** EK MEMORY WATERCOOLING NOW AVAILABLE FOR ANY MODULE **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
EK have released some new products today,
most notable of which is a dominator replacement heatsink. this item allows you to put heatsinks on any memory module that can be used in conjunction with the desirable dominator cooling blocks.
now, every user can cool their memory kit without having to buy expensive dominator memory.
EK-RAM Dominator Module - Black (2pcs) @ £19.99 inc VAT
EK-RAM Dominator Module is a heatsink adapter which allows virtually any (DDR-)SDRAM memory module (of any generation) to be water cooled in conjunction with EK-RAM Dominator series water blocks.
Each heatsink consists of two separate plates while the DIMM memory module is sandwitched in between. Heat transfer between the memory module and aluminium heatsink adapter is ensured by the use of enclosed thermal pad. Between the EK-RAM Dominator Module Adapter and EK-RAM Dominator series water block we recommend the use of electrically non-conductive thermal grease, i.e. Gelid GC-Extreme.
This product is ready to be used only with double-sided (single or dual ranked as per JEDEC) DIMM memory modules. In case single-sided DIMM module is used one needs to use 1.5mm thick thermal pad where no memory chips are used (not enclosed). Factory installed heatsink must be removed from each memory module prior to installation (if present).
This set contains two EK-RAM Dominator Module Adapter heatsink. Each of these items are made of CNC machined high quality aluminium and feature black anodized finish.
Enclosed:
- EK-RAM Dominator Module Adapter (2 pcs)
- thermal pads
- mounting screws
- allen key 2mm
PLEASE NOTE:
- Intended for use with double-sided (single or dual ranked as per JEDEC) DIMM memory modules
- Factory installed heatsink must be removed from each memory module prior to installation (if present)
- Thermal grease is not included
Only £19.99 inc VAT.
ORDER NOW
also released today is the new CSQ single bay res from EK
this is a revamp of the classic single bay repack res in the new CSQ design, perfect for smaller systems or when a spin res is not required.
EK-BAY SINGLE RES CSQ - Acetal @ £38.99 inc VAT
EK-BAY SINGLE Reservoir CSQ - Acetal is a simple, compact yet very efficient water reservoir. Reservoir is made of quality POM Acetal, covered by a 5mm thick, satin finish acrylic glass. Reservoir features special anti-vortex acrylic insert which effectively prevents air bubbles from re-entering the loop. As a result high flow rates of up to 250L/h (1GPM) are possible with this reservoir. Reservoir features G3/8 threaded filling port, an appropriate plug is enclosed. Reservoir fits in majority of computer chassis and occupies only a single 5.25" drive bay. No boring or sawing is necessary. This reservoir is fully air- and waterproof once closed with the enclosed plugs therefore no water can evaporate.
Features:
- Appropriate for flow rates of up to ~ 250L/h (1,1GPM)
- Fits in single 5.25" drive bay cage
- Monitor your water coolant level
- Easy installation
Specifications:
- main body size: 145x40x60 mm (LxHxD)
- total volume: ~ 170 mL
- port threading: G1/4" x 3
- filling port: G3/8"
- main reservoir material: POM Acetal (black)
- includes needed Allen keys (6mm and 2mm) and plugs (1x G1/4", 1x G3/8")
Made in Slovenia - EU!
Only £38.99 inc VAT.
ORDER NOW
EK-BAY SINGLE RES CSQ - White Acetal @ £38.99 inc VAT
EK-BAY SINGLE Reservoir CSQ - White Acetal is a simple, compact yet very efficient water reservoir. Reservoir is made of quality POM Acetal, covered by a 5mm thick, satin finish acrylic glass. Reservoir features special anti-vortex acrylic insert which effectively prevents air bubbles from re-entering the loop. As a result high flow rates of up to 250L/h (1GPM) are possible with this reservoir. Reservoir features G3/8 threaded filling port, an appropriate plug is enclosed. Reservoir fits in majority of computer chassis and occupies only a single 5.25" drive bay. No boring or sawing is necessary. This reservoir is fully air- and waterproof once closed with the enclosed plugs therefore no water can evaporate.
Features:
- Easy installation
Specifications:
- main reservoir material: POM Acetal (white)
Made in Slovenia, EU!
ORDER NOW
stock will likely be limited, so be quick to pre order if you want to avoid disappointment
