I think i may have a problem with my ek 295 double sided block in that the liquid does not appear to be going around the entire inside of it. it looks like the liquid is only going around near the inlet and otlet rather than right to the edges of the block even though loop is fully filled.
now i have connected the inlet on the bottom right and outlet on top left. manual says tops are inlet bottoms are outlet. i gather that its not going to make any difference which way round you do it since the water has to go through the entire block to get out anyway so to minimise tubing lengths just used the bottom as inlet. this is the only thing that may be causing a problem but i cant see how it would.
its possible this is just normal but seems very odd to me so thought i better check it out quick before i fire it up.
see pic below. my coolant is orange, you can clearly see it near the barbs but to the right and left of the barbs its completely clear with no liquid at all in it. have i screwed it up or is this ok??
