Hi,
EK have now officially announced the release of the 1080 ti Water block. The block will be available from the 12th April and we expect stock to land either on the 15th or the 18th.
The new block has a few different features compared to the Titan X block with is also compatible which are:
It is a single Slot card and Bracket
They say GTX 1080 Ti on them
They don't have the cutout for the DVI port like the Titan X Block
They also have a black plastic cover around the inlet and outlet with 1080 ti written on it which can be removed if you wish.
Take a look at at the beauties for yourselves below:
EK Water Blocks EK-FC1080 GTX Ti - Nickel + Plexi @ £109.99 inc VAT https://www.overclockers.co.uk/ek-water-blocks-ek-fc1080-gtx-ti-nickel-plexi-wc-9fa-ek.html
EK-FC1080 GTX Ti is a high-performance full-cover water block for NVIDIA GeForce GTX 1080 Ti graphics card, based on Pascal architecture (GP102).
Only £109.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC1080 GTX Ti - Acetal+Nickel @ £109.99 inc VAT https://www.overclockers.co.uk/ek-water-blocks-ek-fc1080-gtx-ti-acetal-nickel-wc-9fb-ek.html
ORDER NOW
EK Water Blocks EK-FC1080 GTX Ti Backplate - Black @ £26.99 inc VAT https://www.overclockers.co.uk/ek-water-blocks-ek-fc1080-gtx-ti-backplate-black-wc-9fc-ek.html
Aesthetic retention backplate for EK-FC1080 GTX Ti series water block.
Only £26.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC1080 GTX Ti Backplate - Nickel @ £29.99 inc VAT https://www.overclockers.co.uk/ek-water-blocks-ek-fc1080-gtx-ti-backplate-nickel-wc-9fd-ek.html
Only £29.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
