- 15 May 2012
- Louth, lincs
Got some in the box, what are they for?? My 4770 heats up quickly but water temp doesn't, would a different plate help??
Pretty sure the 4770 just uses a normal default jet plate most of the time, but if you have flow problems, you can lower the restriction by changing plate.
Have you refitted the cooler?
Might be bad contact between it and the IHS. The other thing to blame might be the crappy paste they put in between the chip and the IHS, nothing you can do about this without delidding it, i'm afraid.
What temps are you getting and at what volts / OC ? What's in your loop and how much radiator space?
day temp at 100% load 79c, night (heating on in house) 84c
