I am about to upgrade my PC but I need to ask a few questions of you guys...
Would you purchase a Core 2 Duo Quad Pro 6600 or a Core 2 Duo E6850 (they are similar in price)?
Will PC2-8500 (1066) DDR2 run reliably with an Asus P5K-E Motherboard?
..or should I purchase PC2-6400 (800MHz) DDR2 as some suggest?
Somebody told me I would need to manually configure the BIOS to enable 1066 DDR and that it may not be reliable.
At 1280x1024 res. is the 8800GTS 512MB graphics card a good performer compared to the 8800GTX?
Is the stock heatsin and fan any good on the Quad Pro 6600?
If I wish to purchase a better one, which one should I go for?
Many thanks for any advice
