're not seeing packet loss on that test then the 70% you were seeing to the first hop is a red herring.
I have seen google rate limit pings to their DNS servers from certain source addresses so I wouldn't use that as a reliable test sample.
I would test directly connected as close to the ONT as possible and work your way back until you find the issue.
Can you share the ping plotter results?
These are the ping plotter results -
https://imgur.com/CkgR5vT
and ping 8.8.8.8 -
C:\Windows\system32>ping -n 100 8.8.8.8
Pinging 8.8.8.8 with 32 bytes of data:
Reply from 8.8.8.8: bytes=32 time=9ms TTL=55
Reply from 8.8.8.8: bytes=32 time=8ms TTL=55
Ping statistics for 8.8.8.8:
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 8ms, Maximum = 9ms, Average = 8ms
no packet loss here.
Zen dns servers
https://imgur.com/U1f8AND
Run a packet capture and see if you're getting things arriving out-of-order, which I think was an EdgeRouter bug at one point
12:39:05.180349 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29278096:29278272, ack 254865, win 1561, length 176
12:39:05.180463 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29278272:29278448, ack 254865, win 1561, length 176
12:39:05.180533 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29278448, win 8207, length 0
12:39:05.180623 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29278448:29278736, ack 254865, win 1561, length 288
12:39:05.180725 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29278736:29278912, ack 254865, win 1561, length 176
12:39:05.180795 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29278912, win 8212, length 0
12:39:05.180804 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 254865:255025, ack 29278912, win 8212, length 160
12:39:05.180904 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29278912:29279200, ack 255025, win 1561, length 288
12:39:05.181017 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29279200:29279376, ack 255025, win 1561, length 176
12:39:05.181061 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29279376, win 8210, length 0
12:39:05.181257 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29279376:29279840, ack 255025, win 1561, length 464
12:39:05.181365 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29279840:29280128, ack 255025, win 1561, length 288
12:39:05.181436 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29280128, win 8207, length 0
12:39:05.181496 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29280128:29280304, ack 255025, win 1561, length 176
12:39:05.181611 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29280304:29280480, ack 255025, win 1561, length 176
12:39:05.181680 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29280480, win 8212, length 0
12:39:05.181772 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29280480:29280768, ack 255025, win 1561, length 288
12:39:05.181883 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29280768:29281056, ack 255025, win 1561, length 288
12:39:05.181955 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29281056, win 8210, length 0
12:39:05.182014 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29281056:29281232, ack 255025, win 1561, length 176
12:39:05.182129 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29281232:29281408, ack 255025, win 1561, length 176
12:39:05.182197 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29281408, win 8208, length 0
12:39:05.182292 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29281408:29281696, ack 255025, win 1561, length 288
12:39:05.182402 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29281696:29281984, ack 255025, win 1561, length 288
12:39:05.182474 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29281984, win 8212, length 0
12:39:05.182533 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29281984:29282160, ack 255025, win 1561, length 176
12:39:05.182646 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29282160:29282336, ack 255025, win 1561, length 176
12:39:05.182716 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29282336, win 8211, length 0
12:39:05.182806 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29282336:29282624, ack 255025, win 1561, length 288
12:39:05.182917 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29282624:29282912, ack 255025, win 1561, length 288
12:39:05.182989 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29282912, win 8208, length 0
12:39:05.183049 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29282912:29283088, ack 255025, win 1561, length 176
12:39:05.183162 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29283088:29283264, ack 255025, win 1561, length 176
12:39:05.183232 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29283264, win 8207, length 0
12:39:05.183323 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29283264:29283552, ack 255025, win 1561, length 288
12:39:05.183433 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29283552:29283840, ack 255025, win 1561, length 288
12:39:05.183504 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29283840, win 8212, length 0
12:39:05.183627 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 91
12:39:05.183657 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29283840:29284016, ack 255025, win 1561, length 176
12:39:05.183782 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29284016:29284192, ack 255025, win 1561, length 176
12:39:05.183853 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29284192, win 8211, length 0
12:39:05.183960 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29284192:29284560, ack 255025, win 1561, length 368
12:39:05.184071 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29284560:29284848, ack 255025, win 1561, length 288
12:39:05.184144 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29284848, win 8208, length 0
12:39:05.184201 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29284848:29285024, ack 255025, win 1561, length 176
12:39:05.184317 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29285024:29285200, ack 255025, win 1561, length 176
12:39:05.184387 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29285200, win 8207, length 0
12:39:05.184478 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29285200:29285488, ack 255025, win 1561, length 288
12:39:05.184601 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29285488:29285776, ack 255025, win 1561, length 288
12:39:05.184674 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29285776, win 8212, length 0
12:39:05.184734 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29285776:29285952, ack 255025, win 1561, length 176
12:39:05.184851 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29285952:29286128, ack 255025, win 1561, length 176
12:39:05.184921 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29286128, win 8211, length 0
12:39:05.185010 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29286128:29286416, ack 255025, win 1561, length 288
12:39:05.185111 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29286416:29286592, ack 255025, win 1561, length 176
12:39:05.185181 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29286592, win 8209, length 0
12:39:05.185269 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29286592:29286880, ack 255025, win 1561, length 288
12:39:05.185372 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29286880:29287056, ack 255025, win 1561, length 176
12:39:05.185442 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29287056, win 8207, length 0
12:39:05.185531 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29287056:29287344, ack 255025, win 1561, length 288
12:39:05.185632 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29287344:29287520, ack 255025, win 1561, length 176
12:39:05.185702 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29287520, win 8212, length 0
12:39:05.185790 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29287520:29287808, ack 255025, win 1561, length 288
12:39:05.185892 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29287808:29287984, ack 255025, win 1561, length 176
12:39:05.185962 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29287984, win 8210, length 0
12:39:05.186053 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29287984:29288272, ack 255025, win 1561, length 288
12:39:05.186154 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29288272:29288448, ack 255025, win 1561, length 176
12:39:05.186236 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29288448, win 8208, length 0
12:39:05.186295 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29288448:29288736, ack 255025, win 1561, length 288
12:39:05.186410 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29288736:29288912, ack 255025, win 1561, length 176
12:39:05.186479 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29288912, win 8207, length 0
12:39:05.186572 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29288912:29289200, ack 255025, win 1561, length 288
12:39:05.186684 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29289200:29289488, ack 255025, win 1561, length 288
12:39:05.186755 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29289488, win 8212, length 0
12:39:05.186815 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29289488:29289664, ack 255025, win 1561, length 176
12:39:05.186930 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29289664:29289840, ack 255025, win 1561, length 176
12:39:05.187000 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29289840, win 8211, length 0
12:39:05.187091 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29289840:29290128, ack 255025, win 1561, length 288
12:39:05.187191 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29290128:29290304, ack 255025, win 1561, length 176
12:39:05.187261 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29290304, win 8209, length 0
12:39:05.187349 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29290304:29290592, ack 255025, win 1561, length 288
12:39:05.187450 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29290592:29290768, ack 255025, win 1561, length 176
12:39:05.187520 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29290768, win 8207, length 0
12:39:05.187607 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29290768:29291056, ack 255025, win 1561, length 288
12:39:05.187708 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29291056:29291232, ack 255025, win 1561, length 176
12:39:05.187778 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29291232, win 8212, length 0
12:39:05.187865 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29291232:29291520, ack 255025, win 1561, length 288
12:39:05.187966 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29291520:29291696, ack 255025, win 1561, length 176
12:39:05.188035 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29291696, win 8210, length 0
12:39:05.188120 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29291696:29291984, ack 255025, win 1561, length 288
12:39:05.188221 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29291984:29292160, ack 255025, win 1561, length 176
12:39:05.188290 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29292160, win 8208, length 0
12:39:05.188377 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29292160:29292448, ack 255025, win 1561, length 288
12:39:05.188478 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29292448:29292624, ack 255025, win 1561, length 176
12:39:05.188548 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29292624, win 8207, length 0
12:39:05.188682 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29292624:29292912, ack 255025, win 1561, length 288
12:39:05.188797 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29292912:29293088, ack 255025, win 1561, length 176
12:39:05.188867 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29293088, win 8212, length 0
12:39:05.188915 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 128
12:39:05.188959 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29293088:29293376, ack 255025, win 1561, length 288
12:39:05.189083 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29293376:29293552, ack 255025, win 1561, length 176
12:39:05.189153 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29293552, win 8210, length 0
12:39:05.189254 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29293552:29293792, ack 255025, win 1561, length 240
12:39:05.189374 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29293792:29294096, ack 255025, win 1561, length 304
12:39:05.189448 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29294096, win 8208, length 0
12:39:05.189530 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29294096:29294384, ack 255025, win 1561, length 288
12:39:05.189633 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29294384:29294560, ack 255025, win 1561, length 176
12:39:05.189703 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29294560, win 8212, length 0
12:39:05.189791 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29294560:29294848, ack 255025, win 1561, length 288
12:39:05.189891 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29294848:29295024, ack 255025, win 1561, length 176
12:39:05.189961 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29295024, win 8210, length 0
12:39:05.190049 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29295024:29295312, ack 255025, win 1561, length 288
12:39:05.190150 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29295312:29295488, ack 255025, win 1561, length 176
12:39:05.190220 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29295488, win 8208, length 0
12:39:05.190302 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29295488:29295776, ack 255025, win 1561, length 288
12:39:05.190406 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29295776:29295952, ack 255025, win 1561, length 176
12:39:05.190475 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29295952, win 8207, length 0
12:39:05.190560 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29295952:29296240, ack 255025, win 1561, length 288
12:39:05.190662 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29296240:29296416, ack 255025, win 1561, length 176
12:39:05.190732 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29296416, win 8212, length 0
12:39:05.190820 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29296416:29296704, ack 255025, win 1561, length 288
12:39:05.190921 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29296704:29296880, ack 255025, win 1561, length 176
12:39:05.190991 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29296880, win 8210, length 0
12:39:05.191077 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29296880:29297168, ack 255025, win 1561, length 288
12:39:05.191181 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29297168:29297344, ack 255025, win 1561, length 176
12:39:05.191250 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29297344, win 8208, length 0
12:39:05.191340 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29297344:29297632, ack 255025, win 1561, length 288
12:39:05.191451 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29297632:29297920, ack 255025, win 1561, length 288
12:39:05.191523 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29297920, win 8212, length 0
12:39:05.191582 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29297920:29298096, ack 255025, win 1561, length 176
12:39:05.191696 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29298096:29298272, ack 255025, win 1561, length 176
12:39:05.191767 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29298272, win 8211, length 0
12:39:05.191858 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29298272:29298560, ack 255025, win 1561, length 288
12:39:05.191968 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29298560:29298848, ack 255025, win 1561, length 288
12:39:05.192040 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29298848, win 8208, length 0
12:39:05.192102 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29298848:29299024, ack 255025, win 1561, length 176
12:39:05.192217 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29299024:29299200, ack 255025, win 1561, length 176
12:39:05.192287 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29299200, win 8207, length 0
12:39:05.192378 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29299200:29299488, ack 255025, win 1561, length 288
12:39:05.192489 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29299488:29299776, ack 255025, win 1561, length 288
12:39:05.192562 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29299776, win 8212, length 0
12:39:05.192621 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29299776:29299952, ack 255025, win 1561, length 176
12:39:05.192735 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29299952:29300128, ack 255025, win 1561, length 176
12:39:05.192808 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29300128, win 8211, length 0
12:39:05.192893 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29300128:29300416, ack 255025, win 1561, length 288
12:39:05.192995 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29300416:29300592, ack 255025, win 1561, length 176
12:39:05.193065 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29300592, win 8209, length 0
12:39:05.193114 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 255025:255185, ack 29300592, win 8209, length 160
12:39:05.193173 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29300592:29300880, ack 255185, win 1561, length 288
12:39:05.193286 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29300880:29301056, ack 255185, win 1561, length 176
12:39:05.193355 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29301056, win 8207, length 0
12:39:05.193530 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29301056:29301520, ack 255185, win 1561, length 464
12:39:05.193639 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29301520:29301808, ack 255185, win 1561, length 288
12:39:05.193711 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29301808, win 8212, length 0
12:39:05.193770 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29301808:29301984, ack 255185, win 1561, length 176
12:39:05.193886 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29301984:29302160, ack 255185, win 1561, length 176
12:39:05.193958 IP 192.168.1.152.63224 > 128.116.66.148.54817: UDP, length 7
12:39:05.193956 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29302160, win 8211, length 0
12:39:05.194047 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29302160:29302448, ack 255185, win 1561, length 288
12:39:05.194158 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29302448:29302624, ack 255185, win 1561, length 176
12:39:05.194227 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29302624, win 8209, length 0
12:39:05.194337 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29302624:29302992, ack 255185, win 1561, length 368
12:39:05.194448 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29302992:29303280, ack 255185, win 1561, length 288
12:39:05.194521 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29303280, win 8212, length 0
12:39:05.194579 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29303280:29303456, ack 255185, win 1561, length 176
12:39:05.194694 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29303456:29303632, ack 255185, win 1561, length 176
12:39:05.194764 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29303632, win 8211, length 0
12:39:05.194857 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29303632:29303920, ack 255185, win 1561, length 288
12:39:05.194967 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29303920:29304208, ack 255185, win 1561, length 288
12:39:05.195040 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29304208, win 8208, length 0
12:39:05.195096 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29304208:29304384, ack 255185, win 1561, length 176
12:39:05.195210 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29304384:29304560, ack 255185, win 1561, length 176
12:39:05.195280 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29304560, win 8207, length 0
12:39:05.195368 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29304560:29304848, ack 255185, win 1561, length 288
12:39:05.195470 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29304848:29305024, ack 255185, win 1561, length 176
12:39:05.195539 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29305024, win 8212, length 0
12:39:05.195626 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29305024:29305312, ack 255185, win 1561, length 288
12:39:05.195729 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29305312:29305488, ack 255185, win 1561, length 176
12:39:05.195798 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29305488, win 8210, length 0
12:39:05.195885 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29305488:29305776, ack 255185, win 1561, length 288
12:39:05.195986 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29305776:29305952, ack 255185, win 1561, length 176
12:39:05.196056 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29305952, win 8208, length 0
12:39:05.196144 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29305952:29306240, ack 255185, win 1561, length 288
12:39:05.196247 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29306240:29306416, ack 255185, win 1561, length 176
12:39:05.196316 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29306416, win 8207, length 0
12:39:05.196402 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29306416:29306704, ack 255185, win 1561, length 288
12:39:05.196503 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29306704:29306880, ack 255185, win 1561, length 176
12:39:05.196573 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29306880, win 8212, length 0
12:39:05.196658 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29306880:29307168, ack 255185, win 1561, length 288
12:39:05.196757 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29307168:29307344, ack 255185, win 1561, length 176
12:39:05.196827 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29307344, win 8210, length 0
12:39:05.196909 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29307344:29307632, ack 255185, win 1561, length 288
12:39:05.197011 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29307632:29307808, ack 255185, win 1561, length 176
12:39:05.197081 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29307808, win 8208, length 0
12:39:05.197167 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29307808:29308096, ack 255185, win 1561, length 288
12:39:05.197267 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29308096:29308272, ack 255185, win 1561, length 176
12:39:05.197337 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29308272, win 8207, length 0
12:39:05.197420 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29308272:29308560, ack 255185, win 1561, length 288
12:39:05.197521 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29308560:29308736, ack 255185, win 1561, length 176
12:39:05.197590 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29308736, win 8212, length 0
12:39:05.197674 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29308736:29309024, ack 255185, win 1561, length 288
12:39:05.197774 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29309024:29309200, ack 255185, win 1561, length 176
12:39:05.197844 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29309200, win 8210, length 0
12:39:05.197932 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29309200:29309488, ack 255185, win 1561, length 288
12:39:05.198032 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29309488:29309664, ack 255185, win 1561, length 176
12:39:05.198102 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29309664, win 8208, length 0
12:39:05.198189 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29309664:29309952, ack 255185, win 1561, length 288
12:39:05.198289 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29309952:29310128, ack 255185, win 1561, length 176
12:39:05.198358 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29310128, win 8207, length 0
12:39:05.198444 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29310128:29310416, ack 255185, win 1561, length 288
12:39:05.198546 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29310416:29310592, ack 255185, win 1561, length 176
12:39:05.198616 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29310592, win 8212, length 0
12:39:05.198735 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29310592:29310880, ack 255185, win 1561, length 288
12:39:05.198863 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29310880:29311168, ack 255185, win 1561, length 288
12:39:05.198935 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29311168, win 8210, length 0
12:39:05.198995 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29311168:29311344, ack 255185, win 1561, length 176
12:39:05.199112 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29311344:29311520, ack 255185, win 1561, length 176
12:39:05.199182 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29311520, win 8208, length 0
12:39:05.199272 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29311520:29311808, ack 255185, win 1561, length 288
12:39:05.199374 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29311808:29311984, ack 255185, win 1561, length 176
12:39:05.199441 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29311984, win 8207, length 0
12:39:05.199535 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29311984:29312272, ack 255185, win 1561, length 288
12:39:05.199645 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29312272:29312560, ack 255185, win 1561, length 288
12:39:05.199715 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29312560, win 8212, length 0
12:39:05.199779 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29312560:29312736, ack 255185, win 1561, length 176
12:39:05.199894 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29312736:29312912, ack 255185, win 1561, length 176
12:39:05.199962 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29312912, win 8211, length 0
12:39:05.200060 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29312912:29313200, ack 255185, win 1561, length 288
12:39:05.200170 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29313200:29313488, ack 255185, win 1561, length 288
12:39:05.200238 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29313488, win 8208, length 0
12:39:05.200303 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29313488:29313664, ack 255185, win 1561, length 176
12:39:05.200444 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 1088
12:39:05.200544 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29313664:29313840, ack 255185, win 1561, length 176
12:39:05.200611 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29313840, win 8207, length 0
12:39:05.200726 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29313840:29314208, ack 255185, win 1561, length 368
12:39:05.200836 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29314208:29314496, ack 255185, win 1561, length 288
12:39:05.200905 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29314496, win 8212, length 0
12:39:05.200966 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29314496:29314672, ack 255185, win 1561, length 176
12:39:05.201082 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29314672:29314848, ack 255185, win 1561, length 176
12:39:05.201148 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29314848, win 8211, length 0
12:39:05.201244 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29314848:29315136, ack 255185, win 1561, length 288
12:39:05.201355 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29315136:29315424, ack 255185, win 1561, length 288
12:39:05.201424 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29315424, win 8208, length 0
12:39:05.201488 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29315424:29315600, ack 255185, win 1561, length 176
12:39:05.201601 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29315600:29315776, ack 255185, win 1561, length 176
12:39:05.201668 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29315776, win 8207, length 0
12:39:05.201763 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29315776:29316064, ack 255185, win 1561, length 288
12:39:05.201873 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29316064:29316352, ack 255185, win 1561, length 288
12:39:05.201942 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29316352, win 8212, length 0
12:39:05.202005 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29316352:29316528, ack 255185, win 1561, length 176
12:39:05.202120 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29316528:29316704, ack 255185, win 1561, length 176
12:39:05.202187 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29316704, win 8211, length 0
12:39:05.202284 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29316704:29316992, ack 255185, win 1561, length 288
12:39:05.202395 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29316992:29317280, ack 255185, win 1561, length 288
12:39:05.202464 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29317280, win 8208, length 0
12:39:05.202529 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29317280:29317456, ack 255185, win 1561, length 176
12:39:05.202642 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29317456:29317632, ack 255185, win 1561, length 176
12:39:05.202709 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29317632, win 8207, length 0
12:39:05.202806 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29317632:29317920, ack 255185, win 1561, length 288
12:39:05.202917 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29317920:29318208, ack 255185, win 1561, length 288
12:39:05.202986 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29318208, win 8212, length 0
12:39:05.203048 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29318208:29318384, ack 255185, win 1561, length 176
12:39:05.203161 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29318384:29318560, ack 255185, win 1561, length 176
12:39:05.203227 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29318560, win 8211, length 0
12:39:05.203321 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29318560:29318848, ack 255185, win 1561, length 288
12:39:05.203431 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29318848:29319136, ack 255185, win 1561, length 288
12:39:05.203500 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29319136, win 8208, length 0
12:39:05.203562 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29319136:29319312, ack 255185, win 1561, length 176
12:39:05.203675 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29319312:29319488, ack 255185, win 1561, length 176
12:39:05.203742 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29319488, win 8207, length 0
12:39:05.203836 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29319488:29319776, ack 255185, win 1561, length 288
12:39:05.203946 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29319776:29320064, ack 255185, win 1561, length 288
12:39:05.204015 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29320064, win 8212, length 0
12:39:05.204078 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29320064:29320240, ack 255185, win 1561, length 176
12:39:05.204192 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29320240:29320416, ack 255185, win 1561, length 176
12:39:05.204259 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29320416, win 8211, length 0
12:39:05.204356 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29320416:29320704, ack 255185, win 1561, length 288
12:39:05.204465 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29320704:29320992, ack 255185, win 1561, length 288
12:39:05.204534 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29320992, win 8208, length 0
12:39:05.204595 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29320992:29321168, ack 255185, win 1561, length 176
12:39:05.204707 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29321168:29321344, ack 255185, win 1561, length 176
12:39:05.204774 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29321344, win 8207, length 0
12:39:05.204869 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29321344:29321632, ack 255185, win 1561, length 288
12:39:05.204980 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29321632:29321920, ack 255185, win 1561, length 288
12:39:05.205049 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29321920, win 8212, length 0
12:39:05.205113 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29321920:29322096, ack 255185, win 1561, length 176
12:39:05.205226 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29322096:29322272, ack 255185, win 1561, length 176
12:39:05.205240 IP 192.168.1.150.62538 > 192.168.1.1.443: Flags [.], ack 107331, win 8206, length 0
12:39:05.205281 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29322272, win 8211, length 0
12:39:05.205390 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29322272:29322560, ack 255185, win 1561, length 288
12:39:05.205510 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29322560:29322944, ack 255185, win 1561, length 384
12:39:05.205582 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29322944, win 8208, length 0
12:39:05.205646 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29322944:29323120, ack 255185, win 1561, length 176
12:39:05.205751 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 13
12:39:05.205819 IP 192.168.1.162.50032 > 52.112.14.106.3480: UDP, length 259
12:39:05.205866 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29323120:29323296, ack 255185, win 1561, length 176
12:39:05.205929 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29323296, win 8207, length 0
12:39:05.205994 IP 192.168.1.153.38198 > 192.168.1.1.53: 52696+ A? pull-cmaf-f16.tiktokcdn.com. (45)
12:39:05.206412 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29323296:29323664, ack 255185, win 1561, length 368
12:39:05.206571 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29323664:29324128, ack 255185, win 1561, length 464
12:39:05.206649 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29324128, win 8212, length 0
12:39:05.206718 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29324128:29324304, ack 255185, win 1561, length 176
12:39:05.206841 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29324304:29324480, ack 255185, win 1561, length 176
12:39:05.206906 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29324480, win 8211, length 0
12:39:05.207005 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29324480:29324768, ack 255185, win 1561, length 288
12:39:05.207116 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29324768:29325056, ack 255185, win 1561, length 288
12:39:05.207183 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29325056, win 8208, length 0
12:39:05.207246 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29325056:29325232, ack 255185, win 1561, length 176
12:39:05.207362 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29325232:29325408, ack 255185, win 1561, length 176
12:39:05.207427 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29325408, win 8207, length 0
12:39:05.207529 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29325408:29325696, ack 255185, win 1561, length 288
12:39:05.207638 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29325696:29325984, ack 255185, win 1561, length 288
12:39:05.207720 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29325984, win 8212, length 0
12:39:05.207767 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29325984:29326160, ack 255185, win 1561, length 176
12:39:05.207848 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 255185:255345, ack 29326160, win 8211, length 160
12:39:05.207911 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29326160:29326336, ack 255185, win 1561, length 176
12:39:05.208049 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29326336:29326624, ack 255345, win 1561, length 288
12:39:05.208117 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29326624, win 8210, length 0
12:39:05.208284 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29326624:29326976, ack 255345, win 1561, length 352
12:39:05.208394 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29326976:29327264, ack 255345, win 1561, length 288
12:39:05.208460 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29327264, win 8207, length 0
12:39:05.208524 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29327264:29327440, ack 255345, win 1561, length 176
12:39:05.208667 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29327440:29327616, ack 255345, win 1561, length 176
12:39:05.208740 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29327616, win 8212, length 0
12:39:05.208876 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29327616:29327904, ack 255345, win 1561, length 288
12:39:05.208989 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29327904:29328192, ack 255345, win 1561, length 288
12:39:05.209059 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29328192, win 8210, length 0
12:39:05.209121 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29328192:29328368, ack 255345, win 1561, length 176
12:39:05.209233 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29328368:29328544, ack 255345, win 1561, length 176
12:39:05.209303 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29328544, win 8208, length 0
12:39:05.209392 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29328544:29328832, ack 255345, win 1561, length 288
12:39:05.209494 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29328832:29329008, ack 255345, win 1561, length 176
12:39:05.209565 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29329008, win 8207, length 0
12:39:05.209649 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29329008:29329296, ack 255345, win 1561, length 288
12:39:05.209750 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29329296:29329472, ack 255345, win 1561, length 176
12:39:05.209820 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29329472, win 8212, length 0
12:39:05.209913 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29329472:29329760, ack 255345, win 1561, length 288
12:39:05.210015 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29329760:29329936, ack 255345, win 1561, length 176
12:39:05.210085 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29329936, win 8210, length 0
12:39:05.210172 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29329936:29330224, ack 255345, win 1561, length 288
12:39:05.210273 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29330224:29330400, ack 255345, win 1561, length 176
12:39:05.210344 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29330400, win 8208, length 0
12:39:05.210395 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 133
12:39:05.210430 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29330400:29330688, ack 255345, win 1561, length 288
12:39:05.210553 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29330688:29330864, ack 255345, win 1561, length 176
12:39:05.210626 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29330864, win 8207, length 0
12:39:05.210721 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29330864:29331104, ack 255345, win 1561, length 240
12:39:05.210840 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29331104:29331408, ack 255345, win 1561, length 304
12:39:05.210912 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29331408, win 8212, length 0
12:39:05.210997 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29331408:29331696, ack 255345, win 1561, length 288
12:39:05.211100 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29331696:29331872, ack 255345, win 1561, length 176
12:39:05.211170 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29331872, win 8210, length 0
12:39:05.211259 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29331872:29332160, ack 255345, win 1561, length 288
12:39:05.211360 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29332160:29332336, ack 255345, win 1561, length 176
12:39:05.211430 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29332336, win 8208, length 0
12:39:05.211517 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29332336:29332624, ack 255345, win 1561, length 288
12:39:05.211619 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29332624:29332800, ack 255345, win 1561, length 176
12:39:05.211689 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29332800, win 8207, length 0
12:39:05.211771 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29332800:29333088, ack 255345, win 1561, length 288
12:39:05.211874 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29333088:29333264, ack 255345, win 1561, length 176
12:39:05.211943 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29333264, win 8212, length 0
12:39:05.212032 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29333264:29333552, ack 255345, win 1561, length 288
12:39:05.212133 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29333552:29333728, ack 255345, win 1561, length 176
12:39:05.212203 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29333728, win 8210, length 0
12:39:05.212292 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29333728:29334016, ack 255345, win 1561, length 288
12:39:05.212393 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29334016:29334192, ack 255345, win 1561, length 176
12:39:05.212463 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29334192, win 8208, length 0
12:39:05.212549 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29334192:29334480, ack 255345, win 1561, length 288
12:39:05.212650 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29334480:29334656, ack 255345, win 1561, length 176
12:39:05.212719 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29334656, win 8207, length 0
12:39:05.212803 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29334656:29334944, ack 255345, win 1561, length 288
12:39:05.212905 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29334944:29335120, ack 255345, win 1561, length 176
12:39:05.212974 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29335120, win 8212, length 0
12:39:05.213060 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29335120:29335408, ack 255345, win 1561, length 288
12:39:05.213161 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29335408:29335584, ack 255345, win 1561, length 176
12:39:05.213230 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29335584, win 8210, length 0
12:39:05.213319 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29335584:29335872, ack 255345, win 1561, length 288
12:39:05.213419 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29335872:29336048, ack 255345, win 1561, length 176
12:39:05.213489 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29336048, win 8208, length 0
12:39:05.213574 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29336048:29336336, ack 255345, win 1561, length 288
12:39:05.213675 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29336336:29336512, ack 255345, win 1561, length 176
12:39:05.213745 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29336512, win 8207, length 0
12:39:05.213832 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29336512:29336800, ack 255345, win 1561, length 288
12:39:05.213931 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29336800:29336976, ack 255345, win 1561, length 176
12:39:05.214003 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29336976, win 8212, length 0
12:39:05.214104 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29336976:29337264, ack 255345, win 1561, length 288
12:39:05.214213 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29337264:29337552, ack 255345, win 1561, length 288
12:39:05.214295 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29337552, win 8210, length 0
12:39:05.214342 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29337552:29337728, ack 255345, win 1561, length 176
12:39:05.214453 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29337728:29337904, ack 255345, win 1561, length 176
12:39:05.214523 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29337904, win 8208, length 0
12:39:05.214612 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29337904:29338192, ack 255345, win 1561, length 288
12:39:05.214713 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29338192:29338368, ack 255345, win 1561, length 176
12:39:05.214783 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29338368, win 8207, length 0
12:39:05.214868 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29338368:29338656, ack 255345, win 1561, length 288
12:39:05.214971 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29338656:29338832, ack 255345, win 1561, length 176
12:39:05.215040 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29338832, win 8212, length 0
12:39:05.215127 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29338832:29339120, ack 255345, win 1561, length 288
12:39:05.215228 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29339120:29339296, ack 255345, win 1561, length 176
12:39:05.215298 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29339296, win 8210, length 0
12:39:05.215385 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29339296:29339584, ack 255345, win 1561, length 288
12:39:05.215488 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29339584:29339760, ack 255345, win 1561, length 176
12:39:05.215558 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29339760, win 8208, length 0
12:39:05.215676 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29339760:29340048, ack 255345, win 1561, length 288
12:39:05.215690 IP 192.168.1.1.53 > 192.168.1.153.38198: 52696 4/0/0 CNAME pull-cmaf-f16.tiktokcdn.com.akamaized.net., CNAME a1935.z.akamai.net., A 173.222.210.49, A 173.222.210.56 (161)
12:39:05.215808 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29340048:29340336, ack 255345, win 1561, length 288
12:39:05.215878 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29340336, win 8212, length 0
12:39:05.215949 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29340336:29340512, ack 255345, win 1561, length 176
12:39:05.216089 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29340512:29340880, ack 255345, win 1561, length 368
12:39:05.216165 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29340880, win 8210, length 0
12:39:05.216246 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29340880:29341168, ack 255345, win 1561, length 288
12:39:05.216349 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29341168:29341344, ack 255345, win 1561, length 176
12:39:05.216419 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29341344, win 8208, length 0
12:39:05.216506 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29341344:29341632, ack 255345, win 1561, length 288
12:39:05.216607 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29341632:29341808, ack 255345, win 1561, length 176
12:39:05.216677 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29341808, win 8212, length 0
12:39:05.216763 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29341808:29342096, ack 255345, win 1561, length 288
12:39:05.216762 IP 192.168.1.152.63224 > 128.116.66.148.54817: UDP, length 7
12:39:05.216871 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29342096:29342272, ack 255345, win 1561, length 176
12:39:05.216941 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29342272, win 8210, length 0
12:39:05.217051 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29342272:29342640, ack 255345, win 1561, length 368
12:39:05.217160 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29342640:29342928, ack 255345, win 1561, length 288
12:39:05.217232 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29342928, win 8208, length 0
12:39:05.217292 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29342928:29343104, ack 255345, win 1561, length 176
12:39:05.217406 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29343104:29343280, ack 255345, win 1561, length 176
12:39:05.217475 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29343280, win 8212, length 0
12:39:05.217568 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29343280:29343568, ack 255345, win 1561, length 288
12:39:05.217567 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 255345:255505, ack 29343280, win 8212, length 160
12:39:05.217703 IP 192.168.1.162.54915 > 192.168.1.255.54915: UDP, length 263
12:39:05.217717 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29343568:29343744, ack 255505, win 1561, length 176
12:39:05.217730 ARP, Request who-has 169.254.255.255 tell 192.168.1.162, length 46
12:39:05.217836 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29343744, win 8210, length 0
12:39:05.217960 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29343744:29344208, ack 255505, win 1561, length 464
12:39:05.218094 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29344208:29344656, ack 255505, win 1561, length 448
12:39:05.218170 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29344656, win 8207, length 0
12:39:05.218228 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29344656:29344832, ack 255505, win 1561, length 176
12:39:05.218342 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29344832:29345008, ack 255505, win 1561, length 176
12:39:05.218409 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29345008, win 8212, length 0
12:39:05.218504 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29345008:29345296, ack 255505, win 1561, length 288
12:39:05.218640 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29345296:29345584, ack 255505, win 1561, length 288
12:39:05.218719 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29345584, win 8210, length 0
12:39:05.218845 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29345584:29345760, ack 255505, win 1561, length 176
12:39:05.218960 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29345760:29346048, ack 255505, win 1561, length 288
12:39:05.219032 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29346048, win 8208, length 0
12:39:05.219093 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29346048:29346224, ack 255505, win 1561, length 176
12:39:05.219209 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29346224:29346400, ack 255505, win 1561, length 176
12:39:05.219279 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29346400, win 8207, length 0
12:39:05.219370 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29346400:29346688, ack 255505, win 1561, length 288
12:39:05.219481 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29346688:29346976, ack 255505, win 1561, length 288
12:39:05.219552 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29346976, win 8212, length 0
12:39:05.219612 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29346976:29347152, ack 255505, win 1561, length 176
12:39:05.219725 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29347152:29347328, ack 255505, win 1561, length 176
12:39:05.219795 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29347328, win 8211, length 0
12:39:05.219885 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29347328:29347616, ack 255505, win 1561, length 288
12:39:05.219994 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29347616:29347904, ack 255505, win 1561, length 288
12:39:05.220066 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29347904, win 8208, length 0
12:39:05.220125 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29347904:29348080, ack 255505, win 1561, length 176
12:39:05.220236 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29348080:29348256, ack 255505, win 1561, length 176
12:39:05.220306 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29348256, win 8207, length 0
12:39:05.220394 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29348256:29348544, ack 255505, win 1561, length 288
12:39:05.220494 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29348544:29348720, ack 255505, win 1561, length 176
12:39:05.220565 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29348720, win 8212, length 0
12:39:05.220652 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29348720:29349008, ack 255505, win 1561, length 288
12:39:05.220754 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29349008:29349184, ack 255505, win 1561, length 176
12:39:05.220824 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29349184, win 8210, length 0
12:39:05.220911 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29349184:29349472, ack 255505, win 1561, length 288
12:39:05.221013 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29349472:29349648, ack 255505, win 1561, length 176
12:39:05.221083 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29349648, win 8208, length 0
12:39:05.221169 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29349648:29349936, ack 255505, win 1561, length 288
12:39:05.221270 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29349936:29350112, ack 255505, win 1561, length 176
12:39:05.221339 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29350112, win 8207, length 0
12:39:05.221428 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29350112:29350400, ack 255505, win 1561, length 288
12:39:05.221529 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29350400:29350576, ack 255505, win 1561, length 176
12:39:05.221599 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29350576, win 8212, length 0
12:39:05.221690 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29350576:29350864, ack 255505, win 1561, length 288
12:39:05.221791 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29350864:29351040, ack 255505, win 1561, length 176
12:39:05.221861 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29351040, win 8210, length 0
12:39:05.221943 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29351040:29351328, ack 255505, win 1561, length 288
12:39:05.222047 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29351328:29351504, ack 255505, win 1561, length 176
12:39:05.222117 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29351504, win 8208, length 0
12:39:05.222206 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29351504:29351792, ack 255505, win 1561, length 288
12:39:05.222308 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29351792:29351968, ack 255505, win 1561, length 176
12:39:05.222378 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29351968, win 8207, length 0
12:39:05.222465 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29351968:29352256, ack 255505, win 1561, length 288
12:39:05.222566 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29352256:29352432, ack 255505, win 1561, length 176
12:39:05.222636 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29352432, win 8212, length 0
12:39:05.222722 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29352432:29352720, ack 255505, win 1561, length 288
12:39:05.222823 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29352720:29352896, ack 255505, win 1561, length 176
12:39:05.222893 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29352896, win 8210, length 0
12:39:05.222979 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29352896:29353184, ack 255505, win 1561, length 288
12:39:05.223079 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29353184:29353360, ack 255505, win 1561, length 176
12:39:05.223149 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29353360, win 8208, length 0
12:39:05.223236 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29353360:29353648, ack 255505, win 1561, length 288
12:39:05.223338 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29353648:29353824, ack 255505, win 1561, length 176
12:39:05.223407 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29353824, win 8207, length 0
12:39:05.223490 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29353824:29354112, ack 255505, win 1561, length 288
12:39:05.223592 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29354112:29354288, ack 255505, win 1561, length 176
12:39:05.223662 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29354288, win 8212, length 0
12:39:05.223749 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29354288:29354576, ack 255505, win 1561, length 288
12:39:05.223851 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29354576:29354752, ack 255505, win 1561, length 176
12:39:05.223921 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29354752, win 8210, length 0
12:39:05.224009 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29354752:29355040, ack 255505, win 1561, length 288
12:39:05.224111 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29355040:29355216, ack 255505, win 1561, length 176
12:39:05.224183 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29355216, win 8208, length 0
12:39:05.224264 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29355216:29355504, ack 255505, win 1561, length 288
12:39:05.224367 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29355504:29355680, ack 255505, win 1561, length 176
12:39:05.224436 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29355680, win 8207, length 0
12:39:05.224523 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29355680:29355968, ack 255505, win 1561, length 288
12:39:05.224623 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29355968:29356144, ack 255505, win 1561, length 176
12:39:05.224693 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29356144, win 8212, length 0
12:39:05.224779 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29356144:29356432, ack 255505, win 1561, length 288
12:39:05.224881 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29356432:29356608, ack 255505, win 1561, length 176
12:39:05.224951 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29356608, win 8210, length 0
12:39:05.225031 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29356608:29356896, ack 255505, win 1561, length 288
12:39:05.225134 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29356896:29357072, ack 255505, win 1561, length 176
12:39:05.225204 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29357072, win 8208, length 0
12:39:05.225292 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29357072:29357360, ack 255505, win 1561, length 288
12:39:05.225393 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29357360:29357536, ack 255505, win 1561, length 176
12:39:05.225461 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29357536, win 8207, length 0
12:39:05.225552 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29357536:29357824, ack 255505, win 1561, length 288
12:39:05.225662 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29357824:29358112, ack 255505, win 1561, length 288
12:39:05.225730 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29358112, win 8212, length 0
12:39:05.225791 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29358112:29358288, ack 255505, win 1561, length 176
12:39:05.225906 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29358288:29358464, ack 255505, win 1561, length 176
12:39:05.225973 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29358464, win 8211, length 0
12:39:05.226066 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29358464:29358752, ack 255505, win 1561, length 288
12:39:05.226175 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29358752:29359040, ack 255505, win 1561, length 288
12:39:05.226245 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29359040, win 8208, length 0
12:39:05.226308 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29359040:29359216, ack 255505, win 1561, length 176
12:39:05.226422 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29359216:29359392, ack 255505, win 1561, length 176
12:39:05.226489 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29359392, win 8207, length 0
12:39:05.226582 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29359392:29359680, ack 255505, win 1561, length 288
12:39:05.226690 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29359680:29359968, ack 255505, win 1561, length 288
12:39:05.226759 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29359968, win 8212, length 0
12:39:05.226822 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29359968:29360144, ack 255505, win 1561, length 176
12:39:05.226935 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29360144:29360320, ack 255505, win 1561, length 176
12:39:05.227002 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29360320, win 8211, length 0
12:39:05.227097 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29360320:29360608, ack 255505, win 1561, length 288
12:39:05.227206 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29360608:29360896, ack 255505, win 1561, length 288
12:39:05.227275 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29360896, win 8208, length 0
12:39:05.227337 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29360896:29361072, ack 255505, win 1561, length 176
12:39:05.227447 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29361072:29361248, ack 255505, win 1561, length 176
12:39:05.227518 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29361248, win 8207, length 0
12:39:05.227609 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29361248:29361536, ack 255505, win 1561, length 288
12:39:05.227710 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29361536:29361712, ack 255505, win 1561, length 176
12:39:05.227777 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29361712, win 8212, length 0
12:39:05.227869 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29361712:29362000, ack 255505, win 1561, length 288
12:39:05.227980 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29362000:29362288, ack 255505, win 1561, length 288
12:39:05.228048 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29362288, win 8210, length 0
12:39:05.228110 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29362288:29362464, ack 255505, win 1561, length 176
12:39:05.228221 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29362464:29362640, ack 255505, win 1561, length 176
12:39:05.228288 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29362640, win 8208, length 0
12:39:05.228393 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29362640:29362928, ack 255505, win 1561, length 288
12:39:05.228502 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29362928:29363216, ack 255505, win 1561, length 288
12:39:05.228512 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 133
12:39:05.228584 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29363216, win 8212, length 0
12:39:05.228812 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29363216:29363600, ack 255505, win 1561, length 384
12:39:05.228918 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29363600:29363760, ack 255505, win 1561, length 160
12:39:05.228985 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29363760, win 8210, length 0
12:39:05.229053 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29363760:29363936, ack 255505, win 1561, length 176
12:39:05.229168 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29363936:29364112, ack 255505, win 1561, length 176
12:39:05.229235 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29364112, win 8209, length 0
12:39:05.229332 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29364112:29364400, ack 255505, win 1561, length 288
12:39:05.229442 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29364400:29364688, ack 255505, win 1561, length 288
12:39:05.229511 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29364688, win 8212, length 0
12:39:05.229569 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29364688:29364864, ack 255505, win 1561, length 176
12:39:05.229683 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29364864:29365040, ack 255505, win 1561, length 176
12:39:05.229750 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29365040, win 8211, length 0
12:39:05.229843 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29365040:29365328, ack 255505, win 1561, length 288
12:39:05.229953 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29365328:29365616, ack 255505, win 1561, length 288
12:39:05.230021 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29365616, win 8208, length 0
12:39:05.230084 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29365616:29365792, ack 255505, win 1561, length 176
12:39:05.230198 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29365792:29365968, ack 255505, win 1561, length 176
12:39:05.230270 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29365968, win 8207, length 0
12:39:05.230358 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29365968:29366256, ack 255505, win 1561, length 288
12:39:05.230459 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29366256:29366432, ack 255505, win 1561, length 176
12:39:05.230526 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29366432, win 8212, length 0
12:39:05.230617 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29366432:29366720, ack 255505, win 1561, length 288
12:39:05.230727 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29366720:29367008, ack 255505, win 1561, length 288
12:39:05.230795 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29367008, win 8210, length 0
12:39:05.230860 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29367008:29367184, ack 255505, win 1561, length 176
12:39:05.230972 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29367184:29367360, ack 255505, win 1561, length 176
12:39:05.231039 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29367360, win 8208, length 0
12:39:05.231134 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29367360:29367648, ack 255505, win 1561, length 288
12:39:05.231242 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29367648:29367936, ack 255505, win 1561, length 288
12:39:05.231313 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29367936, win 8212, length 0
12:39:05.231373 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29367936:29368112, ack 255505, win 1561, length 176
12:39:05.231488 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29368112:29368288, ack 255505, win 1561, length 176
12:39:05.231553 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29368288, win 8211, length 0
12:39:05.231650 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29368288:29368576, ack 255505, win 1561, length 288
12:39:05.231760 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29368576:29368864, ack 255505, win 1561, length 288
12:39:05.231827 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29368864, win 8208, length 0
12:39:05.231892 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29368864:29369040, ack 255505, win 1561, length 176
12:39:05.232004 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29369040:29369216, ack 255505, win 1561, length 176
12:39:05.232069 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29369216, win 8207, length 0
12:39:05.232167 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29369216:29369504, ack 255505, win 1561, length 288
12:39:05.232276 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29369504:29369792, ack 255505, win 1561, length 288
12:39:05.232343 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29369792, win 8212, length 0
12:39:05.232407 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29369792:29369968, ack 255505, win 1561, length 176
12:39:05.232518 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29369968:29370144, ack 255505, win 1561, length 176
12:39:05.232583 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29370144, win 8211, length 0
12:39:05.232680 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29370144:29370432, ack 255505, win 1561, length 288
12:39:05.232788 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29370432:29370720, ack 255505, win 1561, length 288
12:39:05.232856 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29370720, win 8208, length 0
12:39:05.232921 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29370720:29370896, ack 255505, win 1561, length 176
12:39:05.233032 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29370896:29371072, ack 255505, win 1561, length 176
12:39:05.233096 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29371072, win 8207, length 0
12:39:05.233194 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29371072:29371360, ack 255505, win 1561, length 288
12:39:05.233303 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29371360:29371648, ack 255505, win 1561, length 288
12:39:05.233370 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29371648, win 8212, length 0
12:39:05.233435 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29371648:29371824, ack 255505, win 1561, length 176
12:39:05.233547 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29371824:29372000, ack 255505, win 1561, length 176
12:39:05.233611 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29372000, win 8211, length 0
12:39:05.233709 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29372000:29372288, ack 255505, win 1561, length 288
12:39:05.233749 IP 192.168.1.153.40649 > 192.168.1.1.53: 51903+ A? pull-flv-l11.tiktokcdn.com. (44)
12:39:05.233805 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 255505:255665, ack 29372288, win 8210, length 160
12:39:05.233852 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29372288:29372576, ack 255505, win 1561, length 288
12:39:05.233996 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29372576:29372752, ack 255665, win 1561, length 176
12:39:05.234063 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29372752, win 8208, length 0
12:39:05.234236 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29372752:29372800, ack 255665, win 1561, length 48
12:39:05.234241 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 169
12:39:05.234273 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 185
12:39:05.234298 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 74
12:39:05.234322 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 68
12:39:05.234345 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 79
12:39:05.234376 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29372800:29373088, ack 255665, win 1561, length 288
12:39:05.234428 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 77
12:39:05.234454 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 66
12:39:05.234439 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29373088, win 8206, length 0
12:39:05.234477 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 95
12:39:05.234500 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 95
12:39:05.234523 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 95
12:39:05.234569 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29373088:29373504, ack 255665, win 1561, length 416
12:39:05.234744 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29373504:29374448, ack 255665, win 1561, length 944
12:39:05.234827 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29374448, win 8212, length 0
12:39:05.234924 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29374448:29374864, ack 255665, win 1561, length 416
12:39:05.235036 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29374864:29375152, ack 255665, win 1561, length 288
12:39:05.235106 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29375152, win 8209, length 0
12:39:05.235169 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29375152:29375328, ack 255665, win 1561, length 176
12:39:05.235284 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29375328:29375504, ack 255665, win 1561, length 176
12:39:05.235349 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29375504, win 8208, length 0
12:39:05.235446 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29375504:29375792, ack 255665, win 1561, length 288
12:39:05.235555 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29375792:29376080, ack 255665, win 1561, length 288
12:39:05.235623 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29376080, win 8212, length 0
12:39:05.235687 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29376080:29376256, ack 255665, win 1561, length 176
12:39:05.235798 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29376256:29376432, ack 255665, win 1561, length 176
12:39:05.235868 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29376432, win 8211, length 0
12:39:05.235957 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29376432:29376720, ack 255665, win 1561, length 288
12:39:05.236058 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29376720:29376896, ack 255665, win 1561, length 176
12:39:05.236128 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29376896, win 8209, length 0
12:39:05.236213 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29376896:29377184, ack 255665, win 1561, length 288
12:39:05.236315 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29377184:29377360, ack 255665, win 1561, length 176
12:39:05.236384 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29377360, win 8207, length 0
12:39:05.236469 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29377360:29377648, ack 255665, win 1561, length 288
12:39:05.236573 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29377648:29377824, ack 255665, win 1561, length 176
12:39:05.236643 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29377824, win 8212, length 0
12:39:05.236730 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29377824:29378112, ack 255665, win 1561, length 288
12:39:05.236832 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29378112:29378288, ack 255665, win 1561, length 176
12:39:05.236901 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29378288, win 8210, length 0
12:39:05.236987 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29378288:29378576, ack 255665, win 1561, length 288
12:39:05.237087 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29378576:29378752, ack 255665, win 1561, length 176
12:39:05.237157 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29378752, win 8208, length 0
12:39:05.237242 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29378752:29379040, ack 255665, win 1561, length 288
12:39:05.237343 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29379040:29379216, ack 255665, win 1561, length 176
12:39:05.237413 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29379216, win 8207, length 0
12:39:05.237497 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29379216:29379504, ack 255665, win 1561, length 288
12:39:05.237597 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29379504:29379680, ack 255665, win 1561, length 176
12:39:05.237670 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29379680, win 8212, length 0
12:39:05.237748 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29379680:29379968, ack 255665, win 1561, length 288
12:39:05.237851 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29379968:29380144, ack 255665, win 1561, length 176
12:39:05.237920 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29380144, win 8210, length 0
12:39:05.238017 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29380144:29380432, ack 255665, win 1561, length 288
12:39:05.238126 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29380432:29380720, ack 255665, win 1561, length 288
12:39:05.238198 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29380720, win 8208, length 0
12:39:05.238256 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29380720:29380896, ack 255665, win 1561, length 176
12:39:05.238368 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29380896:29381072, ack 255665, win 1561, length 176
12:39:05.238437 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29381072, win 8207, length 0
12:39:05.238528 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29381072:29381360, ack 255665, win 1561, length 288
12:39:05.238661 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29381360:29381552, ack 255665, win 1561, length 192
12:39:05.238732 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29381552, win 8212, length 0
12:39:05.238860 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29381552:29381824, ack 255665, win 1561, length 272
12:39:05.238973 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29381824:29382112, ack 255665, win 1561, length 288
12:39:05.239045 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29382112, win 8210, length 0
12:39:05.239103 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29382112:29382288, ack 255665, win 1561, length 176
12:39:05.239225 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29382288:29382464, ack 255665, win 1561, length 176
12:39:05.239295 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29382464, win 8208, length 0
12:39:05.239388 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29382464:29382752, ack 255665, win 1561, length 288
12:39:05.239499 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29382752:29383040, ack 255665, win 1561, length 288
12:39:05.239570 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29383040, win 8212, length 0
12:39:05.239628 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29383040:29383216, ack 255665, win 1561, length 176
12:39:05.239740 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29383216:29383392, ack 255665, win 1561, length 176
12:39:05.239810 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29383392, win 8211, length 0
12:39:05.239897 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29383392:29383680, ack 255665, win 1561, length 288
12:39:05.239999 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29383680:29383856, ack 255665, win 1561, length 176
12:39:05.240069 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29383856, win 8209, length 0
12:39:05.240155 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29383856:29384144, ack 255665, win 1561, length 288
12:39:05.240257 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29384144:29384320, ack 255665, win 1561, length 176
12:39:05.240327 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29384320, win 8207, length 0
12:39:05.240416 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29384320:29384608, ack 255665, win 1561, length 288
12:39:05.240518 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29384608:29384784, ack 255665, win 1561, length 176
12:39:05.240587 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29384784, win 8212, length 0
12:39:05.240677 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29384784:29385072, ack 255665, win 1561, length 288
12:39:05.240788 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29385072:29385360, ack 255665, win 1561, length 288
12:39:05.240860 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29385360, win 8210, length 0
12:39:05.240919 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29385360:29385536, ack 255665, win 1561, length 176
12:39:05.241032 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29385536:29385712, ack 255665, win 1561, length 176
12:39:05.241101 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29385712, win 8208, length 0
12:39:05.241195 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29385712:29386000, ack 255665, win 1561, length 288
12:39:05.241305 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29386000:29386288, ack 255665, win 1561, length 288
12:39:05.241380 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29386288, win 8212, length 0
12:39:05.241383 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 255665:255825, ack 29386288, win 8212, length 160
12:39:05.241447 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29386288:29386464, ack 255665, win 1561, length 176
12:39:05.241575 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29386464:29386640, ack 255825, win 1561, length 176
12:39:05.241624 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29386640, win 8211, length 0
12:39:05.241819 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29386640:29387104, ack 255825, win 1561, length 464
12:39:05.241929 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29387104:29387392, ack 255825, win 1561, length 288
12:39:05.242001 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29387392, win 8208, length 0
12:39:05.242059 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29387392:29387568, ack 255825, win 1561, length 176
12:39:05.242173 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29387568:29387744, ack 255825, win 1561, length 176
12:39:05.242243 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29387744, win 8206, length 0
12:39:05.242334 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29387744:29388032, ack 255825, win 1561, length 288
12:39:05.242438 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29388032:29388208, ack 255825, win 1561, length 176
12:39:05.242508 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29388208, win 8212, length 0
12:39:05.242595 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29388208:29388496, ack 255825, win 1561, length 288
12:39:05.242697 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29388496:29388672, ack 255825, win 1561, length 176
12:39:05.242766 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29388672, win 8210, length 0
12:39:05.242869 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29388672:29388960, ack 255825, win 1561, length 288
12:39:05.242979 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29388960:29389248, ack 255825, win 1561, length 288
12:39:05.243051 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29389248, win 8208, length 0
12:39:05.243109 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29389248:29389424, ack 255825, win 1561, length 176
12:39:05.243223 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29389424:29389600, ack 255825, win 1561, length 176
12:39:05.243292 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29389600, win 8207, length 0
12:39:05.243393 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29389600:29389888, ack 255825, win 1561, length 288
12:39:05.243522 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29389888:29390176, ack 255825, win 1561, length 288
12:39:05.243552 IP 192.168.1.1.53 > 192.168.1.153.40649: 51903 17/0/0 CNAME flv-l11.tiktokcdn.liveplay.myqcloud.com., CNAME all.huodonghylivecdn.sched.ovscdns.net., A 203.205.224.46, A 203.205.224.47, A 203.205.224.51, A 211.152.136.34, A 211.152.136.54, A 211.152.136.80, A 211.152.136.95, A 211.152.136.105, A 211.152.136.113, A 211.152.136.116, A 87.245.210.92, A 87.245.210.93, A 87.245.210.95, A 87.245.210.96, A 203.205.224.43 (386)
12:39:05.243595 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29390176, win 8212, length 0
12:39:05.243672 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29390176:29390352, ack 255825, win 1561, length 176
12:39:05.243798 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29390352:29390528, ack 255825, win 1561, length 176
12:39:05.243868 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29390528, win 8211, length 0
12:39:05.243995 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29390528:29391120, ack 255825, win 1561, length 592
12:39:05.244119 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29391120:29391536, ack 255825, win 1561, length 416
12:39:05.244199 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29391536, win 8207, length 0
12:39:05.244250 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29391536:29391712, ack 255825, win 1561, length 176
12:39:05.244362 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29391712:29391888, ack 255825, win 1561, length 176
12:39:05.244432 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29391888, win 8212, length 0
12:39:05.244523 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29391888:29392176, ack 255825, win 1561, length 288
12:39:05.244634 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29392176:29392464, ack 255825, win 1561, length 288
12:39:05.244706 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29392464, win 8210, length 0
12:39:05.244763 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29392464:29392640, ack 255825, win 1561, length 176
12:39:05.244875 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29392640:29392816, ack 255825, win 1561, length 176
12:39:05.244945 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29392816, win 8208, length 0
12:39:05.245033 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29392816:29393104, ack 255825, win 1561, length 288
12:39:05.245134 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29393104:29393280, ack 255825, win 1561, length 176
12:39:05.245204 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29393280, win 8207, length 0
12:39:05.245291 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29393280:29393568, ack 255825, win 1561, length 288
12:39:05.245394 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29393568:29393744, ack 255825, win 1561, length 176
12:39:05.245464 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29393744, win 8212, length 0
12:39:05.245553 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29393744:29394032, ack 255825, win 1561, length 288
12:39:05.245664 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29394032:29394320, ack 255825, win 1561, length 288
12:39:05.245738 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29394320, win 8210, length 0
12:39:05.245794 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29394320:29394496, ack 255825, win 1561, length 176
12:39:05.245907 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29394496:29394672, ack 255825, win 1561, length 176
12:39:05.245978 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29394672, win 8208, length 0
12:39:05.246068 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29394672:29394960, ack 255825, win 1561, length 288
12:39:05.246169 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29394960:29395136, ack 255825, win 1561, length 176
12:39:05.246238 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29395136, win 8207, length 0
12:39:05.246329 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29395136:29395424, ack 255825, win 1561, length 288
12:39:05.246441 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29395424:29395712, ack 255825, win 1561, length 288
12:39:05.246513 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29395712, win 8212, length 0
12:39:05.246571 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29395712:29395888, ack 255825, win 1561, length 176
12:39:05.246683 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29395888:29396064, ack 255825, win 1561, length 176
12:39:05.246755 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29396064, win 8211, length 0
12:39:05.246840 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29396064:29396352, ack 255825, win 1561, length 288
12:39:05.246941 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29396352:29396528, ack 255825, win 1561, length 176
12:39:05.246941 IP 192.168.1.150.62925 > 161.35.188.1.443: Flags [P.], seq 8582:9421, ack 19605, win 1025, length 839
12:39:05.247049 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29396528:29396816, ack 255825, win 1561, length 288
12:39:05.247048 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29396528, win 8209, length 0
12:39:05.247269 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29396816:29397120, ack 255825, win 1561, length 304
12:39:05.247345 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29397120, win 8207, length 0
12:39:05.247438 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29397120:29397408, ack 255825, win 1561, length 288
12:39:05.247541 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29397408:29397584, ack 255825, win 1561, length 176
12:39:05.247611 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29397584, win 8212, length 0
12:39:05.247699 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29397584:29397872, ack 255825, win 1561, length 288
12:39:05.247801 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29397872:29398048, ack 255825, win 1561, length 176
12:39:05.247871 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29398048, win 8210, length 0
12:39:05.247962 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29398048:29398336, ack 255825, win 1561, length 288
12:39:05.248063 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29398336:29398512, ack 255825, win 1561, length 176
12:39:05.248134 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29398512, win 8208, length 0
12:39:05.248218 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29398512:29398800, ack 255825, win 1561, length 288
12:39:05.248321 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29398800:29398976, ack 255825, win 1561, length 176
12:39:05.248395 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29398976, win 8207, length 0
12:39:05.248483 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29398976:29399264, ack 255825, win 1561, length 288
12:39:05.248612 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29399264:29399440, ack 255825, win 1561, length 176
12:39:05.248684 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29399440, win 8212, length 0
12:39:05.248808 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29399440:29399728, ack 255825, win 1561, length 288
12:39:05.248922 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29399728:29400016, ack 255825, win 1561, length 288
12:39:05.248995 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29400016, win 8210, length 0
12:39:05.249053 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29400016:29400192, ack 255825, win 1561, length 176
12:39:05.249166 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29400192:29400368, ack 255825, win 1561, length 176
12:39:05.249235 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29400368, win 8208, length 0
12:39:05.249324 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29400368:29400656, ack 255825, win 1561, length 288
12:39:05.249426 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29400656:29400832, ack 255825, win 1561, length 176
12:39:05.249496 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29400832, win 8207, length 0
12:39:05.249513 IP 192.168.1.152.63224 > 128.116.66.148.54817: UDP, length 33
12:39:05.249584 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29400832:29401120, ack 255825, win 1561, length 288
12:39:05.249634 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 125
12:39:05.249700 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29401120:29401296, ack 255825, win 1561, length 176
12:39:05.249770 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29401296, win 8212, length 0
12:39:05.249842 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29401296:29401456, ack 255825, win 1561, length 160
12:39:05.249983 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29401456:29401792, ack 255825, win 1561, length 336
12:39:05.250057 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29401792, win 8210, length 0
12:39:05.250163 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29401792:29402208, ack 255825, win 1561, length 416
12:39:05.250273 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29402208:29402496, ack 255825, win 1561, length 288
12:39:05.250346 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29402496, win 8207, length 0
12:39:05.250405 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29402496:29402672, ack 255825, win 1561, length 176
12:39:05.250519 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29402672:29402848, ack 255825, win 1561, length 176
12:39:05.250588 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29402848, win 8212, length 0
12:39:05.250681 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29402848:29403136, ack 255825, win 1561, length 288
12:39:05.250791 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29403136:29403424, ack 255825, win 1561, length 288
12:39:05.250862 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29403424, win 8210, length 0
12:39:05.250922 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29403424:29403600, ack 255825, win 1561, length 176
12:39:05.251033 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29403600:29403776, ack 255825, win 1561, length 176
12:39:05.251103 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29403776, win 8208, length 0
12:39:05.251191 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29403776:29404064, ack 255825, win 1561, length 288
12:39:05.251292 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29404064:29404240, ack 255825, win 1561, length 176
12:39:05.251362 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29404240, win 8207, length 0
12:39:05.251450 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29404240:29404528, ack 255825, win 1561, length 288
12:39:05.251553 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29404528:29404704, ack 255825, win 1561, length 176
12:39:05.251623 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29404704, win 8212, length 0
12:39:05.251712 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29404704:29404992, ack 255825, win 1561, length 288
12:39:05.251814 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29404992:29405168, ack 255825, win 1561, length 176
12:39:05.251884 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29405168, win 8210, length 0
12:39:05.252072 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29405168:29405456, ack 255825, win 1561, length 288
12:39:05.252248 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29405456:29405632, ack 255825, win 1561, length 176
12:39:05.252320 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29405632, win 8208, length 0
12:39:05.252414 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29405632:29405920, ack 255825, win 1561, length 288
12:39:05.252525 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29405920:29406208, ack 255825, win 1561, length 288
12:39:05.252597 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29406208, win 8212, length 0
12:39:05.252657 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29406208:29406384, ack 255825, win 1561, length 176
12:39:05.252771 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29406384:29406560, ack 255825, win 1561, length 176
12:39:05.252840 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29406560, win 8211, length 0
12:39:05.252934 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29406560:29406848, ack 255825, win 1561, length 288
12:39:05.253044 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29406848:29407136, ack 255825, win 1561, length 288
12:39:05.253117 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29407136, win 8208, length 0
12:39:05.253174 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29407136:29407312, ack 255825, win 1561, length 176
12:39:05.253285 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29407312:29407488, ack 255825, win 1561, length 176
12:39:05.253329 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 255825:255985, ack 29407312, win 8208, length 160
12:39:05.253459 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29407488:29407776, ack 255985, win 1561, length 288
12:39:05.253617 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29407776, win 8212, length 0
12:39:05.253666 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29407776:29408128, ack 255985, win 1561, length 352
12:39:05.253780 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29408128:29408304, ack 255985, win 1561, length 176
12:39:05.253849 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29408304, win 8210, length 0
12:39:05.253946 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29408304:29408592, ack 255985, win 1561, length 288
12:39:05.254058 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29408592:29408880, ack 255985, win 1561, length 288
12:39:05.254129 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29408880, win 8208, length 0
12:39:05.254192 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29408880:29409056, ack 255985, win 1561, length 176
12:39:05.254309 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29409056:29409232, ack 255985, win 1561, length 176
12:39:05.254308 IP 192.168.1.153.39752 > 192.168.1.1.53: 43783+ A? pull-hls-l1.tiktokcdn.com. (43)
12:39:05.254384 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29409232, win 8206, length 0
12:39:05.254549 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29409232:29409520, ack 255985, win 1561, length 288
12:39:05.254698 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29409520:29409904, ack 255985, win 1561, length 384
12:39:05.254774 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29409904, win 8212, length 0
12:39:05.254851 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29409904:29410080, ack 255985, win 1561, length 176
12:39:05.254969 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29410080:29410256, ack 255985, win 1561, length 176
12:39:05.255039 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29410256, win 8211, length 0
12:39:05.255126 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29410256:29410544, ack 255985, win 1561, length 288
12:39:05.255228 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29410544:29410720, ack 255985, win 1561, length 176
12:39:05.255298 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29410720, win 8209, length 0
12:39:05.255387 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29410720:29411008, ack 255985, win 1561, length 288
12:39:05.255489 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29411008:29411184, ack 255985, win 1561, length 176
12:39:05.255558 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29411184, win 8207, length 0
12:39:05.255647 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29411184:29411472, ack 255985, win 1561, length 288
12:39:05.255748 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29411472:29411648, ack 255985, win 1561, length 176
12:39:05.255820 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29411648, win 8212, length 0
12:39:05.255903 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29411648:29411936, ack 255985, win 1561, length 288
12:39:05.256006 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29411936:29412112, ack 255985, win 1561, length 176
12:39:05.256076 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29412112, win 8210, length 0
12:39:05.256164 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29412112:29412400, ack 255985, win 1561, length 288
12:39:05.256266 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29412400:29412576, ack 255985, win 1561, length 176
12:39:05.256336 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29412576, win 8208, length 0
12:39:05.256424 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29412576:29412864, ack 255985, win 1561, length 288
12:39:05.256526 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29412864:29413040, ack 255985, win 1561, length 176
12:39:05.256596 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29413040, win 8207, length 0
12:39:05.256685 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29413040:29413328, ack 255985, win 1561, length 288
12:39:05.256787 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29413328:29413504, ack 255985, win 1561, length 176
12:39:05.256857 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29413504, win 8212, length 0
12:39:05.256941 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29413504:29413792, ack 255985, win 1561, length 288
12:39:05.257042 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29413792:29413968, ack 255985, win 1561, length 176
12:39:05.257112 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29413968, win 8210, length 0
12:39:05.257198 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29413968:29414256, ack 255985, win 1561, length 288
12:39:05.257300 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29414256:29414432, ack 255985, win 1561, length 176
12:39:05.257369 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29414432, win 8208, length 0
12:39:05.257454 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29414432:29414720, ack 255985, win 1561, length 288
12:39:05.257555 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29414720:29414896, ack 255985, win 1561, length 176
12:39:05.257625 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29414896, win 8207, length 0
12:39:05.257727 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29414896:29415184, ack 255985, win 1561, length 288
12:39:05.257838 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29415184:29415472, ack 255985, win 1561, length 288
12:39:05.257910 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29415472, win 8212, length 0
12:39:05.257969 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29415472:29415648, ack 255985, win 1561, length 176
12:39:05.258082 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29415648:29415824, ack 255985, win 1561, length 176
12:39:05.258152 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29415824, win 8211, length 0
12:39:05.258242 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29415824:29416112, ack 255985, win 1561, length 288
12:39:05.258343 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29416112:29416288, ack 255985, win 1561, length 176
12:39:05.258410 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29416288, win 8209, length 0
12:39:05.258503 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29416288:29416576, ack 255985, win 1561, length 288
12:39:05.258642 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29416576:29416864, ack 255985, win 1561, length 288
12:39:05.258713 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29416864, win 8207, length 0
12:39:05.258843 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29416864:29417040, ack 255985, win 1561, length 176
12:39:05.258958 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29417040:29417328, ack 255985, win 1561, length 288
12:39:05.259026 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29417328, win 8212, length 0
12:39:05.259092 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29417328:29417504, ack 255985, win 1561, length 176
12:39:05.259215 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29417504:29417680, ack 255985, win 1561, length 176
12:39:05.259282 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29417680, win 8211, length 0
12:39:05.259376 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29417680:29417968, ack 255985, win 1561, length 288
12:39:05.259486 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29417968:29418256, ack 255985, win 1561, length 288
12:39:05.259555 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29418256, win 8208, length 0
12:39:05.259619 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29418256:29418432, ack 255985, win 1561, length 176
12:39:05.259732 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29418432:29418608, ack 255985, win 1561, length 176
12:39:05.259799 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29418608, win 8207, length 0
12:39:05.259894 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29418608:29418896, ack 255985, win 1561, length 288
12:39:05.260005 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29418896:29419184, ack 255985, win 1561, length 288
12:39:05.260073 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29419184, win 8212, length 0
12:39:05.260135 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29419184:29419360, ack 255985, win 1561, length 176
12:39:05.260163 IP 192.168.1.152.63224 > 128.116.66.148.54817: UDP, length 49
12:39:05.260255 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29419360:29419536, ack 255985, win 1561, length 176
12:39:05.260323 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29419536, win 8211, length 0
12:39:05.260444 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29419536:29419904, ack 255985, win 1561, length 368
12:39:05.260556 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29419904:29420192, ack 255985, win 1561, length 288
12:39:05.260625 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29420192, win 8208, length 0
12:39:05.260687 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29420192:29420368, ack 255985, win 1561, length 176
12:39:05.260800 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29420368:29420544, ack 255985, win 1561, length 176
12:39:05.260867 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29420544, win 8207, length 0
12:39:05.260962 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29420544:29420832, ack 255985, win 1561, length 288
12:39:05.261073 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29420832:29421120, ack 255985, win 1561, length 288
12:39:05.261141 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29421120, win 8212, length 0
12:39:05.261205 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29421120:29421296, ack 255985, win 1561, length 176
12:39:05.261318 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29421296:29421472, ack 255985, win 1561, length 176
12:39:05.261387 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29421472, win 8211, length 0
12:39:05.261482 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29421472:29421760, ack 255985, win 1561, length 288
12:39:05.261592 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29421760:29422048, ack 255985, win 1561, length 288
12:39:05.261661 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29422048, win 8208, length 0
12:39:05.261725 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29422048:29422224, ack 255985, win 1561, length 176
12:39:05.261838 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29422224:29422400, ack 255985, win 1561, length 176
12:39:05.261905 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29422400, win 8207, length 0
12:39:05.262002 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29422400:29422688, ack 255985, win 1561, length 288
12:39:05.262112 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29422688:29422976, ack 255985, win 1561, length 288
12:39:05.262180 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29422976, win 8212, length 0
12:39:05.262243 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29422976:29423152, ack 255985, win 1561, length 176
12:39:05.262358 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29423152:29423328, ack 255985, win 1561, length 176
12:39:05.262424 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29423328, win 8211, length 0
12:39:05.262519 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29423328:29423616, ack 255985, win 1561, length 288
12:39:05.262630 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29423616:29423904, ack 255985, win 1561, length 288
12:39:05.262702 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29423904, win 8208, length 0
12:39:05.262761 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29423904:29424080, ack 255985, win 1561, length 176
12:39:05.262874 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29424080:29424256, ack 255985, win 1561, length 176
12:39:05.262941 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29424256, win 8207, length 0
12:39:05.263035 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29424256:29424544, ack 255985, win 1561, length 288
12:39:05.263145 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29424544:29424832, ack 255985, win 1561, length 288
12:39:05.263214 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29424832, win 8212, length 0
12:39:05.263276 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29424832:29425008, ack 255985, win 1561, length 176
12:39:05.263390 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29425008:29425184, ack 255985, win 1561, length 176
12:39:05.263457 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29425184, win 8211, length 0
12:39:05.263634 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29425184:29425472, ack 255985, win 1561, length 288
12:39:05.263732 IP 192.168.1.1.53 > 192.168.1.153.39752: 43783 4/0/0 CNAME pull-hls-l1.tiktokcdn.com.wsdvs.com., A 163.171.130.134, A 163.171.130.136, A 163.171.129.137 (137)
12:39:05.263762 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29425472:29425760, ack 255985, win 1561, length 288
12:39:05.263830 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29425760, win 8208, length 0
12:39:05.263972 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29425760:29425936, ack 255985, win 1561, length 176
12:39:05.264106 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29425936:29426400, ack 255985, win 1561, length 464
12:39:05.264179 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29426400, win 8212, length 0
12:39:05.264239 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29426400:29426576, ack 255985, win 1561, length 176
12:39:05.264353 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29426576:29426752, ack 255985, win 1561, length 176
12:39:05.264422 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29426752, win 8211, length 0
12:39:05.264513 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29426752:29427040, ack 255985, win 1561, length 288
12:39:05.264624 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29427040:29427328, ack 255985, win 1561, length 288
12:39:05.264691 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29427328, win 8208, length 0
12:39:05.264757 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29427328:29427504, ack 255985, win 1561, length 176
12:39:05.264871 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29427504:29427680, ack 255985, win 1561, length 176
12:39:05.264936 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29427680, win 8207, length 0
12:39:05.265034 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29427680:29427968, ack 255985, win 1561, length 288
12:39:05.265143 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29427968:29428256, ack 255985, win 1561, length 288
12:39:05.265210 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29428256, win 8212, length 0
12:39:05.265277 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29428256:29428432, ack 255985, win 1561, length 176
12:39:05.265391 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29428432:29428608, ack 255985, win 1561, length 176
12:39:05.265456 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29428608, win 8211, length 0
12:39:05.265555 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29428608:29428896, ack 255985, win 1561, length 288
12:39:05.265665 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29428896:29429184, ack 255985, win 1561, length 288
12:39:05.265732 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29429184, win 8208, length 0
12:39:05.265797 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29429184:29429360, ack 255985, win 1561, length 176
12:39:05.265909 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29429360:29429536, ack 255985, win 1561, length 176
12:39:05.265974 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29429536, win 8207, length 0
12:39:05.266071 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29429536:29429824, ack 255985, win 1561, length 288
12:39:05.266182 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29429824:29430112, ack 255985, win 1561, length 288
12:39:05.266249 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29430112, win 8212, length 0
12:39:05.266313 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29430112:29430288, ack 255985, win 1561, length 176
12:39:05.266427 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29430288:29430464, ack 255985, win 1561, length 176
12:39:05.266491 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29430464, win 8211, length 0
12:39:05.266590 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29430464:29430752, ack 255985, win 1561, length 288
12:39:05.266699 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29430752:29431040, ack 255985, win 1561, length 288
12:39:05.266769 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29431040, win 8208, length 0
12:39:05.266831 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29431040:29431216, ack 255985, win 1561, length 176
12:39:05.266944 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29431216:29431392, ack 255985, win 1561, length 176
12:39:05.267012 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29431392, win 8207, length 0
12:39:05.267110 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29431392:29431680, ack 255985, win 1561, length 288
12:39:05.267220 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29431680:29431968, ack 255985, win 1561, length 288
12:39:05.267286 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29431968, win 8212, length 0
12:39:05.267350 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29431968:29432144, ack 255985, win 1561, length 176
12:39:05.267462 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29432144:29432320, ack 255985, win 1561, length 176
12:39:05.267527 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29432320, win 8211, length 0
12:39:05.267626 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29432320:29432608, ack 255985, win 1561, length 288
12:39:05.267735 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29432608:29432896, ack 255985, win 1561, length 288
12:39:05.267806 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29432896, win 8208, length 0
12:39:05.267819 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 255985:256145, ack 29432896, win 8208, length 160
12:39:05.267878 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29432896:29433072, ack 255985, win 1561, length 176
12:39:05.268092 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 1062
12:39:05.268114 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29433072:29433248, ack 256145, win 1561, length 176
12:39:05.268176 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29433248, win 8207, length 0
12:39:05.268379 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29433248:29433712, ack 256145, win 1561, length 464
12:39:05.268500 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29433712:29434080, ack 256145, win 1561, length 368
12:39:05.268594 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29434080, win 8212, length 0
12:39:05.268660 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29434080:29434256, ack 256145, win 1561, length 176
12:39:05.268783 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29434256:29434432, ack 256145, win 1561, length 176
12:39:05.268853 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29434432, win 8211, length 0
12:39:05.268947 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29434432:29434720, ack 256145, win 1561, length 288
12:39:05.269060 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29434720:29435008, ack 256145, win 1561, length 288
12:39:05.269132 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29435008, win 8208, length 0
12:39:05.269190 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29435008:29435184, ack 256145, win 1561, length 176
12:39:05.269293 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 133
12:39:05.269313 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29435184:29435360, ack 256145, win 1561, length 176
12:39:05.269383 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29435360, win 8207, length 0
12:39:05.269453 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29435360:29435520, ack 256145, win 1561, length 160
12:39:05.269624 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29435520:29436128, ack 256145, win 1561, length 608
12:39:05.269711 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29436128, win 8212, length 0
12:39:05.269930 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29436128:29436304, ack 256145, win 1561, length 176
12:39:05.270038 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29436304:29436464, ack 256145, win 1561, length 160
12:39:05.270113 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29436464, win 8211, length 0
12:39:05.270174 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29436464:29436640, ack 256145, win 1561, length 176
12:39:05.270294 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29436640:29436816, ack 256145, win 1561, length 176
12:39:05.270365 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29436816, win 8209, length 0
12:39:05.270455 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29436816:29437104, ack 256145, win 1561, length 288
12:39:05.270566 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29437104:29437392, ack 256145, win 1561, length 288
12:39:05.270638 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29437392, win 8207, length 0
12:39:05.270697 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29437392:29437568, ack 256145, win 1561, length 176
12:39:05.270811 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29437568:29437744, ack 256145, win 1561, length 176
12:39:05.270881 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29437744, win 8212, length 0
12:39:05.270971 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29437744:29438032, ack 256145, win 1561, length 288
12:39:05.271081 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29438032:29438320, ack 256145, win 1561, length 288
12:39:05.271153 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29438320, win 8210, length 0
12:39:05.271212 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29438320:29438496, ack 256145, win 1561, length 176
12:39:05.271324 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29438496:29438672, ack 256145, win 1561, length 176
12:39:05.271394 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29438672, win 8208, length 0
12:39:05.271483 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29438672:29438960, ack 256145, win 1561, length 288
12:39:05.271583 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29438960:29439136, ack 256145, win 1561, length 176
12:39:05.271653 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29439136, win 8207, length 0
12:39:05.271741 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29439136:29439424, ack 256145, win 1561, length 288
12:39:05.271843 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29439424:29439600, ack 256145, win 1561, length 176
12:39:05.271913 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29439600, win 8212, length 0
12:39:05.272001 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29439600:29439888, ack 256145, win 1561, length 288
12:39:05.272102 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29439888:29440064, ack 256145, win 1561, length 176
12:39:05.272171 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29440064, win 8210, length 0
12:39:05.272256 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29440064:29440352, ack 256145, win 1561, length 288
12:39:05.272357 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29440352:29440528, ack 256145, win 1561, length 176
12:39:05.272427 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29440528, win 8208, length 0
12:39:05.272515 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29440528:29440816, ack 256145, win 1561, length 288
12:39:05.272618 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29440816:29440992, ack 256145, win 1561, length 176
12:39:05.272687 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29440992, win 8207, length 0
12:39:05.272790 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29440992:29441280, ack 256145, win 1561, length 288
12:39:05.272901 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29441280:29441568, ack 256145, win 1561, length 288
12:39:05.272973 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29441568, win 8212, length 0
12:39:05.273030 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29441568:29441744, ack 256145, win 1561, length 176
12:39:05.273142 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29441744:29441920, ack 256145, win 1561, length 176
12:39:05.273211 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29441920, win 8211, length 0
12:39:05.273300 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29441920:29442208, ack 256145, win 1561, length 288
12:39:05.273401 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29442208:29442384, ack 256145, win 1561, length 176
12:39:05.273470 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29442384, win 8209, length 0
12:39:05.273562 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29442384:29442672, ack 256145, win 1561, length 288
12:39:05.273664 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29442672:29442848, ack 256145, win 1561, length 176
12:39:05.273734 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29442848, win 8207, length 0
12:39:05.273823 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29442848:29443136, ack 256145, win 1561, length 288
12:39:05.273923 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29443136:29443312, ack 256145, win 1561, length 176
12:39:05.273993 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29443312, win 8212, length 0
12:39:05.274080 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29443312:29443600, ack 256145, win 1561, length 288
12:39:05.274180 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29443600:29443776, ack 256145, win 1561, length 176
12:39:05.274250 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29443776, win 8210, length 0
12:39:05.274338 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29443776:29444064, ack 256145, win 1561, length 288
12:39:05.274438 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29444064:29444240, ack 256145, win 1561, length 176
12:39:05.274450 IP 192.168.1.153.45764 > 192.168.1.1.53: 58886+ A? pull-hls-f5.tiktokcdn.com. (43)
12:39:05.274508 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29444240, win 8208, length 0
12:39:05.274596 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29444240:29444528, ack 256145, win 1561, length 288
12:39:05.274733 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29444528:29444704, ack 256145, win 1561, length 176
12:39:05.274806 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29444704, win 8207, length 0
12:39:05.274950 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29444704:29445088, ack 256145, win 1561, length 384
12:39:05.275064 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29445088:29445376, ack 256145, win 1561, length 288
12:39:05.275136 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29445376, win 8212, length 0
12:39:05.275196 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29445376:29445552, ack 256145, win 1561, length 176
12:39:05.275312 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29445552:29445728, ack 256145, win 1561, length 176
12:39:05.275382 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29445728, win 8211, length 0
12:39:05.275535 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 13
12:39:05.275574 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29445728:29446016, ack 256145, win 1561, length 288
12:39:05.275687 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29446016:29446192, ack 256145, win 1561, length 176
12:39:05.275757 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29446192, win 8209, length 0
12:39:05.275865 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29446192:29446560, ack 256145, win 1561, length 368
12:39:05.275977 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29446560:29446848, ack 256145, win 1561, length 288
12:39:05.276050 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29446848, win 8212, length 0
12:39:05.276108 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29446848:29447024, ack 256145, win 1561, length 176
12:39:05.276222 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29447024:29447200, ack 256145, win 1561, length 176
12:39:05.276292 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29447200, win 8211, length 0
12:39:05.276379 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29447200:29447488, ack 256145, win 1561, length 288
12:39:05.276484 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29447488:29447664, ack 256145, win 1561, length 176
12:39:05.276554 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29447664, win 8209, length 0
12:39:05.276647 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29447664:29447952, ack 256145, win 1561, length 288
12:39:05.276758 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29447952:29448240, ack 256145, win 1561, length 288
12:39:05.276830 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29448240, win 8207, length 0
12:39:05.276889 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29448240:29448416, ack 256145, win 1561, length 176
12:39:05.277002 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29448416:29448592, ack 256145, win 1561, length 176
12:39:05.277072 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29448592, win 8212, length 0
12:39:05.277165 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29448592:29448880, ack 256145, win 1561, length 288
12:39:05.277275 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29448880:29449168, ack 256145, win 1561, length 288
12:39:05.277347 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29449168, win 8210, length 0
12:39:05.277407 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29449168:29449344, ack 256145, win 1561, length 176
12:39:05.277522 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29449344:29449520, ack 256145, win 1561, length 176
12:39:05.277592 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29449520, win 8208, length 0
12:39:05.277683 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29449520:29449808, ack 256145, win 1561, length 288
12:39:05.277793 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29449808:29450096, ack 256145, win 1561, length 288
12:39:05.277865 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29450096, win 8212, length 0
12:39:05.277924 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29450096:29450272, ack 256145, win 1561, length 176
12:39:05.278037 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29450272:29450448, ack 256145, win 1561, length 176
12:39:05.278081 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 256145:256305, ack 29450272, win 8211, length 160
12:39:05.278216 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29450448:29450736, ack 256305, win 1561, length 288
12:39:05.278374 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29450736, win 8210, length 0
12:39:05.278425 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29450736:29451088, ack 256305, win 1561, length 352
12:39:05.278539 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29451088:29451264, ack 256305, win 1561, length 176
12:39:05.278612 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29451264, win 8207, length 0
12:39:05.278737 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29451264:29451552, ack 256305, win 1561, length 288
12:39:05.278852 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29451552:29451840, ack 256305, win 1561, length 288
12:39:05.278924 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29451840, win 8212, length 0
12:39:05.278983 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29451840:29452016, ack 256305, win 1561, length 176
12:39:05.279099 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29452016:29452192, ack 256305, win 1561, length 176
12:39:05.279168 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29452192, win 8211, length 0
12:39:05.279258 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29452192:29452480, ack 256305, win 1561, length 288
12:39:05.279362 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29452480:29452656, ack 256305, win 1561, length 176
12:39:05.279431 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29452656, win 8209, length 0
12:39:05.279521 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29452656:29452944, ack 256305, win 1561, length 288
12:39:05.279632 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29452944:29453232, ack 256305, win 1561, length 288
12:39:05.279704 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29453232, win 8207, length 0
12:39:05.279763 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29453232:29453408, ack 256305, win 1561, length 176
12:39:05.279875 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29453408:29453584, ack 256305, win 1561, length 176
12:39:05.279944 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29453584, win 8212, length 0
12:39:05.280036 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29453584:29453872, ack 256305, win 1561, length 288
12:39:05.280147 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29453872:29454160, ack 256305, win 1561, length 288
12:39:05.280218 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29454160, win 8210, length 0
12:39:05.280278 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29454160:29454336, ack 256305, win 1561, length 176
12:39:05.280394 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29454336:29454512, ack 256305, win 1561, length 176
12:39:05.280464 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29454512, win 8208, length 0
12:39:05.280554 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29454512:29454800, ack 256305, win 1561, length 288
12:39:05.280656 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29454800:29454976, ack 256305, win 1561, length 176
12:39:05.280726 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29454976, win 8207, length 0
12:39:05.280815 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29454976:29455264, ack 256305, win 1561, length 288
12:39:05.280917 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29455264:29455440, ack 256305, win 1561, length 176
12:39:05.280986 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29455440, win 8212, length 0
12:39:05.281074 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29455440:29455728, ack 256305, win 1561, length 288
12:39:05.281175 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29455728:29455904, ack 256305, win 1561, length 176
12:39:05.281245 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29455904, win 8210, length 0
12:39:05.281331 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29455904:29456192, ack 256305, win 1561, length 288
12:39:05.281432 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29456192:29456368, ack 256305, win 1561, length 176
12:39:05.281502 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29456368, win 8208, length 0
12:39:05.281587 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29456368:29456656, ack 256305, win 1561, length 288
12:39:05.281689 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29456656:29456832, ack 256305, win 1561, length 176
12:39:05.281762 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29456832, win 8207, length 0
12:39:05.281840 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29456832:29457120, ack 256305, win 1561, length 288
12:39:05.281944 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29457120:29457296, ack 256305, win 1561, length 176
12:39:05.282014 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29457296, win 8212, length 0
12:39:05.282101 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29457296:29457584, ack 256305, win 1561, length 288
12:39:05.282203 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29457584:29457760, ack 256305, win 1561, length 176
12:39:05.282273 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29457760, win 8210, length 0
12:39:05.282361 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29457760:29458048, ack 256305, win 1561, length 288
12:39:05.282463 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29458048:29458224, ack 256305, win 1561, length 176
12:39:05.282533 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29458224, win 8208, length 0
12:39:05.282623 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29458224:29458512, ack 256305, win 1561, length 288
12:39:05.282724 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29458512:29458688, ack 256305, win 1561, length 176
12:39:05.282793 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29458688, win 8207, length 0
12:39:05.282877 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29458688:29458976, ack 256305, win 1561, length 288
12:39:05.282978 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29458976:29459152, ack 256305, win 1561, length 176
12:39:05.283047 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29459152, win 8212, length 0
12:39:05.283132 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29459152:29459440, ack 256305, win 1561, length 288
12:39:05.283234 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29459440:29459616, ack 256305, win 1561, length 176
12:39:05.283304 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29459616, win 8210, length 0
12:39:05.283389 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29459616:29459904, ack 256305, win 1561, length 288
12:39:05.283490 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29459904:29460080, ack 256305, win 1561, length 176
12:39:05.283560 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29460080, win 8208, length 0
12:39:05.283646 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29460080:29460368, ack 256305, win 1561, length 288
12:39:05.283747 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29460368:29460544, ack 256305, win 1561, length 176
12:39:05.283816 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29460544, win 8207, length 0
12:39:05.283996 IP 192.168.1.1.53 > 192.168.1.153.45764: 58886 4/0/0 CNAME pull-hls-f5.tiktokcdn.com.akamaized.net., CNAME a1865.z.akamai.net., A 173.222.210.24, A 173.222.210.51 (157)
12:39:05.284007 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29460544:29460832, ack 256305, win 1561, length 288
12:39:05.284193 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 61
12:39:05.284238 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29460832:29461120, ack 256305, win 1561, length 288
12:39:05.284307 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29461120, win 8212, length 0
12:39:05.284461 IP 192.168.1.152.63224 > 128.116.66.148.54817: UDP, length 10
12:39:05.284486 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29461120:29461696, ack 256305, win 1561, length 576
12:39:05.284594 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29461696:29461856, ack 256305, win 1561, length 160
12:39:05.284664 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29461856, win 8209, length 0
12:39:05.284730 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29461856:29462000, ack 256305, win 1561, length 144
12:39:05.284862 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29462000:29462304, ack 256305, win 1561, length 304
12:39:05.284935 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29462304, win 8207, length 0
12:39:05.285022 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29462304:29462592, ack 256305, win 1561, length 288
12:39:05.285124 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29462592:29462768, ack 256305, win 1561, length 176
12:39:05.285194 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29462768, win 8212, length 0
12:39:05.285282 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29462768:29463056, ack 256305, win 1561, length 288
12:39:05.285383 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29463056:29463232, ack 256305, win 1561, length 176
12:39:05.285453 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29463232, win 8210, length 0
12:39:05.285541 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29463232:29463520, ack 256305, win 1561, length 288
12:39:05.285645 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29463520:29463696, ack 256305, win 1561, length 176
12:39:05.285700 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 141
12:39:05.285713 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29463696, win 8208, length 0
12:39:05.285832 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29463696:29463984, ack 256305, win 1561, length 288
12:39:05.285969 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29463984:29464352, ack 256305, win 1561, length 368
12:39:05.286045 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29464352, win 8212, length 0
12:39:05.286166 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29464352:29464528, ack 256305, win 1561, length 176
12:39:05.286278 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29464528:29464816, ack 256305, win 1561, length 288
12:39:05.286350 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29464816, win 8210, length 0
12:39:05.286409 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29464816:29464992, ack 256305, win 1561, length 176
12:39:05.286522 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29464992:29465168, ack 256305, win 1561, length 176
12:39:05.286592 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29465168, win 8209, length 0
12:39:05.286678 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29465168:29465456, ack 256305, win 1561, length 288
12:39:05.286781 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29465456:29465632, ack 256305, win 1561, length 176
12:39:05.286850 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29465632, win 8207, length 0
12:39:05.286936 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29465632:29465920, ack 256305, win 1561, length 288
12:39:05.287038 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29465920:29466096, ack 256305, win 1561, length 176
12:39:05.287108 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29466096, win 8212, length 0
12:39:05.287197 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29466096:29466384, ack 256305, win 1561, length 288
12:39:05.287293 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 13
12:39:05.287417 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29466384:29466560, ack 256305, win 1561, length 176
12:39:05.287487 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29466560, win 8210, length 0
12:39:05.287593 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29466560:29466928, ack 256305, win 1561, length 368
12:39:05.287704 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29466928:29467216, ack 256305, win 1561, length 288
12:39:05.287775 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29467216, win 8208, length 0
12:39:05.287833 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29467216:29467392, ack 256305, win 1561, length 176
12:39:05.287945 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29467392:29467568, ack 256305, win 1561, length 176
12:39:05.288016 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29467568, win 8212, length 0
12:39:05.288103 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29467568:29467856, ack 256305, win 1561, length 288
12:39:05.288204 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29467856:29468032, ack 256305, win 1561, length 176
12:39:05.288273 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29468032, win 8210, length 0
12:39:05.288362 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29468032:29468320, ack 256305, win 1561, length 288
12:39:05.288463 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29468320:29468496, ack 256305, win 1561, length 176
12:39:05.288533 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29468496, win 8208, length 0
12:39:05.288666 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29468496:29468784, ack 256305, win 1561, length 288
12:39:05.288776 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29468784:29468960, ack 256305, win 1561, length 176
12:39:05.288847 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29468960, win 8207, length 0
12:39:05.288934 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29468960:29469248, ack 256305, win 1561, length 288
12:39:05.289039 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29469248:29469424, ack 256305, win 1561, length 176
12:39:05.289109 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29469424, win 8212, length 0
12:39:05.289197 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29469424:29469712, ack 256305, win 1561, length 288
12:39:05.289298 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29469712:29469888, ack 256305, win 1561, length 176
12:39:05.289367 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29469888, win 8210, length 0
12:39:05.289457 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29469888:29470176, ack 256305, win 1561, length 288
12:39:05.289557 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29470176:29470352, ack 256305, win 1561, length 176
12:39:05.289625 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29470352, win 8208, length 0
12:39:05.289714 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29470352:29470640, ack 256305, win 1561, length 288
12:39:05.289824 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29470640:29470928, ack 256305, win 1561, length 288
12:39:05.289893 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29470928, win 8212, length 0
12:39:05.289954 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29470928:29471104, ack 256305, win 1561, length 176
12:39:05.290069 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29471104:29471280, ack 256305, win 1561, length 176
12:39:05.290136 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29471280, win 8211, length 0
12:39:05.290236 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29471280:29471568, ack 256305, win 1561, length 288
12:39:05.290345 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29471568:29471856, ack 256305, win 1561, length 288
12:39:05.290414 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29471856, win 8208, length 0
12:39:05.290477 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29471856:29472032, ack 256305, win 1561, length 176
12:39:05.290496 IP 192.168.1.153.39989 > 192.168.1.1.53: 64545+ A? pull-rtmp-l1.tiktokcdn.com. (44)
12:39:05.290595 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29472032:29472208, ack 256305, win 1561, length 176
12:39:05.290660 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29472208, win 8207, length 0
12:39:05.290780 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29472208:29472368, ack 256305, win 1561, length 160
12:39:05.290943 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29472368:29472880, ack 256305, win 1561, length 512
12:39:05.291019 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29472880, win 8212, length 0
12:39:05.291084 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29472880:29473056, ack 256305, win 1561, length 176
12:39:05.291201 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29473056:29473232, ack 256305, win 1561, length 176
12:39:05.291269 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29473232, win 8211, length 0
12:39:05.291364 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29473232:29473520, ack 256305, win 1561, length 288
12:39:05.291475 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29473520:29473808, ack 256305, win 1561, length 288
12:39:05.291543 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29473808, win 8208, length 0
12:39:05.291605 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29473808:29473984, ack 256305, win 1561, length 176
12:39:05.291717 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29473984:29474160, ack 256305, win 1561, length 176
12:39:05.291784 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29474160, win 8207, length 0
12:39:05.291879 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29474160:29474448, ack 256305, win 1561, length 288
12:39:05.291989 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29474448:29474736, ack 256305, win 1561, length 288
12:39:05.292057 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29474736, win 8212, length 0
12:39:05.292120 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29474736:29474912, ack 256305, win 1561, length 176
12:39:05.292232 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29474912:29475088, ack 256305, win 1561, length 176
12:39:05.292299 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29475088, win 8211, length 0
12:39:05.292391 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29475088:29475376, ack 256305, win 1561, length 288
12:39:05.292502 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29475376:29475664, ack 256305, win 1561, length 288
12:39:05.292570 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29475664, win 8208, length 0
12:39:05.292633 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29475664:29475840, ack 256305, win 1561, length 176
12:39:05.292744 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29475840:29476016, ack 256305, win 1561, length 176
12:39:05.292811 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29476016, win 8207, length 0
12:39:05.292907 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29476016:29476304, ack 256305, win 1561, length 288
12:39:05.293016 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29476304:29476592, ack 256305, win 1561, length 288
12:39:05.293085 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29476592, win 8212, length 0
12:39:05.293147 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29476592:29476768, ack 256305, win 1561, length 176
12:39:05.293259 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29476768:29476944, ack 256305, win 1561, length 176
12:39:05.293326 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29476944, win 8211, length 0
12:39:05.293420 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29476944:29477232, ack 256305, win 1561, length 288
12:39:05.293530 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29477232:29477520, ack 256305, win 1561, length 288
12:39:05.293598 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29477520, win 8208, length 0
12:39:05.293660 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29477520:29477696, ack 256305, win 1561, length 176
12:39:05.293773 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29477696:29477872, ack 256305, win 1561, length 176
12:39:05.293839 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29477872, win 8207, length 0
12:39:05.293936 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29477872:29478160, ack 256305, win 1561, length 288
12:39:05.294045 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29478160:29478448, ack 256305, win 1561, length 288
12:39:05.294113 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29478448, win 8212, length 0
12:39:05.294176 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29478448:29478624, ack 256305, win 1561, length 176
12:39:05.294289 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29478624:29478800, ack 256305, win 1561, length 176
12:39:05.294355 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29478800, win 8211, length 0
12:39:05.294449 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29478800:29479088, ack 256305, win 1561, length 288
12:39:05.294557 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29479088:29479376, ack 256305, win 1561, length 288
12:39:05.294626 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29479376, win 8208, length 0
12:39:05.294688 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29479376:29479552, ack 256305, win 1561, length 176
12:39:05.294799 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29479552:29479728, ack 256305, win 1561, length 176
12:39:05.294866 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29479728, win 8207, length 0
12:39:05.294959 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29479728:29480016, ack 256305, win 1561, length 288
12:39:05.295068 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29480016:29480304, ack 256305, win 1561, length 288
12:39:05.295136 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29480304, win 8212, length 0
12:39:05.295200 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29480304:29480480, ack 256305, win 1561, length 176
12:39:05.295314 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29480480:29480656, ack 256305, win 1561, length 176
12:39:05.295382 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29480656, win 8211, length 0
12:39:05.295474 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29480656:29480944, ack 256305, win 1561, length 288
12:39:05.295585 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29480944:29481232, ack 256305, win 1561, length 288
12:39:05.295652 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29481232, win 8208, length 0
12:39:05.295717 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29481232:29481408, ack 256305, win 1561, length 176
12:39:05.295832 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29481408:29481584, ack 256305, win 1561, length 176
12:39:05.295896 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29481584, win 8207, length 0
12:39:05.295993 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29481584:29481872, ack 256305, win 1561, length 288
12:39:05.296103 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29481872:29482160, ack 256305, win 1561, length 288
12:39:05.296170 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29482160, win 8212, length 0
12:39:05.296234 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29482160:29482336, ack 256305, win 1561, length 176
12:39:05.296345 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29482336:29482512, ack 256305, win 1561, length 176
12:39:05.296411 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29482512, win 8211, length 0
12:39:05.296508 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29482512:29482800, ack 256305, win 1561, length 288
12:39:05.296617 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29482800:29483088, ack 256305, win 1561, length 288
12:39:05.296684 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29483088, win 8208, length 0
12:39:05.296748 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29483088:29483264, ack 256305, win 1561, length 176
12:39:05.296861 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29483264:29483440, ack 256305, win 1561, length 176
12:39:05.296927 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29483440, win 8207, length 0
12:39:05.297024 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29483440:29483728, ack 256305, win 1561, length 288
12:39:05.297134 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29483728:29484016, ack 256305, win 1561, length 288
12:39:05.297201 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29484016, win 8212, length 0
12:39:05.297265 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29484016:29484192, ack 256305, win 1561, length 176
12:39:05.297376 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29484192:29484368, ack 256305, win 1561, length 176
12:39:05.297441 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29484368, win 8211, length 0
12:39:05.297537 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29484368:29484656, ack 256305, win 1561, length 288
12:39:05.297647 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29484656:29484944, ack 256305, win 1561, length 288
12:39:05.297714 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29484944, win 8208, length 0
12:39:05.297779 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29484944:29485120, ack 256305, win 1561, length 176
12:39:05.297891 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29485120:29485296, ack 256305, win 1561, length 176
12:39:05.297898 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 256305:256465, ack 29485120, win 8208, length 160
12:39:05.298060 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29485296:29485584, ack 256465, win 1561, length 288
12:39:05.298129 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29485584, win 8212, length 0
12:39:05.298296 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29485584:29485936, ack 256465, win 1561, length 352
12:39:05.298406 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29485936:29486224, ack 256465, win 1561, length 288
12:39:05.298472 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29486224, win 8210, length 0
12:39:05.298538 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29486224:29486400, ack 256465, win 1561, length 176
12:39:05.298686 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29486400:29486576, ack 256465, win 1561, length 176
12:39:05.298755 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29486576, win 8208, length 0
12:39:05.298888 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29486576:29486864, ack 256465, win 1561, length 288
12:39:05.299002 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29486864:29487152, ack 256465, win 1561, length 288
12:39:05.299069 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29487152, win 8212, length 0
12:39:05.299137 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29487152:29487328, ack 256465, win 1561, length 176
12:39:05.299250 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29487328:29487504, ack 256465, win 1561, length 176
12:39:05.299316 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29487504, win 8211, length 0
12:39:05.299411 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29487504:29487792, ack 256465, win 1561, length 288
12:39:05.299521 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29487792:29488080, ack 256465, win 1561, length 288
12:39:05.299592 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29488080, win 8208, length 0
12:39:05.299652 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29488080:29488256, ack 256465, win 1561, length 176
12:39:05.299765 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29488256:29488432, ack 256465, win 1561, length 176
12:39:05.299835 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29488432, win 8207, length 0
12:39:05.300029 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29488432:29488720, ack 256465, win 1561, length 288
12:39:05.300043 IP 192.168.1.1.53 > 192.168.1.153.39989: 64545 2/0/0 CNAME pull-rtmp-l1.tiktokcdn.com.wsdvs.com., A 163.171.129.87 (107)
12:39:05.300152 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29488720:29489008, ack 256465, win 1561, length 288
12:39:05.300222 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29489008, win 8212, length 0
12:39:05.300393 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29489008:29489184, ack 256465, win 1561, length 176
12:39:05.300524 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29489184:29489600, ack 256465, win 1561, length 416
12:39:05.300599 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29489600, win 8210, length 0
12:39:05.300660 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29489600:29489776, ack 256465, win 1561, length 176
12:39:05.300776 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29489776:29489952, ack 256465, win 1561, length 176
12:39:05.300845 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29489952, win 8208, length 0
12:39:05.300935 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29489952:29490240, ack 256465, win 1561, length 288
12:39:05.301037 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29490240:29490416, ack 256465, win 1561, length 176
12:39:05.301108 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29490416, win 8207, length 0
12:39:05.301197 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29490416:29490704, ack 256465, win 1561, length 288
12:39:05.301299 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29490704:29490880, ack 256465, win 1561, length 176
12:39:05.301368 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29490880, win 8212, length 0
12:39:05.301454 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29490880:29491168, ack 256465, win 1561, length 288
12:39:05.301559 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29491168:29491344, ack 256465, win 1561, length 176
12:39:05.301630 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29491344, win 8210, length 0
12:39:05.301722 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29491344:29491632, ack 256465, win 1561, length 288
12:39:05.301824 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29491632:29491808, ack 256465, win 1561, length 176
12:39:05.301894 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29491808, win 8208, length 0
12:39:05.301981 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29491808:29492096, ack 256465, win 1561, length 288
12:39:05.302085 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29492096:29492272, ack 256465, win 1561, length 176
12:39:05.302154 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29492272, win 8207, length 0
12:39:05.302260 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29492272:29492560, ack 256465, win 1561, length 288
12:39:05.302370 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29492560:29492848, ack 256465, win 1561, length 288
12:39:05.302442 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29492848, win 8212, length 0
12:39:05.302502 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29492848:29493024, ack 256465, win 1561, length 176
12:39:05.302615 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29493024:29493200, ack 256465, win 1561, length 176
12:39:05.302685 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29493200, win 8211, length 0
12:39:05.302776 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29493200:29493488, ack 256465, win 1561, length 288
12:39:05.302886 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29493488:29493776, ack 256465, win 1561, length 288
12:39:05.302958 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29493776, win 8208, length 0
12:39:05.302968 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 256465:256625, ack 29493776, win 8208, length 160
12:39:05.303030 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29493776:29493952, ack 256465, win 1561, length 176
12:39:05.303157 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29493952:29494128, ack 256625, win 1561, length 176
12:39:05.303206 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29494128, win 8207, length 0
12:39:05.303402 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29494128:29494592, ack 256625, win 1561, length 464
12:39:05.303510 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29494592:29494880, ack 256625, win 1561, length 288
12:39:05.303582 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29494880, win 8212, length 0
12:39:05.303641 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29494880:29495056, ack 256625, win 1561, length 176
12:39:05.303757 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29495056:29495232, ack 256625, win 1561, length 176
12:39:05.303826 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29495232, win 8211, length 0
12:39:05.303919 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29495232:29495520, ack 256625, win 1561, length 288
12:39:05.304020 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29495520:29495696, ack 256625, win 1561, length 176
12:39:05.304090 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29495696, win 8209, length 0
12:39:05.304177 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29495696:29495984, ack 256625, win 1561, length 288
12:39:05.304279 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29495984:29496160, ack 256625, win 1561, length 176
12:39:05.304348 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29496160, win 8207, length 0
12:39:05.304435 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29496160:29496448, ack 256625, win 1561, length 288
12:39:05.304537 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29496448:29496624, ack 256625, win 1561, length 176
12:39:05.304607 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29496624, win 8212, length 0
12:39:05.304696 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29496624:29496912, ack 256625, win 1561, length 288
12:39:05.304796 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29496912:29497088, ack 256625, win 1561, length 176
12:39:05.304865 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29497088, win 8210, length 0
12:39:05.304952 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29497088:29497376, ack 256625, win 1561, length 288
12:39:05.305059 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 138
12:39:05.305061 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29497376:29497552, ack 256625, win 1561, length 176
12:39:05.305132 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29497552, win 8208, length 0
12:39:05.305233 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29497552:29497840, ack 256625, win 1561, length 288
12:39:05.305354 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29497840:29498208, ack 256625, win 1561, length 368
12:39:05.305428 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29498208, win 8212, length 0
12:39:05.305486 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29498208:29498384, ack 256625, win 1561, length 176
12:39:05.305602 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29498384:29498560, ack 256625, win 1561, length 176
12:39:05.305671 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29498560, win 8211, length 0
12:39:05.305760 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29498560:29498848, ack 256625, win 1561, length 288
12:39:05.305861 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29498848:29499024, ack 256625, win 1561, length 176
12:39:05.305930 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29499024, win 8209, length 0
12:39:05.306020 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29499024:29499312, ack 256625, win 1561, length 288
12:39:05.306123 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29499312:29499488, ack 256625, win 1561, length 176
12:39:05.306194 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29499488, win 8207, length 0
12:39:05.306284 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29499488:29499776, ack 256625, win 1561, length 288
12:39:05.306393 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29499776:29500064, ack 256625, win 1561, length 288
12:39:05.306466 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29500064, win 8212, length 0
12:39:05.306523 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29500064:29500240, ack 256625, win 1561, length 176
12:39:05.306638 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29500240:29500416, ack 256625, win 1561, length 176
12:39:05.306709 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29500416, win 8211, length 0
12:39:05.306801 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29500416:29500704, ack 256625, win 1561, length 288
12:39:05.306912 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29500704:29500992, ack 256625, win 1561, length 288
12:39:05.306984 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29500992, win 8208, length 0
12:39:05.307044 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29500992:29501168, ack 256625, win 1561, length 176
12:39:05.307157 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29501168:29501344, ack 256625, win 1561, length 176
12:39:05.307227 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29501344, win 8207, length 0
12:39:05.307319 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29501344:29501632, ack 256625, win 1561, length 288
12:39:05.307429 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29501632:29501920, ack 256625, win 1561, length 288
12:39:05.307500 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29501920, win 8212, length 0
12:39:05.307560 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29501920:29502096, ack 256625, win 1561, length 176
12:39:05.307675 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29502096:29502272, ack 256625, win 1561, length 176
12:39:05.307745 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29502272, win 8211, length 0
12:39:05.307843 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29502272:29502560, ack 256625, win 1561, length 288
12:39:05.307953 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29502560:29502848, ack 256625, win 1561, length 288
12:39:05.308025 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29502848, win 8208, length 0
12:39:05.308085 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29502848:29503024, ack 256625, win 1561, length 176
12:39:05.308199 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29503024:29503200, ack 256625, win 1561, length 176
12:39:05.308269 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29503200, win 8207, length 0
12:39:05.308362 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29503200:29503488, ack 256625, win 1561, length 288
12:39:05.308471 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29503488:29503776, ack 256625, win 1561, length 288
12:39:05.308543 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29503776, win 8212, length 0
12:39:05.308625 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29503776:29503952, ack 256625, win 1561, length 176
12:39:05.308772 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29503952:29504128, ack 256625, win 1561, length 176
12:39:05.308844 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29504128, win 8211, length 0
12:39:05.308938 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29504128:29504416, ack 256625, win 1561, length 288
12:39:05.309042 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29504416:29504592, ack 256625, win 1561, length 176
12:39:05.309111 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29504592, win 8209, length 0
12:39:05.309202 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29504592:29504880, ack 256625, win 1561, length 288
12:39:05.309303 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29504880:29505056, ack 256625, win 1561, length 176
12:39:05.309373 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29505056, win 8207, length 0
12:39:05.309460 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29505056:29505344, ack 256625, win 1561, length 288
12:39:05.309561 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29505344:29505520, ack 256625, win 1561, length 176
12:39:05.309631 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29505520, win 8212, length 0
12:39:05.309717 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29505520:29505808, ack 256625, win 1561, length 288
12:39:05.309819 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29505808:29505984, ack 256625, win 1561, length 176
12:39:05.309888 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29505984, win 8210, length 0
12:39:05.309978 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29505984:29506272, ack 256625, win 1561, length 288
12:39:05.310079 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29506272:29506448, ack 256625, win 1561, length 176
12:39:05.310148 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29506448, win 8208, length 0
12:39:05.310238 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29506448:29506736, ack 256625, win 1561, length 288
12:39:05.310340 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29506736:29506912, ack 256625, win 1561, length 176
12:39:05.310410 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29506912, win 8207, length 0
12:39:05.310498 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29506912:29507200, ack 256625, win 1561, length 288
12:39:05.310600 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29507200:29507376, ack 256625, win 1561, length 176
12:39:05.310670 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29507376, win 8212, length 0
12:39:05.310763 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29507376:29507664, ack 256625, win 1561, length 288
12:39:05.310867 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29507664:29507840, ack 256625, win 1561, length 176
12:39:05.310936 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29507840, win 8210, length 0
12:39:05.310990 IP 192.168.1.153.43680 > 192.168.1.1.53: 48011+ A? pull-rtmp-l11.tiktokcdn.com. (45)
12:39:05.311366 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29507840:29508128, ack 256625, win 1561, length 288
12:39:05.311510 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29508128:29508416, ack 256625, win 1561, length 288
12:39:05.311581 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29508416, win 8208, length 0
12:39:05.311681 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29508416:29508704, ack 256625, win 1561, length 288
12:39:05.311785 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29508704:29508880, ack 256625, win 1561, length 176
12:39:05.311854 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29508880, win 8212, length 0
12:39:05.311942 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29508880:29509168, ack 256625, win 1561, length 288
12:39:05.312043 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29509168:29509344, ack 256625, win 1561, length 176
12:39:05.312112 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29509344, win 8210, length 0
12:39:05.312200 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29509344:29509632, ack 256625, win 1561, length 288
12:39:05.312301 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29509632:29509808, ack 256625, win 1561, length 176
12:39:05.312376 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29509808, win 8208, length 0
12:39:05.312444 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29509808:29510096, ack 256625, win 1561, length 288
12:39:05.312560 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29510096:29510272, ack 256625, win 1561, length 176
12:39:05.312631 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29510272, win 8207, length 0
12:39:05.312723 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29510272:29510560, ack 256625, win 1561, length 288
12:39:05.312824 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29510560:29510736, ack 256625, win 1561, length 176
12:39:05.312893 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29510736, win 8212, length 0
12:39:05.312984 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29510736:29511024, ack 256625, win 1561, length 288
12:39:05.313086 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29511024:29511200, ack 256625, win 1561, length 176
12:39:05.313155 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29511200, win 8210, length 0
12:39:05.313245 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29511200:29511488, ack 256625, win 1561, length 288
12:39:05.313346 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29511488:29511664, ack 256625, win 1561, length 176
12:39:05.313416 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29511664, win 8208, length 0
12:39:05.313503 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29511664:29511952, ack 256625, win 1561, length 288
12:39:05.313604 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29511952:29512128, ack 256625, win 1561, length 176
12:39:05.313674 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29512128, win 8207, length 0
12:39:05.313762 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29512128:29512416, ack 256625, win 1561, length 288
12:39:05.313862 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29512416:29512592, ack 256625, win 1561, length 176
12:39:05.313932 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29512592, win 8212, length 0
12:39:05.314014 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29512592:29512880, ack 256625, win 1561, length 288
12:39:05.314115 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29512880:29513056, ack 256625, win 1561, length 176
12:39:05.314185 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29513056, win 8210, length 0
12:39:05.314269 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29513056:29513344, ack 256625, win 1561, length 288
12:39:05.314369 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29513344:29513520, ack 256625, win 1561, length 176
12:39:05.314439 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29513520, win 8208, length 0
12:39:05.314525 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29513520:29513808, ack 256625, win 1561, length 288
12:39:05.314626 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29513808:29513984, ack 256625, win 1561, length 176
12:39:05.314695 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29513984, win 8207, length 0
12:39:05.314784 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29513984:29514272, ack 256625, win 1561, length 288
12:39:05.314885 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29514272:29514448, ack 256625, win 1561, length 176
12:39:05.314955 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29514448, win 8212, length 0
12:39:05.315042 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29514448:29514736, ack 256625, win 1561, length 288
12:39:05.315144 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29514736:29514912, ack 256625, win 1561, length 176
12:39:05.315214 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29514912, win 8210, length 0
12:39:05.315302 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29514912:29515200, ack 256625, win 1561, length 288
12:39:05.315402 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29515200:29515376, ack 256625, win 1561, length 176
12:39:05.315471 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29515376, win 8208, length 0
12:39:05.315517 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 256625:256785, ack 29515376, win 8208, length 160
12:39:05.315579 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29515376:29515664, ack 256785, win 1561, length 288
12:39:05.315690 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29515664:29515840, ack 256785, win 1561, length 176
12:39:05.315760 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29515840, win 8207, length 0
12:39:05.315936 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29515840:29516304, ack 256785, win 1561, length 464
12:39:05.316046 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29516304:29516592, ack 256785, win 1561, length 288
12:39:05.316118 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29516592, win 8212, length 0
12:39:05.316177 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29516592:29516768, ack 256785, win 1561, length 176
12:39:05.316290 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29516768:29516944, ack 256785, win 1561, length 176
12:39:05.316359 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29516944, win 8211, length 0
12:39:05.316449 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29516944:29517232, ack 256785, win 1561, length 288
12:39:05.316572 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29517232:29517520, ack 256785, win 1561, length 288
12:39:05.316644 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29517520, win 8208, length 0
12:39:05.316704 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29517520:29517696, ack 256785, win 1561, length 176
12:39:05.316816 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29517696:29517872, ack 256785, win 1561, length 176
12:39:05.316885 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29517872, win 8207, length 0
12:39:05.316976 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29517872:29518160, ack 256785, win 1561, length 288
12:39:05.317086 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29518160:29518448, ack 256785, win 1561, length 288
12:39:05.317157 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29518448, win 8212, length 0
12:39:05.317217 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29518448:29518624, ack 256785, win 1561, length 176
12:39:05.317330 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29518624:29518800, ack 256785, win 1561, length 176
12:39:05.317399 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29518800, win 8211, length 0
12:39:05.317490 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29518800:29519088, ack 256785, win 1561, length 288
12:39:05.317591 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29519088:29519264, ack 256785, win 1561, length 176
12:39:05.317660 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29519264, win 8209, length 0
12:39:05.317747 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29519264:29519552, ack 256785, win 1561, length 288
12:39:05.317847 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29519552:29519728, ack 256785, win 1561, length 176
12:39:05.317917 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29519728, win 8207, length 0
12:39:05.318002 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29519728:29520016, ack 256785, win 1561, length 288
12:39:05.318104 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29520016:29520192, ack 256785, win 1561, length 176
12:39:05.318174 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29520192, win 8212, length 0
12:39:05.318262 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29520192:29520480, ack 256785, win 1561, length 288
12:39:05.318363 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29520480:29520656, ack 256785, win 1561, length 176
12:39:05.318432 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29520656, win 8210, length 0
12:39:05.318523 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29520656:29520944, ack 256785, win 1561, length 288
12:39:05.318664 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29520944:29521232, ack 256785, win 1561, length 288
12:39:05.318737 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29521232, win 8208, length 0
12:39:05.318863 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29521232:29521408, ack 256785, win 1561, length 176
12:39:05.318977 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29521408:29521696, ack 256785, win 1561, length 288
12:39:05.319049 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29521696, win 8212, length 0
12:39:05.319109 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29521696:29521872, ack 256785, win 1561, length 176
12:39:05.319224 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29521872:29522048, ack 256785, win 1561, length 176
12:39:05.319294 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29522048, win 8211, length 0
12:39:05.319384 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29522048:29522336, ack 256785, win 1561, length 288
12:39:05.319486 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29522336:29522512, ack 256785, win 1561, length 176
12:39:05.319556 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29522512, win 8209, length 0
12:39:05.319647 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29522512:29522800, ack 256785, win 1561, length 288
12:39:05.319749 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29522800:29522976, ack 256785, win 1561, length 176
12:39:05.319819 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29522976, win 8207, length 0
12:39:05.319851 IP 52.112.14.106.3481 > 192.168.1.162.50048: UDP, length 153
12:39:05.319917 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29522976:29523264, ack 256785, win 1561, length 288
12:39:05.320039 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29523264:29523440, ack 256785, win 1561, length 176
12:39:05.320109 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29523440, win 8212, length 0
12:39:05.320201 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29523440:29523680, ack 256785, win 1561, length 240
12:39:05.320527 IP 192.168.1.1.53 > 192.168.1.153.43680: 48011 9/0/0 CNAME rtmp-l11.tiktokcdn.liveplay.myqcloud.com., CNAME all.hylivecdn.sched.ovscdns.net., A 87.245.210.90, A 87.245.210.91, A 87.245.210.92, A 87.245.210.93, A 87.245.210.94, A 87.245.210.95, A 87.245.210.96 (253)
12:39:05.320649 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29523680:29523984, ack 256785, win 1561, length 304
12:39:05.320720 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29523984, win 8210, length 0
12:39:05.320847 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29523984:29524272, ack 256785, win 1561, length 288
12:39:05.320988 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29524272:29524848, ack 256785, win 1561, length 576
12:39:05.321066 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29524848, win 8207, length 0
12:39:05.321121 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29524848:29525024, ack 256785, win 1561, length 176
12:39:05.321238 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29525024:29525200, ack 256785, win 1561, length 176
12:39:05.321308 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29525200, win 8212, length 0
12:39:05.321400 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29525200:29525488, ack 256785, win 1561, length 288
12:39:05.321510 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29525488:29525776, ack 256785, win 1561, length 288
12:39:05.321582 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29525776, win 8210, length 0
12:39:05.321640 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29525776:29525952, ack 256785, win 1561, length 176
12:39:05.321753 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29525952:29526128, ack 256785, win 1561, length 176
12:39:05.321823 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29526128, win 8208, length 0
12:39:05.321914 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29526128:29526416, ack 256785, win 1561, length 288
12:39:05.322025 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29526416:29526704, ack 256785, win 1561, length 288
12:39:05.322096 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29526704, win 8212, length 0
12:39:05.322156 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29526704:29526880, ack 256785, win 1561, length 176
12:39:05.322268 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29526880:29527056, ack 256785, win 1561, length 176
12:39:05.322337 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29527056, win 8211, length 0
12:39:05.322426 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29527056:29527344, ack 256785, win 1561, length 288
12:39:05.322526 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29527344:29527520, ack 256785, win 1561, length 176
12:39:05.322596 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29527520, win 8209, length 0
12:39:05.322684 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29527520:29527808, ack 256785, win 1561, length 288
12:39:05.322785 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29527808:29527984, ack 256785, win 1561, length 176
12:39:05.322855 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29527984, win 8207, length 0
12:39:05.322941 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29527984:29528272, ack 256785, win 1561, length 288
12:39:05.323041 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29528272:29528448, ack 256785, win 1561, length 176
12:39:05.323110 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29528448, win 8212, length 0
12:39:05.323200 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29528448:29528736, ack 256785, win 1561, length 288
12:39:05.323302 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29528736:29528912, ack 256785, win 1561, length 176
12:39:05.323369 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29528912, win 8210, length 0
12:39:05.323459 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29528912:29529200, ack 256785, win 1561, length 288
12:39:05.323569 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29529200:29529488, ack 256785, win 1561, length 288
12:39:05.323638 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29529488, win 8208, length 0
12:39:05.323702 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29529488:29529664, ack 256785, win 1561, length 176
12:39:05.323817 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29529664:29529840, ack 256785, win 1561, length 176
12:39:05.323883 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29529840, win 8207, length 0
12:39:05.323980 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29529840:29530128, ack 256785, win 1561, length 288
12:39:05.324091 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29530128:29530416, ack 256785, win 1561, length 288
12:39:05.324160 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29530416, win 8212, length 0
12:39:05.324222 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29530416:29530592, ack 256785, win 1561, length 176
12:39:05.324335 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29530592:29530768, ack 256785, win 1561, length 176
12:39:05.324401 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29530768, win 8211, length 0
12:39:05.324497 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29530768:29531056, ack 256785, win 1561, length 288
12:39:05.324605 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29531056:29531344, ack 256785, win 1561, length 288
12:39:05.324674 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29531344, win 8208, length 0
12:39:05.324737 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29531344:29531520, ack 256785, win 1561, length 176
12:39:05.324853 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29531520:29531696, ack 256785, win 1561, length 176
12:39:05.324920 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29531696, win 8207, length 0
12:39:05.325019 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29531696:29531984, ack 256785, win 1561, length 288
12:39:05.325129 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29531984:29532272, ack 256785, win 1561, length 288
12:39:05.325198 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29532272, win 8212, length 0
12:39:05.325258 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29532272:29532448, ack 256785, win 1561, length 176
12:39:05.325371 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29532448:29532624, ack 256785, win 1561, length 176
12:39:05.325438 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29532624, win 8211, length 0
12:39:05.325529 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29532624:29532912, ack 256785, win 1561, length 288
12:39:05.325629 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29532912:29533088, ack 256785, win 1561, length 176
12:39:05.325695 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29533088, win 8209, length 0
12:39:05.325786 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29533088:29533376, ack 256785, win 1561, length 288
12:39:05.325895 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29533376:29533664, ack 256785, win 1561, length 288
12:39:05.325964 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29533664, win 8207, length 0
12:39:05.326025 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29533664:29533840, ack 256785, win 1561, length 176
12:39:05.326137 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29533840:29534016, ack 256785, win 1561, length 176
12:39:05.326204 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29534016, win 8212, length 0
12:39:05.326300 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29534016:29534304, ack 256785, win 1561, length 288
12:39:05.326409 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29534304:29534592, ack 256785, win 1561, length 288
12:39:05.326478 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29534592, win 8210, length 0
12:39:05.326540 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29534592:29534768, ack 256785, win 1561, length 176
12:39:05.326651 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29534768:29534944, ack 256785, win 1561, length 176
12:39:05.326717 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29534944, win 8208, length 0
12:39:05.326811 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29534944:29535232, ack 256785, win 1561, length 288
12:39:05.326920 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29535232:29535520, ack 256785, win 1561, length 288
12:39:05.326988 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29535520, win 8212, length 0
12:39:05.327050 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29535520:29535696, ack 256785, win 1561, length 176
12:39:05.327163 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29535696:29535872, ack 256785, win 1561, length 176
12:39:05.327229 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29535872, win 8211, length 0
12:39:05.327326 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29535872:29536160, ack 256785, win 1561, length 288
12:39:05.327435 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29536160:29536448, ack 256785, win 1561, length 288
12:39:05.327504 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29536448, win 8208, length 0
12:39:05.327566 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29536448:29536624, ack 256785, win 1561, length 176
12:39:05.327646 IP 192.168.1.153.39848 > 192.168.1.1.53: 39697+ A? pull-hls-f5-ab.tiktokcdn.com. (46)
12:39:05.327677 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29536624:29536800, ack 256785, win 1561, length 176
12:39:05.327742 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29536800, win 8207, length 0
12:39:05.327867 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29536800:29537088, ack 256785, win 1561, length 288
12:39:05.328019 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29537088:29537472, ack 256785, win 1561, length 384
12:39:05.328090 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29537472, win 8212, length 0
12:39:05.328167 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29537472:29537648, ack 256785, win 1561, length 176
12:39:05.328286 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29537648:29537824, ack 256785, win 1561, length 176
12:39:05.328353 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29537824, win 8211, length 0
12:39:05.328450 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29537824:29538112, ack 256785, win 1561, length 288
12:39:05.328550 IP 52.112.14.106.3480 > 192.168.1.162.50032: UDP, length 78
12:39:05.328565 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29538112:29538400, ack 256785, win 1561, length 288
12:39:05.328601 IP 52.112.14.106.3480 > 192.168.1.162.50032: UDP, length 303
12:39:05.328629 IP 52.112.14.106.3480 > 192.168.1.162.50032: UDP, length 319
12:39:05.328650 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29538400, win 8208, length 0
12:39:05.328881 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29538400:29538656, ack 256785, win 1561, length 256
12:39:05.329007 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29538656:29538992, ack 256785, win 1561, length 336
12:39:05.329077 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29538992, win 8212, length 0
12:39:05.329170 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29538992:29539280, ack 256785, win 1561, length 288
12:39:05.329272 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29539280:29539456, ack 256785, win 1561, length 176
12:39:05.329336 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 134
12:39:05.329342 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29539456, win 8210, length 0
12:39:05.329441 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29539456:29539744, ack 256785, win 1561, length 288
12:39:05.329567 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29539744:29540112, ack 256785, win 1561, length 368
12:39:05.329636 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29540112, win 8208, length 0
12:39:05.329699 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29540112:29540288, ack 256785, win 1561, length 176
12:39:05.329815 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29540288:29540464, ack 256785, win 1561, length 176
12:39:05.329881 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29540464, win 8212, length 0
12:39:05.329980 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29540464:29540752, ack 256785, win 1561, length 288
12:39:05.330089 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29540752:29541040, ack 256785, win 1561, length 288
12:39:05.330155 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29541040, win 8210, length 0
12:39:05.330219 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29541040:29541216, ack 256785, win 1561, length 176
12:39:05.330332 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29541216:29541392, ack 256785, win 1561, length 176
12:39:05.330397 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29541392, win 8208, length 0
12:39:05.330496 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29541392:29541680, ack 256785, win 1561, length 288
12:39:05.330605 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29541680:29541968, ack 256785, win 1561, length 288
12:39:05.330673 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29541968, win 8212, length 0
12:39:05.330738 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29541968:29542144, ack 256785, win 1561, length 176
12:39:05.330854 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29542144:29542320, ack 256785, win 1561, length 176
12:39:05.330920 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29542320, win 8211, length 0
12:39:05.331020 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29542320:29542608, ack 256785, win 1561, length 288
12:39:05.331105 IP 192.168.1.152.63224 > 128.116.66.148.54817: UDP, length 46
12:39:05.331131 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29542608:29542896, ack 256785, win 1561, length 288
12:39:05.331194 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29542896, win 8208, length 0
12:39:05.331281 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29542896:29543072, ack 256785, win 1561, length 176
12:39:05.331421 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29543072:29543440, ack 256785, win 1561, length 368
12:39:05.331491 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29543440, win 8212, length 0
12:39:05.331620 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29543440:29543616, ack 256785, win 1561, length 176
12:39:05.331762 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29543616:29543904, ack 256785, win 1561, length 288
12:39:05.331832 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29543904, win 8210, length 0
12:39:05.331923 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 256785:256945, ack 29543904, win 8210, length 160
12:39:05.331999 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29543904:29544080, ack 256945, win 1561, length 176
12:39:05.332153 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29544080:29544368, ack 256945, win 1561, length 288
12:39:05.332221 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29544368, win 8208, length 0
12:39:05.332434 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29544368:29544720, ack 256945, win 1561, length 352
12:39:05.332572 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29544720:29545008, ack 256945, win 1561, length 288
12:39:05.332639 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29545008, win 8212, length 0
12:39:05.332776 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29545008:29545184, ack 256945, win 1561, length 176
12:39:05.332914 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29545184:29545472, ack 256945, win 1561, length 288
12:39:05.332984 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29545472, win 8210, length 0
12:39:05.333111 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29545472:29545648, ack 256945, win 1561, length 176
12:39:05.333249 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29545648:29545936, ack 256945, win 1561, length 288
12:39:05.333318 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29545936, win 8208, length 0
12:39:05.333443 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29545936:29546112, ack 256945, win 1561, length 176
12:39:05.333581 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29546112:29546400, ack 256945, win 1561, length 288
12:39:05.333653 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29546400, win 8207, length 0
12:39:05.333776 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 1047
12:39:05.333900 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29546400:29546576, ack 256945, win 1561, length 176
12:39:05.334052 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29546576:29546944, ack 256945, win 1561, length 368
12:39:05.334126 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29546944, win 8212, length 0
12:39:05.334257 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29546944:29547120, ack 256945, win 1561, length 176
12:39:05.334395 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29547120:29547408, ack 256945, win 1561, length 288
12:39:05.334467 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29547408, win 8210, length 0
12:39:05.334591 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29547408:29547584, ack 256945, win 1561, length 176
12:39:05.334727 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29547584:29547872, ack 256945, win 1561, length 288
12:39:05.334800 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29547872, win 8208, length 0
12:39:05.334925 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29547872:29548048, ack 256945, win 1561, length 176
12:39:05.335060 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29548048:29548336, ack 256945, win 1561, length 288
12:39:05.335132 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29548336, win 8207, length 0
12:39:05.335253 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29548336:29548512, ack 256945, win 1561, length 176
12:39:05.335389 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29548512:29548800, ack 256945, win 1561, length 288
12:39:05.335461 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29548800, win 8212, length 0
12:39:05.335590 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29548800:29548976, ack 256945, win 1561, length 176
12:39:05.335727 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29548976:29549264, ack 256945, win 1561, length 288
12:39:05.335798 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29549264, win 8210, length 0
12:39:05.335923 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29549264:29549440, ack 256945, win 1561, length 176
12:39:05.336057 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29549440:29549728, ack 256945, win 1561, length 288
12:39:05.336128 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29549728, win 8208, length 0
12:39:05.336254 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29549728:29549904, ack 256945, win 1561, length 176
12:39:05.336391 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29549904:29550192, ack 256945, win 1561, length 288
12:39:05.336463 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29550192, win 8207, length 0
12:39:05.336585 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29550192:29550368, ack 256945, win 1561, length 176
12:39:05.336722 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29550368:29550656, ack 256945, win 1561, length 288
12:39:05.336794 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29550656, win 8212, length 0
12:39:05.336939 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29550656:29550832, ack 256945, win 1561, length 176
12:39:05.337002 IP 192.168.1.1.53 > 192.168.1.153.39848: 39697 4/0/0 CNAME pull-hls-f5-ab.tiktokcdn.com.akamaized.net., CNAME a1831.z.akamai.net., A 173.222.210.32, A 173.222.210.65 (163)
12:39:05.337100 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29550832:29551120, ack 256945, win 1561, length 288
12:39:05.337169 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29551120, win 8210, length 0
12:39:05.337325 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29551120:29551296, ack 256945, win 1561, length 176
12:39:05.337486 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29551296:29551776, ack 256945, win 1561, length 480
12:39:05.337562 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29551776, win 8208, length 0
12:39:05.337687 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29551776:29551952, ack 256945, win 1561, length 176
12:39:05.337824 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29551952:29552240, ack 256945, win 1561, length 288
12:39:05.337896 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29552240, win 8212, length 0
12:39:05.338027 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29552240:29552416, ack 256945, win 1561, length 176
12:39:05.338166 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29552416:29552704, ack 256945, win 1561, length 288
12:39:05.338238 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29552704, win 8210, length 0
12:39:05.338368 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29552704:29552880, ack 256945, win 1561, length 176
12:39:05.338505 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29552880:29553168, ack 256945, win 1561, length 288
12:39:05.338594 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29553168, win 8208, length 0
12:39:05.338734 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29553168:29553344, ack 256945, win 1561, length 176
12:39:05.338878 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29553344:29553632, ack 256945, win 1561, length 288
12:39:05.338950 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29553632, win 8207, length 0
12:39:05.339076 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29553632:29553808, ack 256945, win 1561, length 176
12:39:05.339212 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29553808:29554096, ack 256945, win 1561, length 288
12:39:05.339284 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29554096, win 8212, length 0
12:39:05.339409 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29554096:29554272, ack 256945, win 1561, length 176
12:39:05.339546 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29554272:29554560, ack 256945, win 1561, length 288
12:39:05.339617 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29554560, win 8210, length 0
12:39:05.339740 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29554560:29554736, ack 256945, win 1561, length 176
12:39:05.339877 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29554736:29555024, ack 256945, win 1561, length 288
12:39:05.339949 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29555024, win 8208, length 0
12:39:05.340042 IP 192.168.1.172.51444 > 239.255.255.250.1900: UDP, length 394
12:39:05.340072 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29555024:29555200, ack 256945, win 1561, length 176
12:39:05.340551 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29555200:29555488, ack 256945, win 1561, length 288
12:39:05.340626 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29555488, win 8207, length 0
12:39:05.340784 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29555488:29555744, ack 256945, win 1561, length 256
12:39:05.340924 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29555744:29556032, ack 256945, win 1561, length 288
12:39:05.340996 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29556032, win 8212, length 0
12:39:05.341121 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29556032:29556208, ack 256945, win 1561, length 176
12:39:05.341161 IP 192.168.1.172.51444 > 239.255.255.250.1900: UDP, length 403
12:39:05.341195 IP 192.168.1.172.51444 > 239.255.255.250.1900: UDP, length 452
12:39:05.341225 IP 192.168.1.172.53684 > 239.255.255.250.1900: UDP, length 434
12:39:05.341651 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29556208:29556496, ack 256945, win 1561, length 288
12:39:05.341787 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29556496, win 8210, length 0
12:39:05.341920 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29556496:29556912, ack 256945, win 1561, length 416
12:39:05.342054 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29556912:29557088, ack 256945, win 1561, length 176
12:39:05.342125 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29557088, win 8208, length 0
12:39:05.342263 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29557088:29557376, ack 256945, win 1561, length 288
12:39:05.342399 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29557376:29557664, ack 256945, win 1561, length 288
12:39:05.342471 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29557664, win 8212, length 0
12:39:05.342595 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29557664:29557840, ack 256945, win 1561, length 176
12:39:05.342732 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29557840:29558128, ack 256945, win 1561, length 288
12:39:05.342750 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 256945:257105, ack 29557840, win 8211, length 160
12:39:05.342920 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29558128:29558304, ack 257105, win 1561, length 176
12:39:05.342990 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29558304, win 8210, length 0
12:39:05.343202 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29558304:29558656, ack 257105, win 1561, length 352
12:39:05.343340 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29558656:29558944, ack 257105, win 1561, length 288
12:39:05.343413 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29558944, win 8207, length 0
12:39:05.343539 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29558944:29559120, ack 257105, win 1561, length 176
12:39:05.343678 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29559120:29559408, ack 257105, win 1561, length 288
12:39:05.343749 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29559408, win 8212, length 0
12:39:05.343875 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29559408:29559584, ack 257105, win 1561, length 176
12:39:05.343991 IP 192.168.1.172.53713 > 239.255.255.250.1900: UDP, length 438
12:39:05.344013 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29559584:29559872, ack 257105, win 1561, length 288
12:39:05.343994 IP 192.168.1.172.58268 > 239.255.255.250.1900: UDP, length 456
12:39:05.344039 IP 192.168.1.172.34863 > 239.255.255.250.1900: UDP, length 442
12:39:05.344042 IP 192.168.1.172.43245 > 239.255.255.250.1900: UDP, length 438
12:39:05.344121 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29559872, win 8210, length 0
12:39:05.344542 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29559872:29560048, ack 257105, win 1561, length 176
12:39:05.344738 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29560048:29560656, ack 257105, win 1561, length 608
12:39:05.344823 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29560656, win 8207, length 0
12:39:05.344939 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29560656:29560832, ack 257105, win 1561, length 176
12:39:05.345079 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29560832:29561008, ack 257105, win 1561, length 176
12:39:05.345082 IP 192.168.1.152.63224 > 128.116.66.148.54817: UDP, length 7
12:39:05.345150 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29561008, win 8212, length 0
12:39:05.345095 IP 192.168.1.152.63224 > 128.116.66.148.54817: UDP, length 78
12:39:05.345242 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29561008:29561296, ack 257105, win 1561, length 288
12:39:05.345472 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29561296:29561552, ack 257105, win 1561, length 256
12:39:05.345552 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29561552, win 8210, length 0
12:39:05.345700 IP 52.112.14.106.3479 > 192.168.1.162.50006: UDP, length 137
12:39:05.345711 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29561552:29561920, ack 257105, win 1561, length 368
12:39:05.345869 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29561920:29562208, ack 257105, win 1561, length 288
12:39:05.345941 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29562208, win 8207, length 0
12:39:05.346075 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29562208:29562464, ack 257105, win 1561, length 256
12:39:05.346214 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29562464:29562752, ack 257105, win 1561, length 288
12:39:05.346287 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29562752, win 8212, length 0
12:39:05.346414 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29562752:29562928, ack 257105, win 1561, length 176
12:39:05.346552 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29562928:29563216, ack 257105, win 1561, length 288
12:39:05.346624 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29563216, win 8210, length 0
12:39:05.346749 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29563216:29563392, ack 257105, win 1561, length 176
12:39:05.346885 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29563392:29563680, ack 257105, win 1561, length 288
12:39:05.346957 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29563680, win 8208, length 0
12:39:05.347084 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29563680:29563856, ack 257105, win 1561, length 176
12:39:05.347222 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29563856:29564144, ack 257105, win 1561, length 288
12:39:05.347294 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29564144, win 8207, length 0
12:39:05.347422 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29564144:29564320, ack 257105, win 1561, length 176
12:39:05.347558 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29564320:29564608, ack 257105, win 1561, length 288
12:39:05.347630 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29564608, win 8212, length 0
12:39:05.347640 IP 192.168.1.153.42082 > 192.168.1.1.53: 37901+ A? pull-flv-l1.tiktokcdn.com. (43)
12:39:05.347825 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29564608:29564784, ack 257105, win 1561, length 176
12:39:05.347976 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29564784:29565168, ack 257105, win 1561, length 384
12:39:05.348054 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29565168, win 8210, length 0
12:39:05.348137 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29565168:29565344, ack 257105, win 1561, length 176
12:39:05.348260 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29565344:29565520, ack 257105, win 1561, length 176
12:39:05.348330 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29565520, win 8208, length 0
12:39:05.348422 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29565520:29565808, ack 257105, win 1561, length 288
12:39:05.348523 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29565808:29565984, ack 257105, win 1561, length 176
12:39:05.348598 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29565984, win 8207, length 0
12:39:05.348725 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29565984:29566272, ack 257105, win 1561, length 288
12:39:05.348834 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29566272:29566448, ack 257105, win 1561, length 176
12:39:05.348904 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29566448, win 8212, length 0
12:39:05.348996 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29566448:29566736, ack 257105, win 1561, length 288
12:39:05.349107 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29566736:29567024, ack 257105, win 1561, length 288
12:39:05.349178 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29567024, win 8210, length 0
12:39:05.349236 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29567024:29567200, ack 257105, win 1561, length 176
12:39:05.349352 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29567200:29567376, ack 257105, win 1561, length 176
12:39:05.349422 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29567376, win 8208, length 0
12:39:05.349510 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29567376:29567664, ack 257105, win 1561, length 288
12:39:05.349611 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29567664:29567840, ack 257105, win 1561, length 176
12:39:05.349681 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29567840, win 8207, length 0
12:39:05.349769 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29567840:29568128, ack 257105, win 1561, length 288
12:39:05.349870 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29568128:29568304, ack 257105, win 1561, length 176
12:39:05.349940 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29568304, win 8212, length 0
12:39:05.350026 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29568304:29568592, ack 257105, win 1561, length 288
12:39:05.350124 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 55
12:39:05.350243 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29568592:29568768, ack 257105, win 1561, length 176
12:39:05.350313 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29568768, win 8210, length 0
12:39:05.350425 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29568768:29569136, ack 257105, win 1561, length 368
12:39:05.350535 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29569136:29569424, ack 257105, win 1561, length 288
12:39:05.350608 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29569424, win 8208, length 0
12:39:05.350667 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29569424:29569600, ack 257105, win 1561, length 176
12:39:05.350783 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29569600:29569776, ack 257105, win 1561, length 176
12:39:05.350855 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29569776, win 8212, length 0
12:39:05.350958 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29569776:29570064, ack 257105, win 1561, length 288
12:39:05.351067 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29570064:29570352, ack 257105, win 1561, length 288
12:39:05.351139 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29570352, win 8210, length 0
12:39:05.351197 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29570352:29570528, ack 257105, win 1561, length 176
12:39:05.351311 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29570528:29570704, ack 257105, win 1561, length 176
12:39:05.351382 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29570704, win 8208, length 0
12:39:05.351472 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29570704:29570992, ack 257105, win 1561, length 288
12:39:05.351572 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29570992:29571168, ack 257105, win 1561, length 176
12:39:05.351642 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29571168, win 8207, length 0
12:39:05.351732 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29571168:29571456, ack 257105, win 1561, length 288
12:39:05.351833 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29571456:29571632, ack 257105, win 1561, length 176
12:39:05.351903 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29571632, win 8212, length 0
12:39:05.351992 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29571632:29571920, ack 257105, win 1561, length 288
12:39:05.352093 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29571920:29572096, ack 257105, win 1561, length 176
12:39:05.352163 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29572096, win 8210, length 0
12:39:05.352254 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29572096:29572384, ack 257105, win 1561, length 288
12:39:05.352356 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29572384:29572560, ack 257105, win 1561, length 176
12:39:05.352426 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29572560, win 8208, length 0
12:39:05.352516 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29572560:29572848, ack 257105, win 1561, length 288
12:39:05.352617 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29572848:29573024, ack 257105, win 1561, length 176
12:39:05.352686 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29573024, win 8207, length 0
12:39:05.352771 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29573024:29573312, ack 257105, win 1561, length 288
12:39:05.352872 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29573312:29573488, ack 257105, win 1561, length 176
12:39:05.352941 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29573488, win 8212, length 0
12:39:05.353031 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29573488:29573776, ack 257105, win 1561, length 288
12:39:05.353132 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29573776:29573952, ack 257105, win 1561, length 176
12:39:05.353201 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29573952, win 8210, length 0
12:39:05.353288 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29573952:29574240, ack 257105, win 1561, length 288
12:39:05.353389 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29574240:29574416, ack 257105, win 1561, length 176
12:39:05.353459 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29574416, win 8208, length 0
12:39:05.353541 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29574416:29574704, ack 257105, win 1561, length 288
12:39:05.353644 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29574704:29574880, ack 257105, win 1561, length 176
12:39:05.353713 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29574880, win 8207, length 0
12:39:05.353800 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29574880:29575168, ack 257105, win 1561, length 288
12:39:05.353902 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29575168:29575344, ack 257105, win 1561, length 176
12:39:05.353971 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29575344, win 8212, length 0
12:39:05.354059 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29575344:29575632, ack 257105, win 1561, length 288
12:39:05.354161 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29575632:29575808, ack 257105, win 1561, length 176
12:39:05.354230 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29575808, win 8210, length 0
12:39:05.354320 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29575808:29576096, ack 257105, win 1561, length 288
12:39:05.354422 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29576096:29576272, ack 257105, win 1561, length 176
12:39:05.354492 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29576272, win 8208, length 0
12:39:05.354580 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29576272:29576560, ack 257105, win 1561, length 288
12:39:05.354680 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29576560:29576736, ack 257105, win 1561, length 176
12:39:05.354750 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29576736, win 8207, length 0
12:39:05.354837 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29576736:29577024, ack 257105, win 1561, length 288
12:39:05.354938 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29577024:29577200, ack 257105, win 1561, length 176
12:39:05.355009 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29577200, win 8212, length 0
12:39:05.355090 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29577200:29577488, ack 257105, win 1561, length 288
12:39:05.355195 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29577488:29577664, ack 257105, win 1561, length 176
12:39:05.355262 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29577664, win 8210, length 0
12:39:05.355354 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29577664:29577952, ack 257105, win 1561, length 288
12:39:05.355465 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29577952:29578240, ack 257105, win 1561, length 288
12:39:05.355534 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29578240, win 8208, length 0
12:39:05.355595 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29578240:29578416, ack 257105, win 1561, length 176
12:39:05.355708 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29578416:29578592, ack 257105, win 1561, length 176
12:39:05.355774 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29578592, win 8207, length 0
12:39:05.355870 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29578592:29578880, ack 257105, win 1561, length 288
12:39:05.355979 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29578880:29579168, ack 257105, win 1561, length 288
12:39:05.356048 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29579168, win 8212, length 0
12:39:05.356109 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29579168:29579344, ack 257105, win 1561, length 176
12:39:05.356224 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29579344:29579520, ack 257105, win 1561, length 176
12:39:05.356290 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29579520, win 8211, length 0
12:39:05.356384 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29579520:29579808, ack 257105, win 1561, length 288
12:39:05.356494 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29579808:29580096, ack 257105, win 1561, length 288
12:39:05.356562 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29580096, win 8208, length 0
12:39:05.356625 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29580096:29580272, ack 257105, win 1561, length 176
12:39:05.356737 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29580272:29580448, ack 257105, win 1561, length 176
12:39:05.356805 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29580448, win 8207, length 0
12:39:05.356898 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29580448:29580736, ack 257105, win 1561, length 288
12:39:05.357007 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29580736:29581024, ack 257105, win 1561, length 288
12:39:05.357075 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29581024, win 8212, length 0
12:39:05.357138 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29581024:29581200, ack 257105, win 1561, length 176
12:39:05.357275 IP 192.168.1.1.53 > 192.168.1.153.42082: 37901 8/0/0 CNAME pull-flv-l1.tiktokcdn.com.wsdvs.com., A 163.171.130.138, A 163.171.129.137, A 163.171.130.133, A 163.171.130.134, A 163.171.130.135, A 163.171.130.136, A 163.171.130.137 (201)
12:39:05.357533 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29581200:29581376, ack 257105, win 1561, length 176
12:39:05.357600 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29581376, win 8211, length 0
12:39:05.357718 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29581376:29581664, ack 257105, win 1561, length 288
12:39:05.357857 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29581664:29582208, ack 257105, win 1561, length 544
12:39:05.357932 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29582208, win 8207, length 0
12:39:05.357992 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29582208:29582384, ack 257105, win 1561, length 176
12:39:05.358108 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29582384:29582560, ack 257105, win 1561, length 176
12:39:05.358233 IP 128.116.66.148.54817 > 192.168.1.152.63224: UDP, length 13
12:39:05.358181 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29582560, win 8212, length 0
12:39:05.358542 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29582560:29582848, ack 257105, win 1561, length 288
12:39:05.358700 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29582848:29583216, ack 257105, win 1561, length 368
12:39:05.358772 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29583216, win 8209, length 0
12:39:05.358844 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29583216:29583392, ack 257105, win 1561, length 176
12:39:05.358962 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29583392:29583568, ack 257105, win 1561, length 176
12:39:05.359029 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29583568, win 8208, length 0
12:39:05.359126 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29583568:29583856, ack 257105, win 1561, length 288
12:39:05.359237 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29583856:29584144, ack 257105, win 1561, length 288
12:39:05.359306 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29584144, win 8212, length 0
12:39:05.359368 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29584144:29584320, ack 257105, win 1561, length 176
12:39:05.359481 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29584320:29584496, ack 257105, win 1561, length 176
12:39:05.359547 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29584496, win 8211, length 0
12:39:05.359644 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29584496:29584784, ack 257105, win 1561, length 288
12:39:05.359753 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29584784:29585072, ack 257105, win 1561, length 288
12:39:05.359823 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29585072, win 8208, length 0
12:39:05.359883 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29585072:29585248, ack 257105, win 1561, length 176
12:39:05.359998 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29585248:29585424, ack 257105, win 1561, length 176
12:39:05.360063 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29585424, win 8207, length 0
12:39:05.360167 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29585424:29585712, ack 257105, win 1561, length 288
12:39:05.360278 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29585712:29586000, ack 257105, win 1561, length 288
12:39:05.360346 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29586000, win 8212, length 0
12:39:05.360411 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29586000:29586176, ack 257105, win 1561, length 176
12:39:05.360524 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29586176:29586352, ack 257105, win 1561, length 176
12:39:05.360591 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29586352, win 8211, length 0
12:39:05.360686 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29586352:29586640, ack 257105, win 1561, length 288
12:39:05.360795 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29586640:29586928, ack 257105, win 1561, length 288
12:39:05.360869 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29586928, win 8208, length 0
12:39:05.360926 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29586928:29587104, ack 257105, win 1561, length 176
12:39:05.361039 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29587104:29587280, ack 257105, win 1561, length 176
12:39:05.361107 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29587280, win 8207, length 0
12:39:05.361200 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29587280:29587568, ack 257105, win 1561, length 288
12:39:05.361311 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29587568:29587856, ack 257105, win 1561, length 288
12:39:05.361378 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29587856, win 8212, length 0
12:39:05.361444 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29587856:29588032, ack 257105, win 1561, length 176
12:39:05.361557 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29588032:29588208, ack 257105, win 1561, length 176
12:39:05.361622 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29588208, win 8211, length 0
12:39:05.361718 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29588208:29588496, ack 257105, win 1561, length 288
12:39:05.361828 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29588496:29588784, ack 257105, win 1561, length 288
12:39:05.361894 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29588784, win 8208, length 0
12:39:05.361959 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29588784:29588960, ack 257105, win 1561, length 176
12:39:05.362071 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29588960:29589136, ack 257105, win 1561, length 176
12:39:05.362135 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29589136, win 8207, length 0
12:39:05.362232 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29589136:29589424, ack 257105, win 1561, length 288
12:39:05.362341 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29589424:29589712, ack 257105, win 1561, length 288
12:39:05.362409 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29589712, win 8212, length 0
12:39:05.362472 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29589712:29589888, ack 257105, win 1561, length 176
12:39:05.362584 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29589888:29590064, ack 257105, win 1561, length 176
12:39:05.362648 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29590064, win 8211, length 0
12:39:05.362747 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29590064:29590352, ack 257105, win 1561, length 288
12:39:05.362858 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29590352:29590640, ack 257105, win 1561, length 288
12:39:05.362925 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29590640, win 8208, length 0
12:39:05.362990 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29590640:29590816, ack 257105, win 1561, length 176
12:39:05.363101 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29590816:29590992, ack 257105, win 1561, length 176
12:39:05.363169 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29590992, win 8207, length 0
12:39:05.363268 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29590992:29591280, ack 257105, win 1561, length 288
12:39:05.363255 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 257105:257265, ack 29590992, win 8207, length 160
12:39:05.363376 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29591280, win 8212, length 0
12:39:05.363468 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29591280:29591568, ack 257265, win 1561, length 288
12:39:05.363540 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29591568, win 8211, length 0
12:39:05.363703 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29591568:29591920, ack 257265, win 1561, length 352
12:39:05.363822 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29591920:29592304, ack 257265, win 1561, length 384
12:39:05.363891 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29592304, win 8208, length 0
12:39:05.363955 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29592304:29592480, ack 257265, win 1561, length 176
12:39:05.364073 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29592480:29592656, ack 257265, win 1561, length 176
12:39:05.364140 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29592656, win 8207, length 0
12:39:05.364235 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29592656:29592944, ack 257265, win 1561, length 288
12:39:05.364326 IP 52.112.14.106.3480 > 192.168.1.162.50032: UDP, length 110
12:39:05.364346 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29592944:29593120, ack 257265, win 1561, length 176
12:39:05.364359 IP 52.112.14.106.3480 > 192.168.1.162.50032: UDP, length 308
12:39:05.364383 IP 52.112.14.106.3480 > 192.168.1.162.50032: UDP, length 324
12:39:05.364408 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29593120, win 8212, length 0
12:39:05.364476 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29593120:29593280, ack 257265, win 1561, length 160
12:39:05.364639 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29593280:29593664, ack 257265, win 1561, length 384
12:39:05.364621 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [P.], seq 257265:257329, ack 29593280, win 8211, length 64
12:39:05.364812 IP 192.168.1.1.22 > 192.168.1.150.62965: Flags [P.], seq 29593664:29593984, ack 257329, win 1561, length 320
12:39:05.364884 IP 192.168.1.150.62965 > 192.168.1.1.22: Flags [.], ack 29593984, win 8209, length 0
i have this in a pcap file which wireshark can use as well
What other things do you have in your network setup?
I assume there's at least one switch, access point?
