EK D5 pump top compatibilty?
13 Mar 2006
Quick question - is the EK D5 PWM pump overclockers sell
EK D5 PWM the same as any other D5 in terms of d5 top compatibility? It lists only EK pump top/reservoirs etc... Need it to be compatible with alternative tops to EK ones...
The pump itself will be as all D5 are the same but the connection mounting may be different. A bare D5 and a D5 reservoir may not be easily connected as both may assume the other has a connecting ring.
