EEk Problems
10 Mar 2005
Scotland
Washed the car today and ever since it has never started :mad:
All the dash lights come on but no noise from the engine trying to start all I get is a sort of buzzy tapping noise and the cd changer going a big nuts.
I also have to push the lock button twice to lock it but if i then unlock it and lock it again it onlt takes one push of the button and if I hold the key in the starting position my alarm sounds sometimes too> NOt happy
Any ideas as I know very little :confused:
You didn't clean the engine did you?
Sounds like a bad earth to me or a short circuit where some water has got to it.
Did you get much water in the engine bay? it can cause havoc with the electronics
I do hope so but it has been a while already and I'm not the luckiest person btw infact probably the opposite :(
Check the connections on the battery are clean and tight, and check the chassis ground connection from the negative terminal of the battery is ok.
