The additive is UV reactive.
if you mix it yourself you will need a litre of distilled water
alternatively you can use the superb mayhems UV pre mixed fluid [see our fluid section]
as stated the fittings used in the kit are stocked by us, however we are waiting on a shipment direct from EK [they are based in Slovenia so stock takes a while sometimes]
