ok type it 3 times now trying shorter.
i have a eero6 and grandstrem 801 voip unit with talktalk on fibre (as per advice from here i connected a small router i had to the eero to give me 5 wired lan connections)
all fine.
unfortunatly i have a vehicle diagnostic unit that updates periodically via wireless and found out yesterday it hasnt been doing so due to abnormal wireless connection.
its requirements are wpa2 and 2.4ghz wireless connection.
i can get the eero to switch wpa3 off but cant alter the speed (and to be frank i want faster speeds for normal internet)
thought i had sorted it when i found online a
so problem
if i connect that unit to the eero6 , i could in theory connect existing router to it daisy chaining it.
if i did so would the eero6 still be the problem ?
ie INTERNET/eero6 with voip adapter/wavlink or something compatable/existing router (for lan connections)/diagnostic kit using 2.4 g wpa2.
or would the eero kybosh the lot?.
sorry for the essay but really confused on a side note drove to daughters and connected to her sky network older and updated first time.
(there is a option for the diagnostic to connect via a mobile phone but havent worked out how to do that with my samsung a12 yet
thanking you in advance for any help.
all fine.
AC3200
wavlink unit that appears to be able to connect at different speeds at the same time and seperate passwords for them. but realised it only has 3 lan connections and im not sure if i can connect the voip adapter to it.so problem
)))thanking you in advance for any help.
