** EK GTX 690 & GTX 670 WATERBLOCKS INCOMING **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hey Guys
Finally got the info from EK on these. Anticipating stock very soon.
I know the 670 owners on here are going nuts waiting for these.
Get involved guys!
EK 690 Full Cover Waterblock - Nickel Acetal @ £119.94 inc VAT
EK-FC690 GTX is a high performance full-cover water block for nVidia reference design GeForce GTX 690 series graphics card. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC690 GTX water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
Base is made of nickel plated electrolytic copper while the top is made of quality POM Acetal material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC690 GTX Backplate - Black) which improves the looks of your graphics cards and also provide some passive cooling to the VRM section.
Any G1/4" threaded opening can be used as inlet or outlet.
Up to four EK-FC690 GTX series water blocks can be interconnected with EK-FC Bridge & Link system. The EK-FC Link is already enclosed.
Enclosed:
- EK-FC690 GTX series water block
- mounting mechanism with screw-in brass standoffs
- thermal pads
- link
Please note: Thermal paste is not included and needs to be purchased separately. EKWB recommends Gelid GC-Extreme for best performance. Torx T6 screwdriver needed for dissasembly of the factory heatsink/fan solution is also not included.
Made in Slovenia - Europe!
Only £119.94 inc VAT.
ORDER NOW
EK 690 Full Cover Waterblock - Nickel Plexi @ £119.99 inc VAT
Base is made of nickel plated electrolytic copper while the top is made of quality cast, satin finished acrylic material. The sealing is performed by quality rubber washers. Screw-in brass standoffs are pre-installed and allow for safe, painless installation procedure. Block is mounted with enclosed M3x4 DIN7985 screws.
Enclosed:
- thermal pads
- link
Only £119.99 inc VAT.
ORDER NOW
EK 670 Full Cover Waterblock - Nickel Acetal @ £73.99 inc VAT
EK-FC670 GTX is a high performance full-cover water block for nVidia reference design GeForce GTX 670 series graphics card. Please check our Cooling Configurator online compatibility system for detailed compatibility list!
This water block directly cools the GPU, RAM as well as VRM (voltage regulation module) as water flows directly over these critical areas thus allowing the graphics card and it's VRM to remain stable under high overclocks. EK-FC670 GTX water block also features a very high flow design therefore it can be easily used in liquid cooling systems using weaker water pumps.
EKWB recommends the purchase of aesthetic retention backplate (EK-FC670 GTX Backplate - Black) which improves the looks of your graphics cards and also provide some passive cooling to the VRM section.
Up to four EK-FC670 GTX series water blocks can be interconnected with EK-FC Bridge & Link system. The EK-FC Link is already enclosed.
Enclosed:
- EK-FC670 GTX series water block
- thermal pads
- link
Only £73.99 inc VAT.
ORDER NOW
EK 670 Full Cover Waterblock - Nickel Plexi @ £73.98 inc VAT
Enclosed:
- thermal pads
- link
Only £73.98 inc VAT.
ORDER NOW
+1
dont think its gonna happen though
Coulda sworn it says on the EK website that they are planning to make one just don't have the time/resources yet....
EDIT: Found it: http://www.ekwb.com/news/143/19/
News
May 18, 2012
Water block for Nvidia GeForce GTX 670
We are in process of making a block for Nvidia GeForce GTX 670 reference cards.
We will soon launch also a FC block for ASUS GTX 670 DCII card, however due to amount of recent load of work and full production capacities the update will be posted once we have more information.
Thank you for patience and understanding.
Your EK Team.
Hi All, there is a detail I wanna share with you:
When using the EkWB cooling-configurator and looking for the GTX670 DCII TOP, I found that a new reference is showing up, the EK-FC670 GTX DCII, check that:
http://coolingconfigurator.com/step...ine?height=260&width=530&inline_id=comp_table
We cannot select it yet, but that means it is comming soon and should be compatible with the DirectCU II and DirectCU II TOP... !!! Is not that such a good news !
