Lovely the blue looks awesome !
Great Rig
Great Rig
another quick question, would yotu recommend these rads in the case with a pull or after reading the other thread about push pull, would a 60mm rad with a push setup be better?
Looks good!Nice clean buildLooks good!
I was always wondering, is it easy to connect the GPU out to CPU in with just 90 deg on GPU and straight compression on CPU...
It looks quite tight bend...
Is it worth getting 90deg & 45 deg for this? What's your experience xtremedetailz?
I've got the same case with a 60mm 120.3 in the roof.Sorry to possibly ask a dumb ass question but when using the dual bay can you use the hotswap bay and also a dvd drive?
You can use the hotswap still, but you cant fit a drive in the top as the rad is too thick. (and long) You can fit a fan controller though.
Not how Xtreme has done it though, as his dualbay is actually sitting in the hotswap (unless my eyes are mistaken?)
Yeah I had to change to a tube res because I needed my blueray drive and my storage drive in the front too.
