Hi,
I recently purchase an i5 2500k having had a Q6600, and im hoping to get just as much value for money and amazing performance from this CPU as i did the last.
Previously i had my Q6600 running at a mild 3ghz, and had EIST running and it'd go down to 2ghz or thereabouts when it idle. I see EIST is available on my mobo (see sig) and yet despite it being activated in the bios it doesnt appear to be running.
CPU-Z and Core Temp both have it running at 4ghz which is what its set at *at the moment* (mainly to see if that would see EIST drop to 3.3ghz or something). Theres 0-1% load, so obviously the ideal time to wind down the settings and run cool and thus near silent.
Is there something new which may be auto-enabled which is negating the ability for SpeedStep to run? Ideally i'd love to see it drop as low as it possibly can do as the system is on 24/7 and the requirement for 100% juice is minimal.
Similar sort of question relating to Turbo Boost, i believe this is the anti-EIST, providing more power when more is called for? Its enabled, but doing nothing.
What im seeing while gaming is a default clock setting which takes a hammering sometimes and doesnt do anything, and when im browsing and its twiddling its thumbs, its still powering away at the default clock.
Im monitoring using MSI Afterburner, GPU-Z, CPU-Z, Core Temp, and all the OSD, 2nd monitor and G15 apps so im well aware of my hardwares live status, and its not changing based on whats put infront of it, and im puzzled as to why this might be.
Any thoughts/suggestions would be appreciated.
, CT must have just somehow got the 100mhz steps wrong, but it amused me for some time anyway
