I have finally finished building my new loop. Now that I have solved the hub issue, everything is nice and quiet, except the D5 in the BayRes. I have used D5s before and they were always whisper quiet - but this one seems excessively loud.
If I run it below about 1800RPM it quietens down, but is still the loudest component in the build (5 Noctua fans - chromamax and redux). Wound up to full (around 4000 rpm) it it very loud. I have captured a recording from inside the case on my phone - You can hear the pump at about 1800, then ramps up to max, then back to 1800. The background noise isn't as loud as it sounds on the phone, but the D5 is. Is there a problem with the D5?
Can't get youtube to take the file so here is a link to it in Onedrive - not dodgy honest
https://1drv.ms/u/s!AvIQG23DBLKasiMt8nhhWDKC-EL7?e=lQVbcH
