Effective Moth Repellents
smr
smr
6 Mar 2008
Leicestershire
We're having our moth eaten wool carpet replaced with 100% Polypropylene Carpet tomorrow and are just worried that the Moths will migrate to the Cupboards and what not instead...
Does anyone know any effective moth repellents as the market seems loaded with products, which ones are effective I'm not sure.
Cheers.
Godzilla.
In his last encounter with Mothra, Godzilla came out on top, so I'd say he was a safe bet if you want your moth problem solved*
*solution may involve the total destruction of your house and anything else in a five mile radius
They won't migrate to your food, they tend to be very item dependant. If anywhere you might find them where you keep your clothes.
Good luck. I bought cheap hamster food on an auction site 4years ago which had moth eggs in, still can't get rid of the blighters.
You can get lavender sticks which work okay. Some can make your clothes smell though, so watch out for that
edit: Orphea is the brand I have used before
