I have an EK DDC 3.2 PWM pump, and as watercooling is new to me I have some questions about its behaviour.
Firstly the pump speed is maxed at 50% PWM. Increasing the PWM speed above this has no effect (it's running at 4500 rpm.) Seems odd?
Secondly the pump is really loud at max speed, but silent at around 3400 rpm. Is this fast enough? I don't see much change in temps between the 2 speeds so I guess it's ok.
Finally, I have it plugged into the CPU header on a Gigabyte X99M motherboard, and it seems there is no way to run it at a fixed speed. I only have options for full speed or CPU temp dependant profiles. There is a fan curve editor but it's the buggiest thing ever and impossible to use.
