Edimax EW-7612UAN
28 Feb 2012
Hi,
Wondering if anyone might be able to help!
In January I brought a Edimax EW-7612UAN to replace a 54g USB card. The Edimax however is only connecting at 54mb and using a/g according to my Wireless AP connected devices tab. It is a DLink DIR-615 and other N devices connect fine. I'm a bit confused here.
Thanks:confused:
Well you can have AES and TKIP enabled at the same time, check the settings on the PC side.
Ah I didnt realise! doh! The AP was set to AUTO (TKIP/AES) and on the client it was set to TKIP, so I have set to AES! Now connecting at 150mbps. Thank you for helping me out!
