Well, yesterday i built my first test loop out of the case.
Everything held up, no leaks...however...
How tight i must screw in EK compression fittings ? When i need to tweak the layout its near impossible to unscrew compression ring without unscrewing the whole fitting. Tubing is XSPC 7/16-5/8 (https://www.overclockers.co.uk/showproduct.php?prodid=WC-031-XS) and its well sticky on the outside.
At this point i'm afraid i may strip threads on acetal cpu block(xspc raystorm) and ek pump top res (d5 x-res 140).
Any tips on dealing with this ?
