Hi Guys
Due tomorrow we have a nice price on the Edimax HP-2003AVK kit.
Powerline is an affordable and reliable way of avoiding wireless throughout your home. Useful for hard wired systems and games consoles. A powerline kit often presents a more affordable and faster solution than wireless.
with stock due first thing in the morning, this is a deal not to be missed.
Edimax 200mbps Powerline Kit HP-2003AVK @ £29.99 inc VAT
Transmit Network Data via Existing Electrical Wires
If your home or office does not have Ethernet cables installed in the wall and you dislike the idea of unsightly external cabling running all over the place, use the Edimax HP-2003AV to turn the existing electrical wires in your home or office into a high-speed network connection. With the HP-2003AV, annoying cable planning and installation are no longer necessary. The HP-2003AV enables you to create a network environment easily and cost-effectively.
200Mbps HomePlug AV Standard & IGMP Support
The Edimax HP-2003AV not only complies with the HomePlug AV standard but also supports IGMP managed multicast streams. HomePlug AV is the next generation powerline technology that provides high-speed data rates of up to 200Mbps and transmission range of up to 300 meters. IGMP can be used for online gaming and video streaming applications, and allows for more efficient use of network resources. With the HP-2003AV, you will be able to transfer high-definition video and digital audio quick and easily.
Coexistence with HomePlug 1.0 & 1.0 Turbo Devices
The Edimax HP-2003AV is designed to ensure efficient coexistence with HomePlug 1.0 and 1.0 Turbo devices, providing a guaranteed QoS to all the devices present in the heterogeneous powerline network. In such an architecture, the HP-2003AV and other HomePlug 1.0 stations share the CSMA/CA allocations, thus providing fair access to HomePlug 1.0 stations based on traffic priority.
Hardware Group & Reset Buttons
The Edimax HP-2003AV has both a group button and reset button for simplified group and reset configurations. Press the group button and the HP-2003AV will help you set up a password for your network automatically. Press the reset button to reset the device to factory defaults.
128-Bit AES Encryption
Built in compliance with the 128-bit AES encryption standard, the Edimax HP-2003AV is able to give you superior powerline network security.
Main Features:
• Complies with 200Mbps HomePlug AV and IEEE 802.3/802.3u stand
• Utilizes existing electrical wires to transmit network data
• Supports 128-bit AES link encryption
• Features IGMP, QoS, a group button, and a reset button
• Powerline transmission range up to 300 meters
Only £29.99 inc VAT.
ORDER NOW
Main Features:
ORDER NOW
