I just bought the new Threadripper Velocity block and took it apart to see if I could flip the ports internally (you can't
I cannot for the life of me get it back together. There are two rubber O rings that have to be positioned exactly and I can't do either of them, I've spent an hour pressing the rings into the block and trying to force them into place. How the hell do you get these blocks back together?
Perhaps I shouldn't have taken it apart but at some point I would have had to have cleaned it!
Is there a trick to doing this? I've tried using a spudger to press the ring into the frame, it never stays, I've seen a few videos where the top plate is used to press it into place, I've tried that and cannot get the o-ring into the correct position.
At this point I'm tearing my hair out! I have no idea what else to try.
) I cannot for the life of me get it back together. There are two rubber O rings that have to be positioned exactly and I can't do either of them, I've spent an hour pressing the rings into the block and trying to force them into place. How the hell do you get these blocks back together?
but, I’ve had a similar issue in the past where the o-ring groove wasn’t o-ring shaped. Just ended up using the smallest of small dabs of glue just to get it to sit in the right shape. Worked a treat.
