EK En plating. How to tell?
Status
Not open for further replies.
24 Aug 2006
Gibraltar
Hello just received my HF supreme Full Nickel (EN) from ocuk. At the risk of sounding stupid is there any way to tell if its EN? Theres no silver sticker on the box or anything.
a quote from a staff member at EK
To sum up you can identify the EN plated product by:
- silver "EN" sticker on the box
- new front- and side label on the packaging
- new EAN (product) number
- new labeling for the product (EN instead of Nickel)
elmuzzy66.
could you please email me with your order number and a picture of the front of the product box and the OcUK stock barcode at the side.
I will deal with this myself.
rich.oneil [at] overclockers.co.uk
elmuzzy66.
Thanks Rj i'll do what you asked. Ive sent a webnote before i read your post, so i'll deal with you.
no problem. will help out as much as i can.
it may be a warehousing error so i will have to check.
also, there should be an EAN number on the box somewhere
it would help me laods if you could email me that too.
Sry for wasting your time Rich. Theres a very small En label on the box sleve:o:o:o:o I guess i was expecting a silver en sticker so i panic:mad::o
Back to modding my ATSC840 then. Close thread as all is resolved
Thanks for the help:
Status
