EK CSQ Bridge and Flow
17 Aug 2010
Essex
Hello all,
I'm upgrading to 2x GTX 670's and as EK have discounted the old style of blocks for the new 'CSQ' design and as I can't find the old style anywhere! :( I'm not sure if my original flow plan will still work with these new blocks.
Here is a quick diagram I made in paint(Yes I know my drawing skills suck :))
Here is the bridge I need to get.
I've tried to find images etc on the net to see the available ports on these new CSQ bridges to make sure there is 2 ports at the bottom and 2 ports at the top but can't seem to find anything so I'm not sure if my original flow plan will still work with these new CSQ blocks/bridges.
Also if it wouldn't work is there any suggestions on other GPU blocks that would allow this 'parallel' flow?
Any help is greatly appreciated.
Many thanks,
Not going to happen I'm afraid :(
They only have port on the bottom right hand side and 2 on the top :/
If you want parallel flow, what I'm currently thinking of is to use T fittings on the top of the blocks to mimick the old design, not certain if it would actually work though
Thanks for the fast response Cleeecooo,
Dammit! Why did they have to change the design the old one was fine! lol
I will have to use the same flow like I'm using currently with a single card.
With the above diagram, what bridge is best to get?
Serial or Parallel?
Many thanks once again!
