looking for anyone who is familiar with this block, i've had slow leaks since i got it. i noticed the first leak after i installed it - the inlet hole - as its slightly recessed into the block, my 1/4" fitting wasnt fully seated in the port. A bit of googling and someone advised using the included extender. That worked. The kit only includes 1 extender though.
its an eye sore and i hate it, but it works:
i've noticed i seem to have the same issue the other side, where i wish to use a bitspower temp probe. i've put up with this for a while as it didnt seem to to be dripping near anything important (plus i've had nowhere i can move the pc to drain it)
suprise suprise, somehow it eventually managed to kill my psu which has also caused damage to my mobo, i need to find a solution.
so my question is, has anyone used this port and know whether an extender is required here too? (i hope not, this is going to look stupid)
i've tried a new o-ring on the temp probe, made sure not to over tighten, but it still leaks!
today i've removed the probe and reinstalled the plug that comes with the res, fingers crossed this stops it, but i'd like a temp sensor tbh. the plug is just to see if it stops. I notice it sits completely flush with the block, which is why i suspect its recessed like the other side. why ek.
got some cotton wool and electrical tapeto monitor it, if its blue tomorrow i know theres still an issue.
