Eero Pro 6E vs Deco XE75 Pro vs Other?
26 Dec 2009
North
Looking to upgrade my ageing Eero Pro 5 (AC) triple pack come the new year, due to 1Gb fibre upgrade.
I do like the Eero system i have currently, very easy to setup and manage.
Narrowed it down to the above, which are similar in price (when on sale), just not sure which one.
Anyone tried both, or any other suggestions around the same price (£350ish) for a 3way mesh system.
I have wired backhaul with long runs of cat 6 cable, through a couple of switches.
If you like Eero, stick with Eero. Wifi6E penetration through UK walls and floors is shocking though, so be prepared to go to as many as one access point per room to get full speed. If you’re not getting full speed then you may as well stick with WiFi6.
