Educate me about roof bars/bike carriers.
Caporegime
8 Jan 2004
Rutland
I would like to be able to top mount a couple of bikes on my car, it has the flush metal roof rails.
I assume I need to buy bars and a seperate bike carrier to mount to the bars, are they all interchangeable? Does it all have to match (ie all Thule?)
I'd recommend looking at this site:
I was recommended them from here the stuff is good quality and a lot cheaper than the likes of halfrauds.
If you have a tow ball, it’s worth looking at a bike carrier that can be mounted on one. I had one on our Volvo and really liked it. Much easier than trying to lift heavy bike onto the roof of a car
Got a bundle deal from them, went with Yakima Whispbars and Thule 598 bundle. Not cheap but looks built to last.
Much more efficient too as there's much less drag. Drawbacks are the bikes can get pretty grubby in wet weather, and there's the risk of damage from a rear shunt. Also frees up the roof for a roof box - handy if you are going away.
if your bikes electric stick a bag around the motor area when its being transported by car.
you might wanna just cover the bottom bracket area anyway.
a lot of E bikes were failing from water damage, with the owners claiming they never pressure washed their bikes.
turns out driving in the wet at 70mph can force moisture inside components
