Hi,
EK are probably the most well known water cooling manufacturer in the market and are always looking at creating new products to ensure all customers have the options they want.
The new RGB range has been added after the market trend has gone in the direction of RGB everything. We see some of the most popular blocks come to market allowing you to link the blocks with most motherboard vendors sync software. The Strix blocks are compatible with Asus Aura sync and the none Strix blocks are compatible with Asus Aura sync, Gigabyte RGB Fusion, MSI Mystic Light and Asrock RGB Light.
Pre-order items will be available 23rd March.
EK Water Blocks EK Supremacy EVO RGB CPU Block – Nickel (3830046995797) @ £69.95 inc VAT
3830046995797, EK Supremacy EVO Block, RGB LED, Suitable for Intel LGA-1150/1155/1156/1151/ LGA-2011(-3) / LGA2066
Only £69.95 inc VAT.
ORDER NOW
EK Water Blocks EK-Supremacy EVO AMD/AM4 RGB CPU Block – Nickel (3830046995940) @ £69.95 inc VAT
3830046995940, Supremacy EVO, RGB LED, Fits the new AM4 socket, all legacy AMD socket (AM3+, AM3, AM2, AM2+, FM2, FM2+, 939, 754)
ORDER NOW
EK Water Blocks EK-FC Radeon Vega RGB - Nickel @ £109.99 inc VAT
EK-FC Radeon Vega RGB is a high-performance full-cover water block for multiple AMD® Radeon® Vega based graphics cards that comes with pre-installed 4-pin 12V RGB LED strip.
Only £109.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC Radeon Vega Strix RGB - Nickel @ £119.99 inc VAT
EK-FC Radeon Vega Strix RGB is a high-performance full-cover water block for ASUS® ROG® Strix RX VEGA64 OC graphics card that comes with pre-installed 4-pin 12V RGB LED strip.
Only £119.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC1080 GTX Ti Strix RGB Graphics Card Water Block – Nickel @ £124.99 inc VAT
The EK-FC1080 GTX Ti Strix RGB is a high-performance full-cover water block for all ASUS ROG Strix GeForce® GTX 1080 Ti graphics cards versions on the market!
Only £124.99 inc VAT.
ORDER NOW
EK Water Blocks EK-FC GeForce GTX Founders Edition RGB Graphics Card Water Block - Nickel @ £114.95 inc VAT
EK-FC GeForce GTX FE RGB is a high-performance full-cover water block for multiple NVIDIA® GeForce® GTX and Titan Pascal series graphics cards that comes with pre-installed 4-pin 12V RGB LED strip.
Only £114.95 inc VAT.
ORDER NOW
All EK products available here
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
