Eisbaer Aurora 420 + GeForce RTX 3080 Ti KFA2 + 12 HDD 3,5"
18 Feb 2022
Mitcham
Hello guys
I am looking for a new case that can fit:
Eisbaer Aurora 420 CPU AIO Water Cooling Unit - 420mm
https://www.overclockers.co.uk/alph...u-aio-water-cooling-unit-420mm-hs-00e-ac.html
GeForce RTX 3080 Ti HOF 12GB GDDR6X PCI-Express Graphics Card
https://www.overclockers.co.uk/kfa2...dr6x-pci-express-graphics-card-gx-0aj-kf.html
+ minimum 12 HDD 3,5"
all ideas/help will be appreciated
I checked https://www.overclockers.co.uk/phanteks-enthoo-719-full-tower-drgb-case-black-ca-09d-pt.html
but info "Radiator Mountings (at the expense of HDD- and/or fan slots):" little bit confused me
means: after install watercooling is no space for hdd ??
at this moment I have got
Fractal Design Define XL R2 Full Tower
but I have got the problem with installation graphic card and SAS controller
I removed back plates from this cards because are not fit to this small mounting holes - I tried everything but probably are too fat
every whole is divided by 2 parts 1 part is OK but second is too small
lQI5P6p
https://imgur.com/a/lQI5P6p
