EK Kit ~140quid or H100
27 Oct 2009
West Sussex
Are these worth the money really?
Or maybe its better to just buy H100 and be done with it?
Purpose: 4.8GHz 2500K in a silent rig with Corsair 500R case
depends what you want really
aesthetically, the EK kit winds hands down.
performance is similar but with a kit you have the option to cool your GPU too if you wish.
it depends what you want from the cooling solution, the H100 is very overpriced for what it actually is. If you want a good cpu only cooling solution, then something like a noctua nhd14 would be a better bet imho.
Im planning to get the 500R case and I know the H100 fits in the top there nicely, dunno about other thicker rads so with proper WC that would be a small limitation.
Wouldnt I have to go with a higher grade kit to cool two Xfire 6950s?
I need silent (or near silent @2m) and efficient cooling... Won't be sticking to the stock fans as I want to change them to 2x GT AP-15.
