redex and vpower diesel
Found a good deal for Redex (1/4 of the price at ECP) so have enough for for two years. Wouldn't go so far as to do both though![]()
I sometimes use wynns egr cleaner too. Only use vpower too.Depends what manufacturer your car is.
On some of the VAG models, the EGR is notoriously known for being a weak part, and causing problems, probably no matter how much care you take with it.
