Perfect for getting the most out of the Nvidia GTX 295 graphics cards.
EK GTX 295 SLI Plexi Full Cover VGA Water Block
High performance VGA water block for GeForce 295 GTX refference design series graphic cards. Bases are made of electrolytic copper. Middle part made of quality acrylic glass. The sealing is preformed by quality rubber washer. Block is mounted with enclosed M2,5 screws. Block is prepared for two 5mm LED diodes. Prepared for SLI means, that fittings can be used on both side of the block (up and down)!
- Prepared for SLI
- Dimensions of copper base: 214 x 115 x 8mm
- Dimensions of acrylic top: 171 x 115 x 8mm
- Threads: 4× G1/4
- Weight: 1350g
Buy now @ Just £109.24 Inc VAT
- Prepared for SLI
- Threads: 4× G1/4
- Weight: 1350g
