- 13 May 2012
- Dewsbury,West Yorks,uk
Hi guys.
Just about finished my revamp of my 1000D build with just about evetything conected to Aquacomputer Splitty4s - Farbwerk 360 x 2 and Octo .
With 2 Rgbpx ports left on the 2nd Farbwerk 360 and 2 on the octo,what advice would you guys give in respect of conecting my EK flt 360 res/cpu block/flow indicator and Trinity gup block to these 4 ports either all together on a 4 way 5v 3 pin splitter( way under 90 leds capacity) or 2 each on 2 way Argb splitters,i also have the corsair rgb cable from the front io panel to connect.
Its a shame to plug them in singular as the flow ind has 2 leds and the cpu block 17 leds plus res has 21 and trinity gpu has 12.
Full rgb control is what im after,or would i have to get an active Argb splitter from amazon.
