Had some Edifier from overclocker many many years ago, no idea what version of them, but dont recall having the choice that I have now.
So first question goes to Overclocker UK, assuming you might have listen to a few sets of 2.0 speakers just on sound quality what would you recommend regardless of cost, and then if possible if on a budget of £150 or less what is the best bang for buck in the Edifier range?
Second quest open to all, what speakers have you tried and what did you buy and why?
I'm just after some thing beats all these cheap plastic looking speakers like the T60 speakers, must be less than 9 inches wide, my pc main use is games first and formost
