EK kit advice
18 Oct 2002
Liverpool
been out of the loop for a long time on watercooling last block i used was a cathar little river white water
for ease of ordering was thinking about the EK-KIT H3O - Supreme HF 240, at the moment for cpu cooling only, can't stretch to cool two ati cards also but would maybe like to in the future
any thoughts or comments on this Kit?
thanks in advance
just to add also will be installed into a Haf X and using a asrock extreme4 i5 2500k
I'm interested in this too.
Infact, I want to know more about both EK's kits and XSPC's kit.
Subscribed!! :-)
Hi, the best thing to do is read a few reviews about these H2o Kits, but the XSPC Rasa 240 or 360 get good reviews, there are one or two forum members are runing the XSPC one. But l can tell you the pump that comes with the XSPC Dual750 Res/Pump combo will coupe with GPU as well. But you will need a extra rad or a better single Rad, depending on your Case,the XSPC Rasa 240 below.
XSPC Rasa 750 RS240 Watercooling Kit -
This kit is ideal as a simple CPU watercooling kit and removes more heat than air cooling.The kit is designed to be quiet and also handle mildly overclocked CPU's. The pump is strong enough that other waterblocks can be added to the loop if required.
Please Note : Fluid is not included with this kit.
Model Manufacturer XSPC Model Number Rasa 750 RS240 Specification Intel Socket Compatibility Socket 1366
Socket 1156
Socket 1155
Socket 775
Socket 604
Socket 603 AMD Socket Compatibility Socket AM3
Socket AM2+
Socket AM2
Socket 940
Socket 939
Socket 754 CPU Waterblock XSPC Rasa Black VGA Waterblock N/ARadiator XSPC RS240 Radiator Dimensions 277 x 121 x 35mm Radiator Fan Specification 2 x Low Noise 1700rpm 120mm Fan Pump XSPC X20 750 12v Pump Flow Rate750 L/ph Reservoir Built In Pump Tubing 7/16" ID - 5/8" OD Clear Fittings 6 x 1/4" thread 1/2" Barbs Fluid NOT INCLUDED.
SuitabilitySimple CPU Watercooling, Mild Overclock CPU Cooling Package Contents1 x XSPC Rasa Black CPU Waterblock
1 x XSPC RS240 Radiator
2 x 120mm Fan
1 x XSPC X20 750 Pump & Reservoir combo
2 x 7/16" Clear Tubing
6 x 1/2" Barb Fittings
1 x 5mm Blue LED
1 x Velcro Mounting Pad for Pump
6 x Hose Clips
1 x 80 - 120mm Radiator Mounting Kit
1 x Thermal Paste
1 x CPU Mounting
I just want to cool my i5-2500k at the mo.
I've just upgraded my case from a Coolermaster Storm Scout to a NZXT Phanton and my GPU's have taken a big hit on cooling due to no side fan blowing on them anymore.
My CPU cooler is too big to fit a side fan so thinking if I get watercooling CPU I can fit a side fan too for GFX's.
Just had a look at the Phanton, l think you can fit a 200cm Side Fan, check your case manual, plus there's mounts for a couple more, ah didn't see the CPU being to big, sorry.
Yeah, the XSPC kit is better.
As for the phantom, if you want some info on how to watercool it check out the two links in my zig :)
I would say if you do get a xspc kit, pay the little extra for the RX version so you get the much better radiator
