edifier c6 advice
15 May 2012
Birmingham
Looking to buy edifier c6 but wondering if it needs a amp to go with it or plugs directly into the pc and also if i do need a amp wich one and how does it connect to the pc.
no it has its own amp(with built in mp3 palyer and fm radio), and you will use phono to rca to connect it (should come with the leads you need)
extra
from the little i have found it comes wiht 1 phono to rca and 3 rca to rca
so from a standerd sound card you will need to get 3 more phono to rca or some adapters.
also what sound card are you using?
Presumably you mean 3.5mm jack to phono, as rca plugs are just another name for phonos.
thanks for the replies guys and sorry about late post computer went down and to nelviss im just using 7.1 onboard Sound for the moment
