** EK 7950 WATERBLOCKS INCOMING **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
We have two new waterblocks due from EK which are available to buy from them on March 13th 2012. I expect that our stock will land soon after that.
The 7950 is a popular card and the demand for this block has been massive.
Pre orders will be on a strictly first come first served basis and stock will be very limited on the initial few shipments.
We do not currently have a picture for the Nickel Plexi version of the block but I have put it live with a sample picture to allow those of you who are interested to register your pre order now.
Pre order pricing is available for early buyers too :)
EK-FC7950 Full Cover Waterblock - Nickel Acetal **EN Nickel Plating** @ £74.99 inc VAT
EK-FC7970 is a high performance full-cover water block for AMD reference design Radeon HD 7950 graphics cards. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC7950 water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
G1/4" threaded fittings can be used on both side of the water block (on copper and plastic) and 2 plugs (EK-Plug G1/4) are enclosed!
Enclosed:
- EK-FC7950 series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
Please note: Thermal paste is not included and needs to be purchased separately. EKWB recommends Gelid GC-Extreme for best performance.
Made in Slovenia - Europe!
Was £79.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
EK-FC7950 Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** @ £74.99 inc VAT
Please note, This item is a PLEXI + Nickel Waterblock. The item has not been produced yet and no stock photo is available.
Base is made of electroless nickel (EN) plated electrolytic copper while the top is made of quality cast acrylic material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
PLEASE NOTE:
- Due to superior nickel plating method and corrosion resistance, the waterblock may loose brightness over time and become of a bit duller tone.
- Due to immense variety of fittings/barbs available on market and no prescribed standards, we guarantee compatibility only for connectors bought from our web site.
Was £79.99 Inc. VAT
ORDER NOW
