EK block fittings
12 Sep 2005
Grundisburgh
Water fittings.
I'm about to modify my GTX480 with a water jacket, an EK one from OKUK I thought :) However the rest of my system is a Zalman Reserator XT using Zalman pipe which is 8mm (1/2" ? ).
The EK doesn't come with any connectors and I can't find any 8mm ones. OCUK have one 7/16" would they be any good?
Or, are there any alternative ways of connecting an EK block to the Zalman pipes?
Cheers.
Andi.
AFAIK Reserator stock tubing is 12mm OD 8mm ID and uses barbs. So you need an 8mm barb. Unfortunately a 11/8mm compression fitting probably won't fit as the tubing is too thick.
OcUk don't have the 8mm barb you need, the part number you want is G1/4TOZALMAN but any 8mm barb will do if you are searching on Google :)
