Just wanted to share my thoughts regarding EK kit and this is all by a first timer
I was always afraid that watercooling might be very fragile, not safe, requires a lot of knowledge, maintenance, tools etc. but at the same time I was jealous in terms of temperatures, OC capabilities and noise. So after seeing thread about watercooling kits in "deals&offers" (even though I wasn't planning
) I decided to jump into water. Some new toys to play
I bought EK-KIT P360
https://www.overclockers.co.uk/ek-w...0-performance-watercooling-kit-wc-99d-ek.html
I did some reading before, decided I might want to add graphic card (or two) in to the loop therefore ordered also additional rad from EK
EK-CoolStream CE 280
https://www.overclockers.co.uk/ek-water-blocks-ek-coolstream-ce-280-dual-wc-99h-ek.html
Everything I ordered (at first)
...and unpacked..
My previous setup wasn't bad at all, fairly quiet, temperatures were ok, however overclocked 980ti was like a hair dryer during gaming:/ (running at around 1380 on core). Temperatures in previous cold months we approx 72-76C while gaming. I guess my case didn't help with perfect airflow (evolv ATX) but anyway...
...going back to the EK KIT...
Everything was quite clear to follow and understand. The only thing I was missing was regarding radiators, I didn't flush the radiators before installing them. Manual didn't mention anything and afterwards when I was reading forums very often people were saying that with top quality rads it's not neccessary? not sure, I guess if I buy 1080 with block I will use new coolant so this will serve as cleaning/flushing.
Vardar fans start working from 50% so minimum RPM for them is 850 (they don't go to max speed 1850, just a bit lower). I think they are quiet
I think... because it's hard to say with noise from pump. I can't connect the pump to PWM CPU fan connection just yet as cable is to short to reach it, so can't even test it. On idle my PC is louder than before with air cooling (I assume pump is working on max 4800).
I had difficulties with mounting res. Included mounts are too large and there is not enough space in the front between 280CE and 980ti. At the back of the case, holes didn't match EK mount so I had to drill in the case. In the end this was also not good as window screw was touching the pump which was causing louder vibrations. I bought EK holders which give more flexibility and removed pump/res mount included in the kit.
My current build looks like this
I can't compare temperatures as outside is much warmer than it was earlier this week.
On CPU I have idle temps around 28C, AIDA64 stress testing, closed case, after 20min around 70C.
Watercooled case with weak airflow (phanteks) and in addition blocked with radiators is not good for air cooled graphic card though...which is pushing me even harder to get gtx1080. There is very little air circulation and in a closed case it gets warm really quick, even with fans to max. While playing Doom (around 20-22C in the room), 980ti was getting temps around 84C
and was causing temperatures inside the case to rise by approx 15C (by motherboard sensor). Temperature on the CPU though stayed at 59-60C which I think was great considering conditions
Overall I'm very happy with the purchase, it was fun to play with it, build it. Quality of the EK products is very high, which you notice straight away. I even like their coloured boxes
they've got style.
Can't wait for new graphic card and do some testing then. I don't think I will be disappointed. There are probably things that I could've done better and this can be my chance to improve my water cooling loop
.I was always afraid that watercooling might be very fragile, not safe, requires a lot of knowledge, maintenance, tools etc. but at the same time I was jealous in terms of temperatures, OC capabilities and noise. So after seeing thread about watercooling kits in "deals&offers" (even though I wasn't planning
...and unpacked..
I think... because it's hard to say with noise from pump. I can't connect the pump to PWM CPU fan connection just yet as cable is to short to reach it, so can't even test it. On idle my PC is louder than before with air cooling (I assume pump is working on max 4800).I had difficulties with mounting res. Included mounts are too large and there is not enough space in the front between 280CE and 980ti. At the back of the case, holes didn't match EK mount so I had to drill in the case. In the end this was also not good as window screw was touching the pump which was causing louder vibrations. I bought EK holders which give more flexibility and removed pump/res mount included in the kit.
they've got style.Can't wait for new graphic card and do some testing then. I don't think I will be disappointed. There are probably things that I could've done better and this can be my chance to improve my water cooling loop
