- 11 Dec 2005
- Cheshire
EK CoolStream Radiator XT 360 (120.3) @ £34.99 inc VAT
Quality at EK level and an optimal price-performance ratio make these EK-CoolStream RAD XT radiators unique. The new radiators feature, besides their great design and high build quality, great cooling performance. The copper fins are specially designed for Ultra-silent fans (with low Airflow). The parallel coolant channels reduce flow resistance to a minimum. On both sides of the radiator the M3 threads are integrated to allow fan installation on both sides and radiator mounting. The radiator has integrated G1/4" threads, allowing installation of virtually all common fittings. Please note: Over-tightening of the screws may damage the radiator. Always take care that the screws do not damage the radiator. Damages of the product because of improper use are not covered by the warranty!
Technical details:
- Material: Copper fins, Brass chambers
- Dimensions (LxWxH): 398x123x47mm
- Connection threads: G1/4"
- Weight: Approx. 1350g
- Fan installation: 12 x M3 threads on both sides each (for 3x120mm fan each)
- Pressure tested: 8bar
Enclosed:
- 1x EK-CoolStream RAD XT (360) radiator
- 12x M3 x 30mm screws
- 12x M3 x 35mm screws
Important: The included screws may be too long for some applications. Always be sure to screw them in only so far that the radiator is not damaged.
Only £34.99 inc VAT.
ORDER NOW
Technical details:
Enclosed:
ORDER NOW
