Ek kit and connect 51
18 Oct 2002
So my first attempt at watercooling has gone OK so far, leak tested all OK.
The kit came with a free connect 51 but it doesn't support the vardar fans, block or pump rgb that came with the kit as they are 12v rgb and the connect 51 is 5v rgb Is that right?
I think I can use the connect to control pump and fan speeds with their software but what do I need to control the rgb?
Been out of pc building for a while, thanks for any help.
Contact EK to check. They are very good at responding. I have the Connect with Varder fans and it works fine.
It has D-RGB connectors which I use for my CPU block and Distro plate.
