- 11 Dec 2005
- Cheshire
EK 480 GTX Nickel Plexi Full Cover VGA Water Block @ £68.98 inc VAT
A Full cover block for reference design GeForce 480 GTX graphic card.
Base is made of electrolytic copper. Top is made of quality POM Acetal material. The sealing is preformed by quality rubber washers. Block is mounted with enclosed M3x8mm DIN7985 screws.
Enclosed is also a GPU reinforcer. A metal plate which is mounted around the GPU with M3×4 screws and reinforces the PCB for perfect GPU contact with Water block without unwanted PCB bending.
Fittings can be used on both side of the block (up and down) and 2 plugs are enclosed!
Enclosed:
- water block
- GPU reinforcer plate
- mounting mechanism
- thermal pads
Only £68.98 inc VAT.
ORDER NOW
EK 480 GTX Nickel Acetal Full Cover VGA Water Block @ £71.99 inc VAT
Enclosed:
- water block
- thermal pads
Only £71.99 inc VAT.
ORDER NOW
EK 480 GTX Backplate - Nickel Plated @ £29.99 inc VAT
Retention backplate made of nickel plated aluminum for EK-FC480 GTX waterblock.
Backplate serves as aesthetics add on.
This backplate is compatible only with Reference PCB design Nvidia 480 GTX cards in combination with any of EK-FC480 GTX waterblocks.
CAUTION: Due to extra chips on ASUS 480GTX and MSI 480 GTX PCB design, EK-FC480 GTX Backplates are not compatible (with these cards) until next revision.
Only £19.99 inc VAT.
ORDER NOW
EK 480 GTX Backplate - Black @ £29.99 inc VAT
Retention backplate made of black painted aluminum for EK-FC480 GTX waterblock.
ORDER NOW
Cool down your Fermi!
Enclosed:
- water block
- thermal pads
ORDER NOW
Enclosed:
- water block
- thermal pads
ORDER NOW
ORDER NOW
ORDER NOW
