Ek memory waterblocks?
22 May 2010
Minibotpc
Do these fit only with the Corsair dom's and GT's or is there any other memory kits they will work with?
quite interested in getting one but i'm running Crucial value ram at the moment :p
Why bother though? Memory does'nt run hot enough to require watercooling. Hell, most DDR3 does'nt even need heatspreaders. All you will be doing is adding restriction to the loop.
Some musking blocks are also supported.
I wouldn't bother. Go for Samsung super overclocking RAM instead if you want to buy more/new memory
ive got the corsair gt ram and block.
not sure what other ram the block fit's but i just went for the gt as i knew it fits.
personally i like cooling the ram as it is more look's than anything else.
