- 27 Feb 2020
Hi all,
Recently I bought EK Loop connect to control 9 fans and EK D5 pump in my system. I'm having some serious issues with their software.
1. For starters it constantly crashes without any error message and this causes the temperatures to go through the roof.
2. There are functions in the software which look like you should be able to use but if you click on them nothing happens.
3. EK Loop Connect software has to be manually run after every boot in order to control my fans/pump and has be kept open as it does allow to be minimized into tray.
4. I'm still trying to find a way how to control fans based on the water temperature, this is a fan controller intended for water cooling so what's the point of ramping up fans when CPU temp spikes?
5. RGB section does not allow me to control RGB channels separately and most of the effect won't even let me choose colours unless I'm missing something.
6. In cooling section I can choose between CPU cooling or GPU + CPU cooling if I choose the latter the software is ignoring the fan curves.
What's your experience with this product guys? Have you had any issues?
