Hello,
I was wondering if anyone has installed the EK waterblock for ASUS Tuf 3080Ti.
Although at full load the card reaches 60C it crashes after gaming a bit.
Switching the profile to quiet (and as a result effectively downcloaking the card a bit) solves the problem but as you can imagine it still leaves me troubled.
Both the waterblock, backplate and radiator are hot in touch and since the card was working prior to introducing it into the system leads me to excluse the psu (Corsair 860w) as a potential issue
I have 3 main candidates as the source of the failure
a) GPU and CPU are on seperate loops. When I was filling the gpu it did look like the flow was slow. I have used a couple of ek offset fittings. Dont know if they can restrain the flow that much
b) maybe there is poor contact? But if that is the case then the block and backplate wouldnt be hot when gaming would they + the temp would go well above 60C
c) poor contact in some of the chips on the back?
EK has not bothered to amend their instructions after the release of 3080ti and the online manual only shows the scenarios for 3080 and 3090.
https://www.ekwb.com/shop/EK-IM/EK-IM-3831109832639.pdf
I went by the instructions for 3080 but ultimately I dont think that it makes any difference as in both scenarios the pads on the areas that change are of the same thickness.
In any case I am going on holidays at the end of this week and I planning to adress all these scenarios by using the ek distro block and the ek active back plate. But in any case I wanted to check if someone else has encountered a similar issue
